08-05-2011, 11:58 AM | #1 |
213
Rep 1,395
Steering Problem: Going to be without my M3 for 10 days or more!
Currently, my car is being serviced for a steering issue, the first that I've heard of or seen on the forums, and the first my SA has seen as well. The issue has now been submitted to PUMA and BMW is involved. (See here and here for more details).
The repair is being done in phases. Phase I is to replace the lower joint and if that doesn't not fix the issue, Phase II will be to install a new steering rack. The problem here is that the lower joint part(s) don't arrive from Germany for another 7 days! I asked the dealer if I could have the car back in the interim, since that noise is something I've dealt with the whole time i've had the car, another week is no big deal. I was told the car cannot be released because it is disassembled and BMW is already monitoring this situation. #bummed Anyway, my concern is that: (1) the lower joint won't fix it, leading to more delays for the new steering rack; and (2) the car coming back with other serious problems, like vibration in the steering wheel etc. I have a video that I tried to make a while back, but it doesn't really capture the sound as well as it should - but I will still post it a bit later. Basically was making a loud crunching/knocking sounds while steering up to and beyond a full turn at low speeds. It always operated fine, but the sound had an associated bump in the steering feel, so I had to finally bite the bullet and have them look into this. If Phase I does not solve the problem, I will be demanding to have the car released after the lower joint is replaced, as I will not have it sit there for however long while I wait for the steering rack to arrive. Has anyone here had any steering problems? What is the chance that my Car comes back worse than it was? Any thoughts you guys have on this would be appreciated.
Club 6MT 2008 E92 M3 6MT, AW/Blk Ext., brushed aluminum 2006 E46 M3 ZCP 6MT Carbon blk/blk(sold) 2001 E46 325Xi 5MT Jet Blk/Blk (sold) |
08-05-2011, 02:40 PM | #2 |
213
Rep 1,395
anyone?
08-05-2011, 02:50 PM | #3 |
344
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
sometimes when i am trying to park the car in a tight space and i reverse while turning the steering all the way, then put into D to go forward again, and turn the wheel all the way in the opposite direction, i do feel some sort of jerk, bite, vibration...hard to describe...it turns fine..and doesnt make any sound...its just a slight feedback i get, i always attributed it to the tight turn and the wheels or something....is this your issue?
08-05-2011, 03:14 PM | #4 |
213
Rep 1,395
OK, this is the video. It sounds like what you're feeling, Rich, except it has a sound associated with it. Right at the beginning of the video at 1-3 seconds is when you can hear it. The rest of the noise is me shifting. The video might make it seem like a non-issue but it's a lot louder in person. Tech knew something was up right away.
08-05-2011, 04:22 PM | #5 |
4th down; 4th quarter? Renegade.
87
Rep 3,850
Did they at least give you a decent loaner? Hope it gets fixed soon. Waiting on parts from Germany is a pain. Good luck.
08-05-2011, 04:48 PM | #6 |
213
Rep 1,395
Thanks. Took back the red e90 for an E60 535i. This will do until I get mine.
08-05-2011, 04:55 PM | #7 |
Apex Everything!
976
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
If it makes you feel any better, my 2011 M3 is at the dealership for at least a month because the engine main bearings have gone bad. And I'm stuck in a dirty cashmere-colored 128i. It's been 2 days so far.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
08-07-2011, 08:17 AM | #8 |
Rep 39
I think i heard the same noise for every first full turn, but it seem to disappear after the car warmed up.
I never heard it when I did a parallel parking, only the first full turn in my parking lot. Yes, it sound like a pop from the front/engine bay. Can you tell us more on what is the problem and what to replace? E. |
08-08-2011, 12:29 AM | #9 |
258
Rep 5,012
Never heard of that problem OP. Don't have time to read the 2 threads you linked, but my first question is if the car has been in any kind of accident. If yes, the issue is a bad repair, not anything inherently wrong with the car. If not, did you buy the car new? Otherwise you can't really know, as carfax and such are not that reliable. If suspension is not damaged, dealer should be able to fix it properly. I'd also check alignment, and make sure the thrust angle is at 0.00. That's the first clue car does not have suspension damage. Good luck.
08-09-2011, 10:57 AM | #10 | |
22
Rep 151
08-09-2011, 11:05 AM | #11 | |||
213
Rep 1,395
Mine does not disappear after warm up, but I will be sure to let you know what's up, as you may be experiencing the early stages of something similar to my current problem.
08-10-2011, 06:25 PM | #12 |
213
Rep 1,395
WOOT WOOT! Dealership called, Lower Joint arrived and that fixed the problem! I get my car back today.
08-12-2011, 02:11 PM | #14 |
213
Rep 1,395
The lower joint was replaced. The steering feels how it should feel now. I will post a picture of the paper work, which will have more details. Look for that before the end of the weekend.
08-12-2011, 03:01 PM | #16 |
213
Rep 1,395
True. Anytime you're dealing with steering issues, it could lock up potentially.
08-12-2011, 08:59 PM | #17 |
BimmerPost Supporting Vendor
3387
Rep 7,542
I'm glad it's fixed - hopefully the problem doesn't reoccur. I had issues the first few months with my M3 with wheel bearings/rotors. They replaced the wheel bearings and rotors over four times before the noises were resolved. Aparently they had some manufacturing issues during the initial run (as my car is a 12/07 build, one of the first in the US).
On my E60 M5, BMW gave me two thousand dollars for a host of problems that I was inconvenienced for. I know it's hard being without your car, but it's always well worth the wait to make sure that everything is fixed properly.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
