BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Australia
      11-01-2011, 03:07 AM   #1
DaveDee
DaveDee's Avatar
532
Drives: BMW X5M Comp
Akrapovic Evolution with ESS Tune
Now updated to Gintani Sport Dual wall Valved Rear Section (black ceramic) with X-pipe and high flow cats.
      11-01-2011, 09:10 AM   #2
disapr
drop a gear and...
79
Drives: 2010 M3
Nice write-up and video! I had the same setup just before I supercharged and I loved it!
      11-01-2011, 09:39 AM   #3
Huy
Drives: R34 GT-R
Nice read. The car looks and sounds fantastic.
      11-01-2011, 07:59 PM   #4
SPQR M3
SPQR M3's Avatar
Australia
43
Drives: 2009 E92 325i
Great review and video Dave, very well explained and summarised.
I have the exact same setup as you, as you know. IMO a tune is essential if you have the Akra exhaust, it really brings out the best qualities.
      11-01-2011, 08:24 PM   #5
DaveDee
DaveDee's Avatar
532
Thanks for that Chris, it would be great if you have some pics or the carbon tips on yours you could add.
      11-02-2011, 02:46 AM   #6
MFKN3
MFKN3's Avatar
Australia
127
Drives: supercharged 4.4L stroker E92
Good stuff mate, see all this time you were a car-modding hoon and didn't even know it! Good write up on the tune, I know Andrew has done a fair bit of work as well, with dyno's and getting tunes right. Most people seem to do a few things at once, so it's good to hear the tune alone is a good buy
      11-05-2011, 04:01 AM   #7
MFKN3
MFKN3's Avatar
Australia
127
Those akra tips look badass!!
      11-24-2011, 10:13 AM   #8
E93Blackhawk
E93Blackhawk's Avatar
31
Drives: 2008 335i M sport
Slightly off topic.
But can someone answer this. The differences between the....
Akrapovic ESS tune and ESS's direct flash software?
Does the Akra ess tune still remove cold start cycles and top speed governor for instance like the DF does?
By my understanding the direct flash is the module obviously and that you send your ECU file to ess and they send it back and upload it.
How does the akrapovic ess tune work? In the same way? So how are they different if you get what i mean?
Sorry just a little confused
      11-24-2011, 01:30 PM   #9
DaveDee
DaveDee's Avatar
532
Originally Posted by E93Blackhawk View Post
Slightly off topic.
The ESS tune may be done at ESS using their workshop programmer, but the ESS Direct flash unit is a handheld programming tool, available to customers outside the ESS workshops, that plugs into the vehicle OBDII port which allows access to the ECU.
If the ESS direct flash has not been used before (or is reset) it will read the firmware of the ECU and store it as a file (along with the VIN) which can be later transferred to your PC (via a USB connection) to a communications program supplied by ESS.
The file is then saved and sent by email to ESS where alterations are made to the ECU firmware to enhance performance, just like a ”remote tune”.
When the Akrapovic Evolution exhaust system is fitted the gas flow and performance changes substantially, plus the factory cats are replaced by small high flow cats that do not use the O2 sensors where the factory cats used to be. The change in performance to the car by the exhaust system, the lack of stock cats and the error (CEL) caused by the absence of stock cats are taken into account by the ESS tune when the Akrapovic Evolution (not the Akrapovic slip on system) is fitted .
The modified ECU firmware is emailed back to you, loaded into your hand held ESS direct flash unit via the PC software/USB cable. You then take the ESS Direct flash back to the car, plug it in to the OBDll port and upload the modified ECU file. If the Akrapovic Evolution exhaust modification is included in the file the cold start cycle will be removed as there are no longer any factory cats to preheat. Much smoother start. Hope that covers it. Andrew at Southern BM is a supplier of these kits and is an expert in this area. He also does the tune on site if you prefer. If you are purchasing the Akrapovic Evolution and are going to tune the car you don’t need to purchase the “delete-R” module.
      11-24-2011, 03:30 PM   #10
aussiem3
aussiem3's Avatar
Australia
274
Drives: Goggomobil
Very good write up and congratulation on a very nice looking car. Happy driving.
F86 X6///
      11-24-2011, 06:45 PM   #11
Erik@EVL
Erik@EVL's Avatar
Australia
Drives: Tester
Hi DaveDee,
Great write up and glad you are happy with the Akrapovic. You are very right, if you are tuning the car when using the Evolution, then you won't need the Delet-R - just always make sure the CEL check is removed in the tune. But if you are not wanting to tune it for what ever reason the Delet-R is the easiest way to stop you check engine light coming on because of the hi flow CATS. Its a plug in job and its made so you can update away at your BMW service without needing to reflash. Got to admit I do like the ESS Direct Flash from Andrew
Cheers
Erik
www.evlmotorsports.com.au
Official KW and Akrapovic Importers/Distributors
      11-26-2011, 06:35 PM   #12
DaveDee
DaveDee's Avatar
532
Originally Posted by Erik@EVL View Post
Hi DaveDee,
Cheers
Erik
Hi Erik
Thanks for your input. Do you have any pics of the carbon tips you can post? Are the highly polished tips still available. The stock titanium is really nice but it would be good to see some photos of alternatives posted
      11-27-2011, 09:47 PM   #13
Veratyr
Dr. Drive
35
Drives: 2009 BMW M3 E92
2023 BMW X3 M40i  [0.00]
2018 BMW M4  [0.00]
2009 BMW M3 E92  [0.00]
Would the Akrapovic Evolution Titanium Exhaust system pass emissions testing?
2009 BMW M3 E92/space gray metallic/VT2-600 ESS Supercharger/extended silver novillo leather/performance carbon fiber interior trim/DCT/BMW performance spoiler/19" Volk TE37SL wheels in pressed graphite.
      11-27-2011, 09:53 PM   #14
DaveDee
DaveDee's Avatar
532
Don't think so. I'm pretty sure the slip on system does though. I guess most after market systems either fail noise or emissions levels.
      11-29-2011, 04:20 AM   #15
Alpine*
Alpine*'s Avatar
Australia
1282
Drives: M2 G87
Hi Erik
Hi Dave, these are the ones on my 1M that Andrew added on Friday.
      11-29-2011, 12:17 PM   #16
E93Blackhawk
31
Thanks for clearing that up bud
m3post
