07-04-2011, 11:00 PM | #1 |
381
Rep 2,926
Drives: Cayman GT4, 135i
DYNO: 135i with Procede V5
Runs were done in 92 degree weather.
Mods: Procede V5 Dual cone Intakes Fabspeed Catless Downipes HPF Intercooler 100 Octane Pretty Pleased with 100whp and 100wtq delta.
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
07-05-2011, 03:47 AM | #3 | |
realitydesign.com
14
Rep 205
As for the OP, those are some solid numbers on 14 PSI. Congrats If you don't mind, can I ask why you only targeted 14 PSI if you were running 100 octane? Seems like you could have seen another 30whp easy by just upping the boost another 2 PSI .
2008 135i MT - JB4 15ohm, Map 3
CM VC2 2.7gal Meth Kit | CP-e Downpipes | BMW Performance Exhaust | BMS DCI | Stett CP & Forge DV's | ETS FMIC | 3.46 Quaife LSD | KW V2 Coilovers | Breyton GTS-R's | Dunlop Z1 Starspecs | Complete BMW Performance Exterior & Interior |
07-05-2011, 07:37 AM | #4 | |
55
Rep 944
07-05-2011, 08:08 AM | #5 | ||
381
Rep 2,926
Odd thing is that my other friend came who has the same mods and 100 octane and was hittin 14psi A's well. Makes me believe it was either the temps in that room or the Procede targeting.
Current: M2CS
07-05-2011, 09:32 AM | #6 |
356
Rep 2,080
Note... this is w/ SAE correction. Some people post logs with STD correction which will make the #'s higher than the OPs...
I was the friend who also dyno'd - exact same mods basically.... Procede V5 (same 5/25 maps as OP) ETS FMIC Macht Schnell CL DPs Maddad Whisper BMS DCI 2008 135i, with latest software update from 6/1... OP has a 2010.... |
07-05-2011, 06:14 PM | #7 | |
realitydesign.com
14
Rep 205
I wasn't really concerned with the number though, as even for STD they looked quite nice for only 14 PSI, even better considering it's SAE.
07-07-2011, 08:34 PM | #8 | |
356
Rep 2,080
And yess, less than 10whp as suggest above. You were spot on.... |
07-07-2011, 10:20 PM | #10 |
356
Rep 2,080
Because I've dyno'd with 93 several times before, #1. And #2, if I run at the track, I will run with 100 octane, so I'd like to know how my track times compare with the power #'s I am putting out....
07-07-2011, 11:12 PM | #11 | |
381
Rep 2,926
In all seriousness I was trying to do a glory run to hit 400 hp / 400 tq
Current: M2CS
07-08-2011, 09:16 AM | #12 |
356
Rep 2,080
07-08-2011, 03:29 PM | #13 |
381
Rep 2,926
8 Horsepower = nothing on the street or track. Stop gloating over minor things .
Current: M2CS
07-09-2011, 10:51 AM | #14 |
356
Rep 2,080
Winning is winning. Crack 12.5's at the track w FBO and LSD and we'll talk....
07-09-2011, 04:05 PM | #15 |
381
Rep 2,926
Hit 12.7 last time. Watch yourself
Current: M2CS
07-11-2011, 09:39 PM | #16 |
356
Rep 2,080
07-12-2011, 01:32 AM | #17 |
Bashar
416
Rep 1,121
07-12-2011, 09:20 AM | #18 |
356
Rep 2,080
