      11-05-2011, 12:53 PM   #1
Wykf1m
Drives: 1m
M5 blue brake caliper upgrade?
Is Anyone decide upgrade there brake caliper to f10 m5? Just wondering will 400mm disc will fit the 19\'s?
      11-05-2011, 04:58 PM   #2
elitt13
elitt13's Avatar
France
156
Drives: 1///M Coupe & ///M2 CS DKG
2020 BMW M2 CS  [0.00]
2011 BMW 1M coupé  [10.00]
2007 335i  [0.00]
I've the same idea!!
but I don't no ...
- Série 1 ///M BSM -
      11-06-2011, 12:09 PM   #3
bimmer ///man
100
Drives: M
Why would you? That caliper was designed for that car. A car that is at least 600lbs heavier.
Why would you not chose from the many availble big brake kits designed for your car (Stoptech, AP Racing, Brembo)?
      11-06-2011, 12:45 PM   #4
1SerieStud
1SerieStud's Avatar
183
Drives: '11 VO 1M (498 of 740)
+1. Why would you AT ALL? Your car came equipped with brakes capable of performing on a car that weighs 300-400lbs. more (M3), why do you think you need to upgrade them when every review raves about how amazing they are on our smaller, lighter cars?
      11-06-2011, 01:56 PM   #5
mm1
Drives: exE90 M3/ now1M
It doesn't look like you have driven the car on track, brakes on the 1M are useless, even with upgraded pads
      11-06-2011, 02:05 PM   #6
1SerieStud
1SerieStud's Avatar
183
Huh? That's a first, specially coming from a consumer and not a professional driver...I truly doubt that 99% of the people hanging around these forums could possibly and properly put the car through its paces to the point where brakes need to be upgraded. By the way, using the brakes too much does not constitute as "proper" driving/racing.
      11-06-2011, 03:13 PM   #7
ESC OFF
ESC OFF's Avatar
40
Drives: 1M, CaymanS, 914, 500 Abarth
Please elaborate on your statement, what is it based on?
The faster you go, the better it feels
      11-06-2011, 03:14 PM   #8
HALOTHANE
HALOTHANE's Avatar
36
Drives: INTERLAGOS ZCP
Having tracked the car, the stock brakes in the 1M suffered from fade noticeably more than the Brembo's on my old 135i M-Sport (also tracked at same course and similar summer heat). I have not tried track pads yet on the 1M.
      11-06-2011, 05:37 PM   #9
Dan Parker
79
Drives: 2012 Golf R
Stock brakes with better pads and fluid are awesome. Even on a track that is known to be hard on brakes. My opinion.
Dan Parker
      11-06-2011, 06:09 PM   #10
1M Fan
SMSgt
11
Drives: AW 1M Coupe
1012 F150  [0.00]
1971 Chevrolet Nova  [0.00]
2011 1M  [0.00]
What fluid do you recommend and at what point do you recommend it. Example:
1. 20-30 minutes of fun runs on a road track
2 100+ lap event
3. Something in between
I've only autocrossed the car so far, but I would like to get it on a road course for some fun laps.
      11-06-2011, 07:06 PM   #11
hopofthese
Drives: E46 M3 & 11 1M
Maybe I got a special 1M but the brakes are awesome. *Stock fluid and I went through DTC 70's and PFC 01. *You do not need a big brake upgrade. *
If you went to the track on stock pads and are coming on here to complain about the brakes then shame on you.
      11-06-2011, 07:12 PM   #12
MusclezMarinara
262
Drives: VALNCYA
      11-06-2011, 07:13 PM   #13
Oaktree
Oaktree's Avatar
Drives: 2012 X5 - 2010 M3 - 1999 M3
Track pads, fluid, ss brake lines are all you need. I know many M3 owners that are successful with is setup.
      11-06-2011, 07:21 PM   #14
Dan Parker
79
Drives: 2012 Golf R
I used super blue but motul 600 and just about any high temp fluid should be fine. 1.3 G's in braking, without any fade, lap after lap at Road Atlanta in nearly 100 degree temperatures says a lot about the stock brakes with minor improvements (pads + fluid). I bled the brakes when I changed the pads back to stock and the fluid showed no sign of discoloration either. Before I spent any money on BBK upgrades, especially M5 from BMW as they will probably be insanely expensive and not meant to bolt up to the 1M, I'd spend the money on 18" wheels and tires and most importantly track time.
Dan Parker
      11-06-2011, 07:25 PM   #15
Franklin Joseph
57
Drives: BMW
BBK would be the last upgrade i'd do (assuming i have $$ burning a hole in my wallet)
Stock brakes + pfc01 + castrol srf at the track with no issues at all.
      11-07-2011, 03:30 PM   #16
p66
56
Drives: 1M
Tracked my car last Friday at a private event at Eagles Canyon in Slidel, TX. That track can be hard on brakes. 5, 30+ minute run sessions. Hawk dtc70 pads and motul 660. No fade at all. Rock solid. Running R compound tires. I wore down a set of almost new front pads to the backing plate. Good pads and fresh fluid and you should be fine for most DE events at most tracks.
      11-07-2011, 03:44 PM   #17
Amnizu
20
Drives: 502 of 740
How is the pedal feel in this setup? I'm spoiled by my WRX, but to me the pedal on stock setup and fluid feels soft. Does not inspire confidence when braking prior to entering a slow corner...
      11-07-2011, 04:58 PM   #18
p66
56
Drives: 1M
The DTC 70 pads are superb. Strong initial bite with good release characteristics. First time I've used these. Was surprised how quickly they wore down. No complaints for track use. Not recommended for use on the street. They do not have good bite under light pressure when cold and they squeal something aweful. But that is to be expected. I only drive on them to and from the track.
      11-07-2011, 05:42 PM   #19
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
you mean.. the stock PADs suffered from fade ? . And yes... if you had Brembos on the 135 with track pads.. then it's just not a fair comparison is it? As others have mentioned.. the 1M already HAS a BBK on it... when the M division decided to put the calipers from the M3 on.
I will send you a PM... I am a member at ECR ..
With all due respect to Dan.. Road Atlanta is indicated to be tough on brakes.. but personally really don't think it is SUPER hard on brakes.. You have hard braking zone for 10A-B... and that's really it..... Most other places (1, 3,6,7).. the driver is on the brakes and back off again quickly.. Reminds me of Texas World Speedway..
Eagles Canyon is absolutely the hardest track on brakes I have been to. Three medium long straights, and a slight dowhill braking into each one.... .. andd each one the driver needs to slow from 110-115 to about 50. In addition
there are two shorter straights... also with downhill slopes.. I have been to Mid Ohio..x 2.. Road Atlanta x 3... Road America once.. barber motorsports park x 4... TWS many times.. Hallett...x 3 Putnam Park.. .. Motorsport Ranch Cresson and MSR houston.. Watkins Glen.. and a few other tracks.. Eagles Canyon is by far the hardest on brakes of all these. Hallet would be second .. I can certainly see going through a set of pads in a day at ECR... It's just not a track that one can show up to with 50% pads.
I was out at ECR myself on Saturday with a club driving tour and did about 5 laps... looking forward to heading back up for a member day. I did 5 sessions in a day at Barber Motorsports Park with the stock pads .. no issues.
Personally.. I plan on getting some good pads (PFC-01 or 06) , SRF fluid.. and that's it.
if you've got money falling out of your pockets... or just want cool man BLUE calipers.. have at it.
      11-07-2011, 06:52 PM   #20
v1k0d3n
v1k0d3n's Avatar
92
Drives: M2C /// (and x3 for the wife)
The first thing I do before going to track/auto-x is change brake fluid out to ATE Super Blue, like Dan recommended. Awesome stuff! I change out the pads as needed, but I've found that fluid and pads make the biggest difference, making a complete caliper kind of pointless (it's more bling vs. stopping power than most people actually need).
Last edited by v1k0d3n; 11-08-2011 at 08:30 AM.. Reason: working on ipad...meant to say change brake *fluid* out
      11-08-2011, 06:28 AM   #21
mm1
So you know me personaly, that`s a first, should I list for you my achievments in racing?
On a recent trackday at Spa (it`s in Belgium, near German border, maybe you`ve heard of such a place) brakes were rumbling away in third lap, ofcourse Spa is really hard on the brakes, but anyway all Mcars have problems with brakes, and the ONE is no exception.
      11-08-2011, 06:45 AM   #22
1SerieStud
1SerieStud's Avatar
183
Oh please dude, we both know you're no Schumacher....I don't need to know you personally to say that. You do fall under the category of consumer whether you like it or not - we all are. No need to list your "achievements", and yes I'm familiar with Spa, it's not like we live in a bubble on the other side of the globe
Anyhow, that's beyond the point of the thread. According to you the brakes are garbage, and according to everyone else who tracks regularly a change of fluid and pads suffices. That's good enough for me, as a caliper replacement would be a waste of money.
1addicts
