KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
04-08-2007, 10:39 AM | #1 |
18
Rep 220
official tyre size?
Does any body know the offical F/F tyre dimensions for the E92 M3? Interested to know for 18/19.
360mm front brake disc is impressive but single piston caliper again? :mad: |
04-08-2007, 10:55 AM | #2 |
Rep 188
I´ve read that they are 245/40 & 265/40 on 18". As you can see, the wider rears have the same aspect ratio as the fronts (40), making those taller overall. This situation is very common on Ferraris, Lamborghinis, etc, but new to BMW (which always had lower aspect ratios for the wider rears).
I do not know the tire sizes for 19". The Geneva concept had Michelin Pilot Cup tires from the E46 CSL in 235/35 & 265/30, but I guess that the production version of the E92 will have even wider tires (maybe 245/35 & 265/35).
'10 E90 325i LCI Space Grey l Step w/paddles l iDrive Pro Navi
'07 E92 335i Space Grey l Grey Poplar l Saddle Brown l Anthrazit Headliner l Active Steering l BT l Step l LC LM l Eibach l Aero Front Lip l M3 Rear Spoiler l Performance Steering Wheel w/Paddles '97 E39 540i Aspensilver l 6 MT l EDC dampers + Eibach l Xenon l Comfort seats l TV |
04-08-2007, 11:04 AM | #3 | |
1568
Rep 29,202
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
04-08-2007, 05:54 PM | #4 |
611
Rep 10,407
Perhaps
04-08-2007, 06:27 PM | #5 |
Commander-In-Chief
2122
Rep 8,924
Drives: 2023 M2 Coupe, 2020 GLE 450
Tire sizes
Per the German price list, the stock wheels are 8.5/9.5 x 18 w/ 245/40 & 265/40 ZR tires. The optional 19s are same width but with 35-series tires, of course.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
04-08-2007, 06:33 PM | #6 |
15
Rep 119
On the (red) one, on which the official photos and videos were made, there are 245/40 18 on both front and back. But I'm sure it won't be like this on the production vehicles.
04-08-2007, 06:45 PM | #7 |
Commander-In-Chief
2122
Rep 8,924
No, the rears on that car are definitely larger than the fronts. No way they they would showcase a square setup on the M3.
04-08-2007, 10:41 PM | #9 |
18
Rep 220
04-08-2007, 11:53 PM | #10 | |
611
Rep 10,407
Brakes
04-09-2007, 01:03 PM | #11 | |
11
Rep 146
It is better if they have 245/40 front and 265/35 rear or 275/35 rear. |
04-09-2007, 01:15 PM | #12 | |
Rep 188
Regarding DTC, ABS, etc, they all work based on a signal from the wheel rotation sensors, which is then processed by the corresponding electronic module. By applying a correction algorithm, the information from the rear wheels can be easily adjusted by the BMW engineers.
04-09-2007, 02:21 PM | #13 | |
11
Rep 146
I think 275/35 or more still fit under rear fender. THis is the first M to have rear tire with taller diameter than the front. |
04-09-2007, 02:38 PM | #14 | |
Rep 188
I believe this is the first BMW (not only M) to have taller rear wheels. Porsche is also starting to use taller rear wheels now. Until the 996, they had almost identical diameters for front and rear wheels, but since the 997, they are using taller rears. For example the 997 has 235/40 18 up front and 265/40 18 on the rear, while the 993 had 225/40 18 and 265/35 18.
04-09-2007, 05:55 PM | #15 | |
11
Rep 146
I notice NSX, G35, 350Z, IS350 all have taller diameter rear tire besides Ferrari, Lambo, etc. |
04-09-2007, 05:59 PM | #16 | |
11
Rep 146
Is there any benefit of having smaller diamater tire at front axle? |
04-09-2007, 07:32 PM | #17 | |
Rep 188
Better steering feedback due to lower unsprung weight.
04-09-2007, 09:04 PM | #18 |
Rep 167
18" or 19" which is better?
The videos of the red ///M3 going around country roads appears to have 18" wheels, not 19". While I feel 19" will give the M a better and more aggressive look, will it affect ride comfort even with the 40-aspect ratio tyre at the rear?
04-09-2007, 09:25 PM | #19 |
Commander-In-Chief
2122
Rep 8,924
Ride comfort with 19s
Certainly it would have a minor effect. However, I went from 18s to 19s on my E46 and barely noticed the difference. The 40-series tires will have about the same sidewall as 45s on the E46. Should be fine.
04-10-2007, 10:02 AM | #21 |
18
Rep 220
I think 265 with 35 aspecct ratio (19inch) should affect the ride quality that much. My Box is using 265 40 18inch in the back and that's pretty cushy.
