10-28-2011, 05:32 PM | #1 |
2314
Rep 4,341
Instructions for drilling and attaching front license plate bracket?
I got my license plate bracket and hardware at Welt and told dealer not to install it after delivery. I think I will go ahead and do it, but there were no instructions. Anyone know of a PDF or instructions somewhere? There are screws and felt strips, etc that I don't know where they go or if they are for the rear bracket.
Thanks |
10-28-2011, 06:18 PM | #2 |
115
Rep 1,998
are you talking european long plate bracket, or usa small plate bracket???
if usa, there are 2 tabs on the bottom of the bracket that go into a slot in the bumper cover. once those tabs are in, its basically run a screw into the cover... sometime they come with the 2 longer screws that are fine thread to grab the cover well... thats all ther is to it.. it just sucks that you actually drill into the cover... i havent put a front plate on my cars in over 10 years!!! and in NY its a front plate state.. 1 ticket in over ten years.... guess ive been lucky..
X1, R58 JCW, M2 in my future if planets align
10-28-2011, 06:22 PM | #3 |
20
Rep 325
10-28-2011, 06:25 PM | #4 | |
Rep 83
10-28-2011, 06:29 PM | #6 | |
2314
Rep 4,341
Anyway, I will hold off as long as I can but if anyone knows of the instructions for where the foam pads go, let me know. Thanks |
10-28-2011, 06:58 PM | #7 |
63
Rep 901
I'm going to use the Tow Hook Mount. I am not going to put holes in my bumper.
I live in California but never gotten pulled over for the license plate. I might just go without a front plate until then.
2011 VO 1M
10-28-2011, 06:58 PM | #8 | |
Gold Member
161
Rep 512
BTW +1 for the tow hook mounts. http://www.rhoplate.com/ http://www.cravenspeed.com/the-platypus/ http://m3forum.net/m3forum/showthrea...light=eurodyne |
10-28-2011, 07:00 PM | #9 |
13
Rep 335
My guy at Ridgefield BMW in CT called me to ask whether I wanted it drilled or not. The answer was 'NO" and he's getting all 10's in his survey because of it. Thanks David!
10-28-2011, 08:27 PM | #10 |
14
Rep 249
Tow hook all the way.
I got the 70$ jobbie from us millworks. Works good and is solid and versatile mount. http://www.usmillworks.com/bmw_front..._tow_hook.html You can call the guy and he will talk with you about it, good guy very helpful. The CP-e is the other choice. Very solid looking. |
10-28-2011, 08:39 PM | #11 |
Thread killer
643
Rep 1,896
There was an extensive discussion about tow hook mounts several weeks back:
http://www.1addicts.com/forums/showt...light=tow+hook Black Angus: can you post some pics of the US Millworks mount on your 1M? I'd reiterate the positive experience with US Millworks. Even though I didn't buy, he was completely helpful in offering assistance. |
10-29-2011, 12:59 AM | #12 | |
Rep 15
Great mounting and easy to use!! |
10-29-2011, 02:13 PM | #14 | |
2314
Rep 4,341
Thanks! |
11-23-2011, 04:44 AM | #16 |
Kind of a big deal
300
Rep 1,674
Drives: an 1M not often enough
Now this is a nice way of plating: Stick On, does anyone know if NYS allows / who produces stick on front plates?
Does anyone notice the local rivalry between 911 and GTR owners (sorry for low contrast pic: what will hopefully be visible is a Belgium GTR that has "911 Bye" as a stick on front license plate ! |
11-23-2011, 06:21 AM | #17 |
12
Rep 383
I'm in NY and I'm running the cp-e plate and it's definitely a solid piece.
I know some people have gotten away with not running a plate at all (it's the best aesthetically,) but the last thing I'd want is to get pulled over after a dinner where I had a glass of wine. Just a thought... |
11-23-2011, 07:36 AM | #18 |
MSgt (ret)
563
Rep 2,116
Drives: VO 1M #739/740
Don't screw with my bumper
Also very adamant about screwing up the front bumper of this gorgeous car..so for a couple of weeks drove with plate in windshield until I came up with a solution.
I basically took a L-shaped bracket...kind of like to hang a shelf, 3-4 inches per side, bent the 90 degree angle about 10+ degrees more. Bent the other end completely around in a "U" shape, drilled a hole through both sides of the "U" and then slipped it into the grill. Once all the way through, pulled it out using the grill as the first point of support. Put 4 layers of double-sided tape to provide cushion between bracket and bumper...that's the second point of contact. Slipped a couple of plastic washers between the "U" and then stuck a screw about 3/4" long and secured bracket to bumper from underneath. That's the third point of contact/support. Finally screwed the European frame against the bracket with short screws and used duct tape to make everything neat. I intentionally used the same points under the bumper as the US style bracket so I can use this same gizmo in the states. Entire job from idea to final, two hours. Hope that helps. Last edited by Rikx1M; 11-23-2011 at 08:06 AM.. |
11-23-2011, 09:36 AM | #20 |
39
Rep 524
http://skenedesign.com/FPBracket/index.shtml
2009 135i Coupe - Sedona Red Metallic - Savanna Beige - 6MT- ///M Sports Package - Boston Leather - Power/Heated Seats
2005 BMW F650 GS - Mandarin Yellow - Farkled |
