06-26-2011, 08:52 PM | #1 |
57
Rep 315
Another ....somewhat Noob question
Can someone explain what all of these metrics mean on that the COBB AP measures? And what normal levels of each should be for our cars?
Any additional info would be great too like: What mods impact which metrics, what is physically going on in the engine with respect to each metric, etc... Here is the list (some are obvious): Battery Volt - (obvious) Vehicle Speed - (obvious) RPM - (obvious) Air Fuel Ratio - (obvious meaning, but what is the implication for our car/mods/whats normal?) MAF - ? Load Act. - ?? TPS Act. - ?? TPS Req. - ?? Baro Pressure - (obvious..i think?) MAP - ?? Req. Boost Abs. - ?? Boost Abs. - ?? WGDC - ?? Timing CA -?? (whats normal?) ECT - ?? Oil Temp. - (obvious) Amb. Temp - (obvious) Intake Mani. Temp. (obvious) I think without meth or FMIC normal is like 110 +/- 3-5 deg Boost - (obvious) TIA... ~V |
06-26-2011, 11:28 PM | #2 |
Indian Stig
29
Rep 1,002
Drives: '03 540i M, '11 Ducati M796
I'd love for the more well-versed to chime in here as I'm also curious about a number of these things. I'll share what I know for now...
MAF - mass air flow (usually in grams/second) Load actual - a measure of MAF over engine speed TPS - throttle position sensor, actual and requested MAP - mass air pressure, similar to MAF WGDC - waste gate duty cycle Timing CA - timing correction advance? One of the important parameters for determining engine preignition and detonation (knock) ECT - engine coolant temp.
2008 E82 N54 || Stage 2 -------- Gone to a good home. Last edited by Kamal; 06-27-2011 at 12:16 AM.. |
06-27-2011, 10:30 AM | #3 | |
i miss boost
35
Rep 402
I'll try to add my two cents on top of Kamals, please correct me if I'm blatantly wrong, I'm still learning every day...
2009 Mercedes C63 AMG
2008 135i (Sold) |
06-27-2011, 11:06 AM | #4 | |
57
Rep 315
Arent we all... lol... PS: DAAYYUM Thats gonna take me a while to read over. Thanks for putting in the time and energy to answer this man.. ~V |
06-27-2011, 11:08 AM | #5 |
i miss boost
35
Rep 402
Hahaha, im trying to put in the time to understand everything ahead of ATR coming out!
Hope this helps!
2008 135i (Sold) |
06-27-2011, 12:26 PM | #6 | |
Indian Stig
29
Rep 1,002
Same here... I've posted on the Cobb tuning forums multiple times to get them to provide us with some insight into what we should be looking for when looking at data logs to no avail. I'm guessing they'll release a technical article when the ATR software comes out... also, is the ATR program free?
2008 E82 N54 || Stage 2 -------- Gone to a good home. |
06-27-2011, 01:03 PM | #7 |
i miss boost
35
Rep 402
I'm sure ATR will be free if you look at the other platforms like mazda and subaru as comparisons. I've seen it connected to my car, it will allow us to do way more than any one of us is capable of doing without a dyno, a bit of spare time, and a lot of knowledge.
I'll try to dig a bit on the Timing CA stuff, I know there is a lot of power to be had with this car playing around with the timing. This motor and ecu allows you to tune cylinder by cylinder as well which is pretty slick!
2008 135i (Sold) |
06-27-2011, 01:50 PM | #8 |
154
Rep 4,528
Drives: M2 CS
I'm not sure if the N54 is diff than other boosted platforms but 12-14.7 AFR is not where is supposed to be
the magic number is 11.4, anything around that is safe. anything under 11 is considered rich and anything approaching 13s is considered dangerous, at full load that is those stock AFR number from cobb look high but also depends where they put the sniffer |
06-27-2011, 02:40 PM | #9 | |
Indian Stig
29
Rep 1,002
06-27-2011, 04:20 PM | #10 |
realitydesign.com
14
Rep 205
It is quite different. The N54 is direct injected, which is exactly why it can run those AFR's and get away with it. The entire point of direct injection is MUCH better control of the explosion in the cylinder, allowing for what was once "dangerously" lean AFR's without major risk of knock/detonation.
2008 135i MT - JB4 15ohm, Map 3
CM VC2 2.7gal Meth Kit | CP-e Downpipes | BMW Performance Exhaust | BMS DCI | Stett CP & Forge DV's | ETS FMIC | 3.46 Quaife LSD | KW V2 Coilovers | Breyton GTS-R's | Dunlop Z1 Starspecs | Complete BMW Performance Exterior & Interior |
06-27-2011, 08:22 PM | #11 | |
Indian Stig
29
Rep 1,002
copying this from the Cobb AP discussion thread so it's all in one easy to access thread...
06-28-2011, 07:16 AM | #12 | |
154
Rep 4,528
Drives: M2 CS
08-12-2011, 12:42 AM | #13 |
37
Rep 193
So reading the two boost level for stage 1, 28-32 is normal....?
2009 BSM with Coral Red interior 135i: ///M-Sport Package // 20% tints //Cobb Protune by ProTuning Freaks// Carbon Fiber trunk lip spoiler // ADV.1 adv10 trakfunctions// H&R front and rear sway bars // Injen dual cone// CP-e full catback exhaust// AR catless downpipes // HPF FMIC // Quaife LSD // LUX Angel Eyes // Eibach Pro-Street S
08-12-2011, 10:09 AM | #14 |
42
Rep 596
This range seems normal for the Req. Boost Abs and Boost Abs parameters on the 93 octane Stage 1 maps. There is actually a separate Boost (PSI) parameter you can enable in the data logs (if you haven't already) which will show you the actual Boost read at the TMAP, pre throttle body. Generally this in the range of 12 - 16 with the Stage I OTS maps and depend on the octane level of the map and conditions. This is most likely the parameter you are looking for.
08-12-2011, 10:22 AM | #15 |
Resident Kerbalnaut
477
Rep 10,703
Don't mean to thread jack.
But I'm trying buy gauges and I can't find these numbers. Nominal N54 oil Pressure? Nominal EGT? Nominal Fuel pressure? Crankcase Pressure? Etc. |
08-12-2011, 11:34 PM | #16 | |
37
Rep 193
08-13-2011, 12:37 AM | #17 |
Indian Stig
29
Rep 1,002
COBB AP New Monitor Descriptions....
