12-05-2011, 01:16 PM | #1 |
Party at the Moontower
135
Rep 1,287
Dinan Stage 1 thoughts
Hey,
I'm waiting for Winter to pass but stopped to talk about coil over kits with a local shop. I mentioned the K&W sleeve over kit vs complete coil over system but being a Dinan rep he recommended the Dinan stage 1. I told him it was strictly cosmetic not going to track it. In a nutshell he said stay away from coil overs you'll hate them. Any thoughts on the Dinan stage 1 other than too expensive? Also been thinking about some rims, but the kind I want only come in 20's. Are 20's to big? this is for an 08 E90 The guy knows his stuff so i'm kinda torn. |
12-05-2011, 01:42 PM | #2 | |
926
Rep 15,818
He says you will hate them cause he can't sell them to you I have Dinan Stage 1, but I got it for a steal. Otherwise, i would have gotten a KW Sleeve or GC kit. Or spent the $$$ for coils since you only want cosmetic, don't get the Dinan. the drop is barely noticeable. I like my Dinan...for the price I paid for it. I wouldn't pay any more. I also got the Dinan Camber plates, which are more than I wanted to spent but half the cost of the alternative (GC)
12-05-2011, 01:50 PM | #3 |
135
Rep 1,287
12-05-2011, 02:37 PM | #4 | |
ESS Dreaming
27
Rep 870
The Dinan stuff makes the car perform much better but doesnt really help in the way of looks. The drop is minimal as its function over form. It sounds like the KW sleeve kit would be your best bet because it will allow you to get the exact ride height or look you want. If you just do springs it might be too high or too low. Save the coilovers or Dinan stuff for the track |
12-05-2011, 03:07 PM | #5 |
169
Rep 3,832
The Dinan set up is a street set up, not well suited for track. I personally found the 1/2 drop noticeable and think its a perfect drop, I dont like the slammed look.
Nice ride on the street.
12-05-2011, 03:11 PM | #6 |
15
Rep 274
12-05-2011, 03:35 PM | #7 |
135
Rep 1,287
is that what you have in your signature photo? car looks low! also how do you like the intake?
12-05-2011, 03:44 PM | #8 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Skip the Dinan and save you money for other parts.
12-05-2011, 04:04 PM | #9 |
926
Rep 15,818
Stage 1 2 or 3 all have the same springs
Just in case you guys don't know difference is with stage 2, you get the sway bar, with stage 3 you get the camber plates. spring/ride height is the same on all the dinan set up is better than stock, but not that much better; both on street and on track
12-05-2011, 04:13 PM | #10 | |
169
Rep 3,832
I have run Moton SS, and KW CS on my car, they run much lower ride heights and great track performance, but a little harsh on street compared to Dinan, if the OP cares. The sleeve kits will also run stiffer then the Dinan set up IMO.
12-05-2011, 06:15 PM | #11 |
97
Rep 3,246
Dinan works well for me, but would like a bit more performance (coilovers in the fuutures ) but they are quite comfortable on the street.
mods: track ready stuff
12-05-2011, 06:58 PM | #12 | |
1770
Rep 6,696
Drives: F30 340i
12-05-2011, 07:43 PM | #13 |
1578
Rep 8,077
Drives: 11 E90 M3 Individual
Stage 3 is higher in front due to the camber plates.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
12-06-2011, 02:48 AM | #14 |
926
Rep 15,818
This
I forgot to mention this It's 1/4pm higher with camber plates Which means you only have a 1/4 in drop total
12-06-2011, 05:32 PM | #15 |
16
Rep 439
Stupid question, but if you go with C/Os, would you need a camber (maybe toe) kit as well? I had to get this on my last ride, but I was only on springs.
12-06-2011, 05:49 PM | #16 |
1889
Rep 5,506
I'd suggest the KW Sleeve Over Kit. It has shorter bump stops to increase travel and it is engineered to work with the stock EDC shocks. You can set the ride height as you like - even match the Dinan's setting if you want. And it costs less!
I only see advantages over the Dinan besides maybe that the Dinan has a softer ride. |
12-06-2011, 11:24 PM | #17 |
1006
Rep 3,341
I've got the Dinan Stage 1. It's a very noticeable drop to me, even more so than ZCP...at least on my car. I like the feel better than stock, it's firmer but rides so nice and comfy!
12-07-2011, 11:11 AM | #19 |
135
Rep 1,287
12-07-2011, 11:13 AM | #20 | |
307
Rep 13,093
12-07-2011, 11:36 AM | #21 | |
1889
Rep 5,506
The advantage of height adjustability is not just to go low, it is the ability to set it as you like and also corner weighting to set up for track use. |
12-07-2011, 12:51 PM | #22 | |
135
Rep 1,287
How much is the Dinan stage 2 with the sway bar? anyone know off hand? |
