11-07-2011, 10:11 AM | #1 |
Rep 144
17" or 18" for snow?
How much better traction do you get running 17" snows (Blizzaks) vs. 18" snows (Blizzaks)? I live in the DC area and we usually do not get that much snow so wondering if I could get away with 18s.
Also, with staggered rims sizes is it better to run a square winter set up? Thanks! |
11-08-2011, 08:36 AM | #2 |
40
Rep 1,058
Winter traction is more about tire width than rim diameter, the thinnner the tire the more it will bite into the snow, the wider the tire the more it will float on the snow. Typically if you are installing a larger diameter rim you will be using a wider tire (typically). A square set-up is the best for winter and it allows front to back rotation. Not knowing what rim/tire combo you're looking for I'd say a 17"' square set-up will give you the best traction.
The faster you go, the better it feels
11-08-2011, 10:42 AM | #4 |
117
Rep 1,998
i run 17" square set up for winters ... theya re also very forgiving with the ruts and holes as opposed to the 18's that you may consider..
Although thinnner is better... I had 7.5" wheels that double duty as my track and winter wheel.. I run 225/45/17 ( which is basically the rear tire on a sport suspension 128) for both sets... Had absolutly no issues in last years 8 snow storms / blizzard in NY..!!! You will appreciate the ability to rotate.
X1, R58 JCW, M2 in my future if planets align
11-08-2011, 11:43 AM | #5 |
Rep 144
Thanks DriveHard. So you run 225/45/17s on your stock M207s? I was either going to put staggered tires on those or sqaure but use 205/50s (if they fit on the rear).
11-08-2011, 12:23 PM | #6 | |
117
Rep 1,998
i have heard that persons use the rear wheel with the tire you say... I would spend a few more bucks and get dedicated winter wheels and tires ...you will be so much happier in the long run.. you can swap them yourself in the street if you had too.. also you run the risk of damaging 8 tires 2 times a year on mounting and dismounting...not to mention the labor $'s and the risk to damaging you OEM wheels just my .02
11-08-2011, 12:34 PM | #7 |
European Editor
10596
Rep 22,992
I run the BMW winter wheel/tire package. The wheels are 17x7j on all fours. The tire size is: 205/55HR17's on all fours. They also come with four TPMS sensors.
Running a tall skinny tire is best for winter "bite" in snow. Also the taller sidewall makes for a nicer ride when traveling over those huge winter potholes. Remember you don't want to skimp on tires because it IS your only connection with the road. Also... the first accident you AVOID will pay for the added cost of having a dedicated set of winters and summers. No compromises. 17" V SPOKE 141 (not for 1 M Coupé) 17" Alloy Wheels w/TPMS Goodyear Eagle UG-GW3 RSC 205/50R17 89H Run-Flat |
11-08-2011, 01:24 PM | #8 |
Rep 144
Thanks! I have 17" M207s from my 128 plus a set of 18" M261s for non-winter months. The M207s would be my dedicated snow wheel but they are staggered so not sure then if I should run staggered snows on the 17s or square (205s or 225s). I appreciate all of your feedback!
11-08-2011, 02:49 PM | #9 | |
2048
Rep 25,989
The width of the tire will definitely determine how well a setup works in winter. 18s will work as well though!
VMR|Wheels | 714.442.7916 |
11-08-2011, 03:08 PM | #10 |
28
Rep 457
I just picked up 5 Blizzak LM-60 tires (used less than 500 miles for $400) running 225/40/18 on the stock 264 wheels, can't wait for the snow to see how they do, it should be a great set up though. They do stretch a little on the back wheels, but still should be fine
Current: 2018 MSport x1 & 2009 Cayman S
Former: 2013 BMW 335i XDrive M Sport 6spd Cobb Tuned '09 135i |
11-10-2011, 04:41 PM | #12 |
2452
Rep 7,341
I also do a 17" square setup for the winter. Works VERY well!
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold |
11-10-2011, 06:14 PM | #13 |
Moderator
369
Rep 4,745
17" gives you more flex in the sidewall and more protection from wheel damage. Usually 17" offers more options in the studless category.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
11-11-2011, 06:29 AM | #14 |
Let's save military ranks for those who earn it!
45
Rep 1,161
Drives: ...on the Ragged Edge
17" square here for going on three winters, running Nokian Hakkapeliitta 5's. The car will go through anything that winter throws at it (last winter was a return to 1970's era snowfalls here). Never got stuck once...
Richard
2013 BMW M3 Individual -- Fire Orange (sold) 2013 BMW X1 xDrive35i M-Sport -- Valencia Orange (sold) 2011 BMW 1-series M Coupe (#205/220) -- Valencia Orange (sold) 2009 BMW 135i M-Sport Coupe -- Space Grey (sold) |
11-11-2011, 07:26 AM | #15 |
aiming for 450.....
304
Rep 2,910
Stick with 17's square. I have 205/50's Michelins on mine right now. Last year I had Pirelli Sottozero's and had no problems getting around in the Bavarian winter.
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car " |
11-17-2011, 03:59 PM | #17 | |
Rep 56
I started another post yesterday which kinda relates to this: http://www.1addicts.com/forums/showt...6#post10817806 |
11-17-2011, 11:58 PM | #19 |
52
Rep 874
11-18-2011, 06:16 AM | #20 | |
Resident Kerbalnaut
477
Rep 10,703
Moral is more sidewall to deal with potholes! I also didnt mention this before. But that is one of the 264s that my car came from the factory with Last edited by BrokenVert; 11-18-2011 at 06:24 AM.. |
11-18-2011, 06:23 AM | #21 |
Unindicted co-conspirator
66
Rep 1,734
Drives: to work, mostly.
Another vote for 17" square set up and for getting dedicated winter wheels. Blizzaks have served me well for two winters (including getting caught in that memorable blizzard in 2010.)
I also picked up a set of snow chains for extreme situations, although that's more for peace of mind insurance than anything. |
11-20-2011, 03:43 PM | #22 | |
28
Rep 457
