11-22-2011, 04:02 AM | #1 |
112
Rep 994
Drives: M2, 135i, Xclass
Air Scoops
I was thinking of getting either the Macht Schnell Scoops or Cyba Scoops. The Macht Schnell have more of an OEM appearance.
Has anyone has any experience with these scoops? Do they work? Which ones do you recommend? Macht Schnell Scoop Cyba Scoop
__________________________________________________ |
11-22-2011, 04:13 AM | #2 |
112
Rep 994
Not sure. In theory they should as they would direct more cool air into the air box
11-22-2011, 04:23 AM | #4 |
112
Rep 994
Not unless you're blowing air directly into the scoops while on the dyno.
11-22-2011, 04:59 PM | #6 |
Rep 146
Any ducting that diverts more air towards a cooling unit / intake will work... whether or not you get a positive outcome out of it is another story and is really up to the answers to the following questions:
1) are you ducting fresh, cold air or are you ducting heat-soaked air? 2) is the duct properly sealed to whatever you're ducting to so you are getting maximum efficiency? 3) does the design of the duct allow for easy routing of air (i.e. minimum turbulence) or has it got large and sharp kinks throughout the path? I've seen ducting work very well on past projects in the area of oil coolers, intercoolers, intakes, and even engine components. It's definitely not just another piece of 'bling' on the car. Word of warning, some air ducting can actually be counter-productive in certain situations. An example of this would be ducting for oil coolers where it is possible to over-cool the system making warm-up times excessively long.
| 2011 BMW 135i | AW, N55, Prof. Nav, 18% Tints, Kerscher CF Splitter, CF Rear Spoiler, Matte Black Grilles Build Thread |
11-22-2011, 05:57 PM | #8 |
33
Rep 646
I've got the cyba one. Paying $50 for a scoop is stupid enough let alone > $100
It doesn't block that much of the radiator. I didn't expect too much a difference because the factory ducting is already sitting in a high pressure area so any ram effect is minimal. 6th gear pull on highway speed seems more effortless and I am hoping the scoop is acting more like a heat shield at lower speed rather than a ram device. |
11-22-2011, 06:58 PM | #9 |
89
Rep 3,070
Drives: A boring one...
I have scoops, and wouldn't say they made any difference. I originally had them as my intake has a plenum which pushed air directly onto the filter but don't use the plenum as it was tapping on the bonnet.
If you have a stock intake they would be pointless... |
11-22-2011, 07:05 PM | #10 |
334
Rep 4,021
Drives: F32 Coupé
I've got the Macht Schnell ones... No idea if they've made any difference or not...
11-23-2011, 08:59 PM | #11 |
44
Rep 1,883
You can't over-cool if the oil thermostat (if present) shuts off the oil cooler flow until the preset thermostat temp is reached.
11-23-2011, 09:26 PM | #12 |
334
Rep 4,021
Drives: F32 Coupé
PS: In case anyone's interested, I have a set of Riss Racing Scoops. 3rd hand and need to be refinished... Offers?
11-24-2011, 04:12 AM | #13 | |
Rep 146
But you are right, products do exist where this is taken care of by the use of a thermo.
