12-10-2011, 10:39 PM | #1 |
Rep 2
Frameless windows and freezing
Hi everyone! New member here!
I bought a new 2012 128i Coupe a few months ago... Now that the temperatures have gone below freezing point here in Qc, Canada, I've been having trouble with the window mechanism which lowers it a few inches to clear the door frame when you open/close the door... The problem is that the window often completely freezes in the morning so when I open the door, it doesn't go down like its supposed to... The door opens fine but when I try to close it back, the window hits the frame of the door and the door doesn't want to close !! I worry I'll just break the window if I force it, but then again I can't drive with the door opened ! Most of the time I just wait a bit for the car to warm up and the window finally moves but I guess it won't be as easy when the temps go much lower in the next weeks... Someone else has encountered this problem ? Thanks |
12-11-2011, 04:12 AM | #3 |
189
Rep 682
Drives: 09 328i Sport 6MT
gummi pfledge.
here's a link to a discussion about some of this type of stuff http://www.bimmernut.com/forum/5-ser...i-pfledge.html this stuff will keep your rubber seals healthy for a while, and should help them remain flexible and your windows from sticking. |
12-11-2011, 06:58 AM | #4 |
217
Rep 1,489
This is a common problem with the 1er. The quick/easy solution is to get a roll of 3M blue painters tape. Keep in the inside door pocket. Place a strip of 3M tape across the bottom of the window/trim. Half of the tape sticking on the window and the other half of the tape sticking on the trim. Press it on very lightly.
The next morning/or when leaving work, walk up to the car and just pull the tape off with one motion. Now............yes, that is very silly doing that to a $40K car.........but it will save the window mechanism from damage.
-Diplomacy is saying, "nice doggie while trying to find a rock"-
07-Z4 coupe-Black/Black/6MT/sport/premium/X 04-M3 vert-Black/Imolla/6MT/Cold/Xenon/HK/ 06-M3 Coupe-Mystic/Black/6MT/ZCP/Xenon/HK/ 09-135i- AW/Bk-Lette/6MT/M-pac/Nav/Hi-Fi/Usb-Ipod/SOLD |
12-11-2011, 07:37 AM | #5 |
189
Rep 3,435
Yeah I've had this problem all last winter, and just the other day when my car froze over. One of the first places I scrape on the windows are the bottom of the side windows. The doors won't shut unless the windows drop down a bit. I'm always worried that I'm gonna shatter my side windows if I close the door too hard and the window doesn't drop a little.
The tape idea is pretty good. What about that de-icing spray that Rain-X has? |
12-11-2011, 09:05 AM | #6 | |
89
Rep 3,732
Drives: BMW S1000XR
BMWCCA member |
12-11-2011, 02:09 PM | #7 |
Still a Honda Fanboi
Rep 148
This happened to me last year. Just tap the power windows down a very slight amount, enough to clear the frame but obviously not too low to let any snow in. it worked well for me.
2011 135i / 6MT / Alpine White / M-Sport
12-11-2011, 04:46 PM | #8 |
41
Rep 825
I use a silicone spray on the rubber seal about twice a month in the winter and never have a problem. This is my 3rd BMW with the windows that go down slightly when the door is opened and since I use the spray never a problem. The silicone spray is similar to gummi pfledge if you can’t find gummi pfledge. I do not leave my car out overnight so it may be worse for those folks but before I started using silicone spray I would come out of work in the winter and sometimes have the sticky window issue.
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
12-11-2011, 08:07 PM | #9 |
Rep 2
I finally tried putting some Armor All on the rubber seal at the base of the window this morning (its the only product I have here that I tought could work..) and the windows were not frozen tonight when I left work.. I guess putting some regularly will keep them from freezing..
Still can't believe BMW has not tought about this when they designed the car! |
12-12-2011, 07:56 AM | #10 |
44
Rep 1,003
Made it through our insane winter last year without a problem. I've had other cars that have this window drop feature, too, and only rarely had a problem. There are quite a few makes/models on the market right now that have windows that opearate in a similar matter, so it's not really a BMW problem, per say.
12-12-2011, 09:48 AM | #11 | |
Loves his G20
265
Rep 2,507
Exactly, this will solve the issue which is common in E46 coupes as well. Bavarian Auto-sport also has it.
2020 330ix-Msport Past- 2013 135i 2011 135i |
