BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      07-28-2011, 12:20 PM   #1
M3DCTBT
34
Drives: E92 M3
19x9.5 front wheel + 265/35/19 or 275/30/19 Hankook?
Current tire is 265/30/19 Hankook EVO and it is not enough tire.....
      07-28-2011, 12:37 PM   #2
Dave07997S
730
Drives: 2020 Ford Mustang GT
265/35/19 could be to tall, go with the 275/30/19.
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk
2007 Porsche 997C2S Speed Yellow/Blk sport seats
2004 BMW M3 Imola/Blk
      07-28-2011, 12:39 PM   #3
Martin_D
Martin_D's Avatar
102
Drives: Ford Super Duty
Try a different tire, both are available in the size you listed.
Yokohama Advan AD08
Michelin Pilot Super Sport
      07-28-2011, 01:17 PM   #4
M3DCTBT
34
Drives: E92 M3
Yokohama Advan AD08
I have pilot SS on my track wheels.
These are my street wheels and i need a stretchy for looks sidewall. I know I'm lame
-Bren
      07-28-2011, 01:26 PM   #5
persian54
persian54's Avatar
924
Drives: M760/G83M4
275/30
265/35 shouldn't clear
You can also try Toyo T1Rs.
not optimal for performance but they have the stretchy look
      07-28-2011, 01:38 PM   #6
M3DCTBT
34
Drives: E92 M3
front tire looks like a rubber band.
      07-29-2011, 01:01 AM   #7
bunnn
bunnn's Avatar
86
Drives: like a grandma
That is a pretty bad angle, not to mention without tire spec it means nothing.
My 275/30/19 AD08 on 19x9.5 doesn't look rubber band at all
Cheers
Ben
      07-29-2011, 01:59 PM   #8
persian54
persian54's Avatar
924
Drives: M760/G83M4
ad08s are much meatier tires than V12s
      07-29-2011, 02:39 PM   #9
nerweezyTA
Drives: 2011 e92 M3
Im running V12s, 19x9.5 front with 275/30/19 as well
      07-29-2011, 02:42 PM   #10
STALKER
169
Drives: 997.2 GT3, Golf R
You need to take into account camber, ride height and wheel offset also.
      07-29-2011, 03:37 PM   #11
roy@acuteperformance
roy@acuteperformance's Avatar
21
Drives: 2015 AW M4 6MT
Give us more specifics on your setup. Ride height, suspension, camber, wheel specs.
      07-31-2011, 09:22 PM   #12
M3DCTBT
34
Drives: E92 M3
-2.0 height all the way around
-2.2 camber front
-2.0 rear
265/30/19 has TONS OF ROOM
19x9.5 +18. I've run it with a +12 with 5mm spacer too without rubbing
      08-01-2011, 01:34 AM   #13
persian54
persian54's Avatar
924
Drives: M760/G83M4
275/30 than in your case
but a V12 isn't a meaty tire
Maybe get some meaty R Comps :P
then you'll want a smaller sized tire
      08-01-2011, 08:50 AM   #14
M3DCTBT
34
Drives: E92 M3
Again the Work Brombachers are my street wheels this is for looks not performance.
The Michelin SS's are on my track wheels.
      08-29-2011, 09:41 AM   #15
M3DCTBT
34
Drives: E92 M3
did it 275/30/19 is PERFECT on 19x9.5
      12-02-2012, 11:39 PM   #16
BIU
22
Drives: M
Did you go with the 275/30 V12s?
Any pics?
I take it you went 275/30 with the +18 offset and not the +13 (W/ 5mm spacer) offset correct?
Thanks!
      12-03-2012, 08:18 PM   #17
M3DCTBT
34
Drives: E92 M3
I am 19x10 +25 in the front now - 275/30 no rub
      12-03-2012, 09:02 PM   #18
BIU
22
Drives: M
Thanks for taking the time to respond to my revival of this old thread
Are you dropped with less than a 1.5 finger gap for the fronts and what camber specs are you running?
The 19x10 ET25 is 1 mm inwards from your previous 19x9.5 ET18 setup.. Since I see that you went with the same 275/30 tires I assume you have made the switch solely for a larger lip and/or greater concavity? (Less inner clearance and greater unsprung weight)
Would you have any pics of the current fronts? I would love to see the flushness with the offset and Hankook 275/30s
      12-04-2012, 09:17 AM   #19
M3DCTBT
34
Drives: E92 M3
After 3 months of fussing to get it right im not releasing all my secrets. I went a bit wider with the wheel overall and got rid of the spacer. It is actually ET+20 my fault. Hardest part now is starting all over with sticky RS3s to put the ESS blower power down
      12-04-2012, 09:56 AM   #20
GewoW
#thatsanicemovebro
GewoW's Avatar
Greece
202
Drives: E92 M3 LSB/Black 6MT
2011 BMW M3  [9.34]
35 will rub
      12-04-2012, 10:00 AM   #21
M3DCTBT
34
Drives: E92 M3
Originally Posted by GewoW View Post
35 will rub
30 looks like a rubber band, wish i went 35.
      12-04-2012, 10:27 AM   #22
GewoW
#thatsanicemovebro
GewoW's Avatar
Greece
202
2011 BMW M3  [9.34]
switch to 18s
m3post
