09-26-2011, 04:19 PM | #1 |
Rep 12
Start Off Assistance Inactive!
Hi All.
My 2008 M3 just recently started flashing up a yellow warning saying "Start Off Assisance Inactive!" I didnt notice any change in the car when driving around the city, and when I turn the car off, the warning always goes away. It will always come back though, sometimes when I first start the car, and other times after I've been driving for a while. On the weekend I took my first road trip with the car, and the car would either suddenly accelerate or decelerate when driving with cruise control on, and then the "Start Off Assistance Inactive" light would come on. After the light came on the car drove normally. Any ideas? Sensor? BMW told me they had no ideas but would be happy to diagnose for $130/hr. They told me that nothing came up on my key when they put it into their computer. |
09-26-2011, 04:23 PM | #2 |
36
Rep 547
isnt that the mechanism where it holds your car for a second on a hill so it doesnt roll back?
2008 E90 M3: Alpine White/ Fox Red Novillo/ Brushed Aluminum | 6MT | Premium | Cold Weather | Technology | EPS | PDC | Ipod/USB |
Fuelly :: Adelei's Gas Mileage |
09-26-2011, 04:28 PM | #3 |
Rep 12
Ya I think so.
I thought it might be caused by low brake fluid, but I checked it and it's full, and that wouldn't explain the weird way the cruise control was working I suppose. |
09-27-2011, 10:12 AM | #7 |
Enginerd
118
Rep 542
I believe this is tied into the DSC system. Can you get a code reader to check for fault codes stored on the DSC control unit? That would help us to get a better picture of the issue (sensor, wire short, bad module, etc).
2008 E92 AW 6MT /// 120k orig rod bearings
09-27-2011, 10:57 AM | #8 | ||
29
Rep 106
Wonder if any of the other features aren't working either...... Maybe it's an angle sensor that's gone to detect car is on a hill? Quote:
09-27-2011, 11:14 AM | #9 | |
Enginerd
118
Rep 542
Ref: http://wds.spaghetticoder.org
09-28-2011, 12:10 AM | #10 |
Rep 12
ill try and get the codes read tomorrow. thx for all the help so far!
09-28-2011, 01:36 AM | #12 |
BimmerPost Supporting Vendor
3388
Rep 7,542
How is the warranty out already? I thought it was 4 year 50 K...
When did you buy it and whats the mileage? Start off assistance inactive is just a message on the idrive is not descriptive. You would have to read the codes to see exactly what the problem is. Only someone with the proper equipment will be able to read it since this is not a generic OBD II specific code.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
09-28-2011, 07:59 AM | #13 | |
Enginerd
118
Rep 542
OP see what you got and we'll try to help.
09-28-2011, 10:28 PM | #14 |
Rep 95
If this is indeed the "hill assist" portion that has gone out, I'd pay to have mine disabled. This feature has been my biggest headache with the 6MT starting from a stop. It seems that, depending on how hard you were on the brakes when stopped, the release is never quite smooth/predictable. I tend to almost lift completely off the brakes as the car stops rolling in an attempt to keep this PITA "assistant" from kicking in. Having said that; I would not be willing to put up with a fault indication that would not clear. Good luck & let us know the resolution.
Delivered 02/20/09
LeMans Blue/6MT/EDC |
09-28-2011, 10:45 PM | #15 |
258
Rep 5,012
The 'hill assist' only has inputs from clutch and brake switches, but DSC is what actually keeps the brakes applied for up to 2 seconds. What's weird is no DSC error . Keep us posted on your results. Looks like you'd benefit from a Bavarian Tool right now. Good luck.
09-29-2011, 12:26 AM | #16 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
The fact that cruise control is also acting odd says to me it's maybe a speed sensor with intermittent issues. But, that's just a WAG, because I would think there would be other warning lights that would also come up if that were the case. Interested to see what this turns out to be.
09-30-2011, 02:46 AM | #17 | |
3388
Rep 7,542
07-19-2014, 04:21 PM | #18 |
Rep 12
hello all,
I finally ordered a bavarian technic cable and got the code. see new thread http://www.m3post.com/forums/showthread.php?t=1012553 |
09-20-2014, 02:40 PM | #19 |
Rep 12
The solution:
FYI it was the speed sensor (cluster) that was the problem. I found it hiding under the drivers seat, under a painted piece of the body, just forward of the under seat speaker. Relatively easy replacement, just had to disconnect the battery to avoid airbag BS, remove the drivers seat (but not the wiring harness, just leaned it back), remove the under seat speaker cover (no need to remove the speaker), pull the carpet and some of the foam away, remove the three bolts on the bracket and wiggle it out towards the front of the car. It must come out forward because of the way the wiring harness fits on it. I smashed the old sensor open with a hammer (glued closed) as it was just a dumb circuit board so really no way to figure out wtf happened in there, although I can't really think of a worse place to stick electronic sensors due to risk of getting wet through the carpet on rainy or snowy days. Bought mine off ebay for $160. So I saved myself - Dealer diagnostics minimum: $100 Dealer parts: $640 Dealer labor - quoted 3 hours LOLZ (literally will take you 30 mins or less now that you know where it is): 3x$140/hr = $420 Dealer shop supplies shake down fee: Maybe $40 TOTAL DEALERSHIP RIP OFF would have been $1200+tax! Dam I deserve a beer. |
09-20-2014, 03:49 PM | #20 | |
63926
Rep 24,824
Good to hear about the solution
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
01-05-2016, 12:57 PM | #22 |
Relatively New
25
Rep 67
Drives: BMW F36 435i Gran Coupe
Here's Hoping!
Just ordered that part online today. I'm praying that its going to be the resolution to my issue that sounds identical to yours. If not.. its a waste of money but at least I tried.
Thanks for the great description of your resolution! |
