08-07-2011, 08:30 PM | #1 |
92
Rep 1,603
Drives: Imola Red Z4MC
5mm spacer + bolt question
Did a quick search but came up short,
If i buy 5mm spacers for my front will i need to buy extended bolts or will the OEM bolts work fine for 5mm?
///M - Some Mods 'N Stuff
08-07-2011, 09:21 PM | #2 |
11
Rep 331
I read somewhere that you need to be able to get 6.5 turns.
Depending on the wheel, you may or may not get 6.5 turns with the stock bolts. I think for OEM wheels, you'll need longer bolts (35mm shank) for your 5mm spacers.
08-07-2011, 09:32 PM | #3 |
27
Rep 341
You might want to think about hub extenders too. I needed them with my 5mm spacers to get the OE wheels centered properly.
http://www.turnermotorsport.com/p-21...ders-pair.aspx |
08-08-2011, 12:28 AM | #4 |
92
Rep 1,603
Will not be using stock wheels but the 6.5 turns theory is interesting,
Thanks for the help guys!
08-08-2011, 02:40 AM | #5 |
///M-fanatic
193
Rep 3,885
With 5mm spacers, you still have enough threading (with the use of OE lug bolt) to safely secure the wheel onto the hub. Usually it's 8mm (or thicker) spacers that require extended bolts.
08-08-2011, 11:52 AM | #6 | |
92
Rep 1,603
Have you personally done this?
08-08-2011, 04:44 PM | #7 |
M = Midlife Crisis
65
Rep 2,006
I have the longer bolts coming from Turner for 5mm spacers. Based on the HUB measurement on my car, extenders not required. The 12.5mm spacers + 265's are getting a slight bit of rub on the rears.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
08-08-2011, 07:35 PM | #8 |
///M-fanatic
193
Rep 3,885
I remember trying it out on my E46 325Ci back in the day, and I recall 8mm+ is when you need to start considering extended lug bolts for the extra threading.
I can't recall the exact spec, but in any case, usually the thicker spacers come with extended lug bolts when you buy them; or at least the vendor that sells you the spacers will ask if you're aware that you may need longer bolts, etc. |
08-10-2011, 09:18 AM | #9 |
11
Rep 331
Are you running 265/30/18 or 265/35/18 or 265/40/18?
08-10-2011, 08:03 PM | #10 |
M = Midlife Crisis
65
Rep 2,006
