08-12-2011, 04:49 PM | #1 |
79
Rep 1,421
1M & Sirius Radio
Do any of you have Sirius radio on your 1M? Mine has H/K radio with no sat/nav. The dealer has my car right now and is having problems adding the feature. Yesterday they thought they needed to replace the radio and after trying that it still wouldn't take the flash. I have a 335 for a few days. Boy, does it feel slow in comparison to the 1M! Anyway, from what I gathered BMW made it so their cars do not come with Sirius activated so the dealerships do it after the sale. Thanks in advance!
Dan Parker
08-12-2011, 04:54 PM | #2 |
252
Rep 513
I have the HK and all it took was the dealer to activate it which they did right before delivery. Mine has sat nav but not sure if that matters. You think the 335 is slow, try the 328 my dealer gave me!
08-12-2011, 06:08 PM | #4 |
La Flama Blanca
27
Rep 1,545
The 1M comes pre-wired for Sirius. You just need to add the sat radio module and have it activated. Same head unit.
AMS, Berk Technology, aFe, ER
08-12-2011, 06:33 PM | #6 |
37
Rep 381
I have the H/K radio with Sirius but no sat/nav. It too was activated before delivery but my CA has done this numerous times. Maybe it's user error on your dealer's part?
Speaking of the 335, I traded in a modded one with the Dinan Stage II engine tune, LSD and M3 suspension bits. It was fast but no where near the car that the 1M is. I don't miss it a bit. |
08-12-2011, 06:40 PM | #7 |
30
Rep 86
Hello all,
The Satellite radio is built into the head unit..Did you order Sat radio from the factory or are you having it enabled at the dealer? there are no seperate parts for this to happen..parts dept just order a enabling code and then technicians just hook up to a programming session and perform the retrofit. If you have selected sat radio when you ordered, it's something you can do at home , the ESN# to your radio is in Sirius database and you'll get your 1 year free when you call it in (or do thru sirius website) hope this helps Ray |
08-12-2011, 06:40 PM | #8 |
Rep 71
I have H/K with both sat/nav and the CA set it up in the lot before I drove off. No issues here but he did mention that they had been having some problems with Sirius activiations - not for technical reasons, but because some Sirius reps didn't seem to know or accept that new BMW sirius comes with a free year of service.
08-12-2011, 06:45 PM | #9 |
79
Rep 1,421
They seem competent to me. I thought I remembered hearing about someone having problems with theirs but maybe I'm wrong. My bad luck I suppose.
Oh, and I bet no one here had a baby blue with beige interior 335. So pimp!
Dan Parker
08-12-2011, 06:49 PM | #10 |
79
Rep 1,421
Ray,
I didn't order it with the car because the dealer told me I couldn't and they would activate it when I got the car. I forgot all about it until recently and now they are having problems programming it to add the feature to the radio. I'm told it adds it to the list of options when you press audio.
Dan Parker
08-12-2011, 07:16 PM | #11 |
292
Rep 2,898
Dan -
I ordered it as an option. United BMW activated it -- or tried to -- when I was doing paperwork inside, but I realized on drive into Smokies that it wasn't working. Called Sirius/XM and they sent another activation signal that worked. Learned that cars needs to be on and within reach of signal (i.e., not underneath an overhang or in undergound garage), neither of which was the case when United arranged for the initial, unsuccessful activation. Give me a call or pm if that is unclear. Neil |
08-12-2011, 09:02 PM | #13 | |
Rep 20
Dan I wish you all the best in getting this sorted out. |
08-12-2011, 09:04 PM | #14 | |
30
Rep 86
If Sat radio is not displayed, sirius/XM cannot activate the radio. My wife's 2011 Z4 was equipped with the sat radio and I activated it here at home like Neil did. Dan ,I hope they don't charge you more than the $350 for this..It has always been available on the 1M from the start of production. |
08-12-2011, 10:12 PM | #15 |
Rep 238
Is the Sirius system available after purchase only for the HK or is it built into the standard audio system as well?
I didn't order the HK audio and initially decided against Sirius but had it on my 135 and enjoyed it on long trips, so decided to add it. Unfortunately I was a couple of days too late as the order had entered 150 production status and the configuration had been frozen. No big thing, but I'm wondering if I can add it once it arrives (production is scheduled to be completed in 5 days). Thanks. |
08-13-2011, 06:20 AM | #18 | |
30
Rep 86
"655" is pretty much turn key and all you need to do is activate the radio with a simple phone call or internet connection and your up and running in less than an hour (mine took 15 minutes) ..nice thing about "655" , there's no labor time to install .. purchasing sat radio with "693" on the 2010 and newer cars still costs $350 for the enabler code and then need to pay the tech his time to retrofit and code the vehicle,could reach in the $500 neighborhood depending on the dealer. This is why I told Dan he shouldn't pay more than what the option cost because he was told he couldn't order it at the time (not sure why though). |
08-15-2011, 10:07 AM | #21 |
262
Rep 5,018
Drives: VALNCYA
loaded sat nav HK working for me
08-15-2011, 06:53 PM | #22 |
363
Rep 781
Drives: 2013 328i E92 LMB
Hopefully it works out for ya... any luck yet?
Just out of curiousity were you told you could not order it because it was too close to build date or did they just say no lol?
BMW CCA Member# 481791 Current: 2013 E92 328i LMB/Saddle Brown (1 of 21 for E92 LCI in that combo), 2018 F31 330xi AW/Saddle Brown Sold: 2011 1M BS/Black, 2008 E90 328xi AW/Beige, 2001 E46 330xi SG/Black |
