10-23-2011, 10:07 PM | #1 |
35
Rep 278
Winter tire
I hope it not to late to get those ??
If so what the best on the market ?? for 19'' stock wheels I was thinking about Scorpion, any others ?? |
10-24-2011, 03:18 PM | #2 |
99
Rep 1,828
Drives: 2016 Tesla Model X P90DL
I just got Nokian WR G2 SUV in 20''
http://www.nokiantyres.com/product-group?group=2.01 I will install them in a month or so I would recomend them based on my research if you dont have to have RFTs It's still a good time to buy these Last edited by AndreyATC; 10-24-2011 at 03:45 PM.. |
10-24-2011, 06:52 PM | #3 |
35
Rep 278
are this any better? http://www.nokiantyres.com/tyre?id=1...itta%207%20SUV
10-24-2011, 08:02 PM | #4 |
33
Rep 576
i don't think we have to go all out and get studded tires for nyc winters, or no?
I'm about to pull the trigger on a winter setup myself, been looking at the pirelli scorpions but don't know if i should get rft's or not? When do you guys usually swap from summer to winter setup? |
10-24-2011, 09:58 PM | #6 |
99
Rep 1,828
I live a bit north from NYC, about 30 miles
I have very hilly area and i get a lot more snow than NYC I still picked G2s Considering you live in flat brooklyn and driving mostly on plowed roads in your AWD X6, even WR G2 is overkill These are also the best handling dry/wet tires of any winter tires And you will appreciate this 90%+ of the time in Brooklyn-lack-of-snow winter So, i believe it's a perfect tire for X6 and NYC winters Last edited by AndreyATC; 10-24-2011 at 10:04 PM.. |
10-25-2011, 08:22 AM | #8 |
99
Rep 1,828
In Brooklyn you have to worry about morons that always try outpace you and then they cant stop soon enough
I commuted in my 3 series for 8 years from Sheepshedbay Brooklyn to upper west side Manhattan With just winter sport tires it was perfect balance between dry winter and ocasional snow G2s are even more capable in winter than those Dunlops i had Now, if you wanna go with studded tire, you may be up for a traffic ticket (i think it's illigal in NYC) and also you going to make this annnoing ticking sound 99% of the time Also, 99% of the time, when you on dry/wet pavement, your stopping distance and handling will be worse than with G2s Anyways, Any winter tire is good, but with some you lose dry/wet grip and with others you lose a bit of winter performance Pick wisely, based on your environment Last edited by AndreyATC; 10-25-2011 at 08:27 AM.. |
10-25-2011, 09:23 AM | #9 |
WTF are you looking at?
232
Rep 1,560
Snow tires are much more important for ice than snow. Anyone that has ever ridden on a set of snow tires on ice knows how much more reliable they are than All-Seasons.
I have a set of All-Seasons on my X6 and they were fine for the snow last year but as soon as the road got a little bit icey.. it was a test in patience and attention. |
10-25-2011, 04:59 PM | #10 |
99
Rep 1,828
NYCGP,
I'm not sure I understood where you were going with this You just compared AS with winter tire, were you refering to something? Current discussion went towards winter studless vs winter studed tires We are trying to help OP to deside on proper winter tire setup All-seasons are out of the question |
10-26-2011, 12:42 AM | #12 |
15
Rep 119
winter tires
do u guys recommend a smaller rim. i ordered my car with the 20 inch y spoke, wanted a winter tire for those only the pirelli scorpion ice and snow available
10-26-2011, 08:18 AM | #13 | |
232
Rep 1,560
10-26-2011, 08:55 AM | #14 | |
99
Rep 1,828
1. M may not take 19'', due to bigger brakes 2. 20s look better 3. 20s ride better/sportier on dry (that's 90% of the winter in tri-state) 4. I had much smaller sidewall on my 335i and did just fine Remember that blizzard last year? I drove through it in my 335i from Philly to upstate with zero issues. And this was just RWD car with low clearance So, 20s vs 19s is a wash on this car |
10-26-2011, 06:46 PM | #15 |
isn't it?
21
Rep 262
Are snow tires essential for NY winters? I'm on Long Island and rocking a 5.0 with the huge meats (11" i think) In the rear. I had the Jeep SRT8, which was more powerful, and picked up a set of 8.5" wide 18" wheels and tires for the winter. Consequently, I sold that truck before I had the chance to test em.
10-26-2011, 09:43 PM | #16 | |
17
Rep 165
With all due respect
Common wisdom is to go for narrower tires to cut through snow better (rally cars use narrow tires for mud, sand and snow). While a wider contact surface makes sense for ice traction, it is detrimental on hard-packed and icy roads because of the ruts and irregular surface - wde tires "bounce" you around with ruts. Also, going to a high profile provides more "give" if you hit something at speed (ice ruts). Because of the higher profile, I stick with RFTs to give me the stiff BMW ride I paid for. |
10-26-2011, 10:54 PM | #17 | |
15
Rep 119
10-26-2011, 11:45 PM | #18 |
99
Rep 1,828
I got 20s with 10inch width Nokian WR G2 from WSTO vendor here
I dealt with Julius He got me whole setup, TSW rims, nokian tires and OEM TPMs Everything mounted, balanced and ready to drive I just got these, so i dont think it's a problem to get Nokians PM Julius@WSTO if you need help with winter setup |
