08-03-2011, 02:43 PM | #1 |
292
Rep 2,898
Diff Fluid - Changed at 1,200 miles?
Does anyone know whether the diff fluid is changed or simply topped off at the 1,200 mile service?
My dealer is advising me that is only topped off. Thanks. Neil |
08-03-2011, 02:52 PM | #3 |
292
Rep 2,898
Tranny oil - currently unobtanium by US dealers -- is no longer changed at 1,200 mile service. Subject of separate thread which has reprint of BMWNA's technical service bulletin on this issue.
But I'm really looking for info on differential. Thanks. Neil |
08-03-2011, 02:52 PM | #4 |
79
Rep 1,421
I would demand it be changed. It's an M car!
Diffs are expensive and diff fluid is cheap. It's standard practice to change it and this is the first I've ever heard of "topping it off." Diffs don't typically use fluid and require a "top off."
Dan Parker
08-03-2011, 03:12 PM | #5 |
European Editor
10589
Rep 22,992
The diff fluid should be changed at 1,200 mile service. IF your dealer is that inep, just do it yourself.
I would also make sure they do an engine oil change with the BMW Castrol oil (5w30, The N54/N55 engine oil) and make sure they don't use the M (Castrol TWS) motor oil! Manual trans fluid should be changed but BMW is apperently not doing it now bc they hvae very little of the correct oil on hand (MTF-LT-5). Someone posted you can use Pentison trans oil sold thru Porsche dealer - since it is the very same oil. Dackel |
08-03-2011, 03:23 PM | #6 | |
292
Rep 2,898
Thanks. Just got off phone for second time with dealer and they have now changed the diff fluid. They did use BMW Castrol 5w30 for motor. Feeling relieved since I'm heading to track this weekend. Neil |
08-03-2011, 03:36 PM | #9 |
European Editor
10589
Rep 22,992
08-03-2011, 03:41 PM | #10 |
Rep 196
My car is in dealership as we speak for 1st service ,engine oil/filter ,gearbox oil and diff oil change and some warranty work to be done
harmon kardon ,performance steering wheel,rear spoiler,black grills ,viz pack,heated seats ,sun protection
08-03-2011, 03:41 PM | #11 |
115
Rep 1,998
The modifier is for only a diff that is chattering on tight turns.. adding it is not automatic.
It does work BTW .....once the diff chatters, if at all... has a lot to do with driving style..
X1, R58 JCW, M2 in my future if planets align
08-03-2011, 03:45 PM | #12 |
57
Rep 820
thanks for clearing this up. thought it was an automatic add-on with the diff fluid.
08-03-2011, 04:00 PM | #13 |
26
Rep 672
mine did and it was real bad. i had my 1300 mile service done and shortly after the diff was so loud it was starting to make me nervous. the diff had been silent since i picked up the car and only after the service did it get loud. I took it back, they added the fluid and now it was back to like it was on day 1. not adding the modifier to the diff will not ruin the diff but since bmw will do this free of charge i would ask them to do so anyways as i spent a day at the dealer that i rather have spent at the beach.
08-03-2011, 04:01 PM | #14 | |
La Flama Blanca
27
Rep 1,545
"All 1 Series M Coupe vehicles and only M3 vehicles with the optional M- DCT Drivelogic transmission have a long-term rated transmission fluid which does not need to be changed except for system repairs." (Page 6) |
08-03-2011, 04:02 PM | #15 |
26
Rep 672
while driving it was fine. I park my car in a 3 story parking garage and when driving slow making sharp right hand turns to go up the levels the sound was bad. Other than that, under normal driving conditions it was fine.
08-03-2011, 04:08 PM | #16 | |
European Editor
10589
Rep 22,992
Yes, most LSD's will make some chatter noises when pulling a U-turn or tight turns. That doesn't mean the LSD unit is bad or anything. Just that it is working. The LSD friction additive is there to quiet the LSD of this chatter noise. I would rather hear that noise than not. |
08-03-2011, 04:50 PM | #17 | |
115
Rep 1,998
M3 diffs have been changed in the past, but not really decause of the low speed chatter... Now if you get noise / vibration / chatter at High speed in a nice sweet sweeper.....well now you have issues If it were me, i would leave the modifier out as long as i could.. just my .02
08-03-2011, 07:07 PM | #18 | |
26
Rep 672
08-03-2011, 11:18 PM | #19 | |
103
Rep 1,417
I searched but couldn't find it. Thanks
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles |
08-04-2011, 04:22 AM | #20 | ||
European Editor
10589
Rep 22,992
You can thank "DriveHard" for his post#73... TSB SI B00 01 10 http://www.1addicts.com/forums/showt...TF-LT-5&page=4 Here is his post... Quote:
PS: you might want to read thru that entire thread... it is VERY interesting. Dackel |
