06-24-2011, 03:32 PM | #1 | |
Joint Chiefs of Staff
4918
Rep 115,980
Dual cone intake and WW meth kit dyno testing
Just saw the results posted and thought I'd share them over here. There has been a lot of speculation on the dual cone intake performance as well as how the WW meth kit might do on a completely stock car. These dyno charts answer some of those questions.
06-24-2011, 07:56 PM | #3 |
915
Rep 3,456
Drives: Harrop E90 M3
Close the hood on those dcis and watch what happens....
06-24-2011, 09:57 PM | #5 |
realitydesign.com
14
Rep 205
Drive the car with the hood closed and see what happens...you get the gains you see in the dyno sheet.
Why the hell would you close the hood on a car when it's standing still and run it on the dyno? I don't know about you, but my car doesn't make 400whp+ standing still at the stoplight, it makes it going 60+mph with air flowing in to my engine bay.
2008 135i MT - JB4 15ohm, Map 3
CM VC2 2.7gal Meth Kit | CP-e Downpipes | BMW Performance Exhaust | BMS DCI | Stett CP & Forge DV's | ETS FMIC | 3.46 Quaife LSD | KW V2 Coilovers | Breyton GTS-R's | Dunlop Z1 Starspecs | Complete BMW Performance Exterior & Interior |
06-25-2011, 03:22 AM | #6 |
915
Rep 3,456
How much cold air is there in the engine bay? Oh, none. At road speed heated air across the radiator along with engine block heat creates a nice power loss for those with dcis. Hot air = power loss, period. Dynos are too easy to manipulate...just as easy to pull the stock airbox lid off on the dyno and show a 10 hp increase, same as a dci on a dyno power wise. Remove the "restriction" as vendors call it
06-25-2011, 02:50 PM | #7 | |
realitydesign.com
14
Rep 205
Do the DCI's suck in hotter air than a stock airbox? Yes. Is there absolutely no cold air going in to your engine bay at speed like you're suggesting? No. There's actually quite a bit. Though, quite frankly, with meth none of that matters anyway.
06-27-2011, 12:44 AM | #8 |
18
Rep 462
There are numerous posts in the E90 section about the downside of DCIs. Recorded IATs 10-15F higher than with stock box. Sure they'll flow better than the stock box and in certain scenarios provide hp gains. I'd also agree that if you're running meth, the weakness of the DCIs is primarily negated.
The best solution to improve performance (from an intake) is both higher flow (less restriction) and colder air. There are numerous test results and tales of traffic heatsoak running DCIs in the e90 section. Does all of this mean that DCIs don't provide gains? No, its just that they arn't always going to give you the best performance. There is a growing trend of owners building Mr. 5 like CAIs (Basically a DIY of the approach taken by the Dinan intake) All the results appear promising on this approach AND good news is that you can use ONE of your DCI filters to make one I've got nothing against DCIs and would have no issues running them myself if I was also running Meth, just wanted to share some addition rational for why DCIs have gone out of favor by a number of folks. |
06-27-2011, 05:51 AM | #9 | |
4918
Rep 115,980
Mike |
06-27-2011, 06:01 AM | #10 |
247
Rep 1,827
If I was using meth, I'd sport a dci. On the dyno, it does show the dci breathing better at high rpms which also correlates to drag strip results. However, for simple daily driving, the stock box seems to perform the best for me in these hot Florida summer temps with few bolt ons (tune, fmic, dps). I don't know what it is, but that is just me. I don't spend much of my time in high rpms daily driving so that could be a reason.
06-27-2011, 02:36 PM | #11 | |
18
Rep 462
A better test would be to log IATs through a 3 gear pull making sure ambient temps are the same and starting oil temps are the same with each setup. The idle test suggested won't really prove the comparision of inlet temps at intake becasue the FMIC (not being anywhere near its soak limit) will cool down the intake air prior to the IAT measurement. The the multi-gear pulll, if intake temps are greater, you'd expect the FMIC to soak sooner thus resulting in higher recorded IATs. I'm sure there are other valid ways to test as well... |
06-27-2011, 04:11 PM | #12 |
realitydesign.com
14
Rep 205
Can I ask a stupid question? Are you guys sitting in rush hour traffic in 100 degree summer days and then doing quarter mile pulls? I don't understand why heat soak in traffic matters at all. Who cares if you lose 5-10whp in stop and go traffic? That is the entire downside of the DCI, and what everyone complains about.
Maybe it's just me, but I tend to drive fast on OPEN roads where my car is actually MOVING, not idling for 15 minutes in my garage or sitting in traffic on the 405. That said, the Mr. 5 intake is great, and if you don't mind mangling your stock airbox go for it.
06-27-2011, 07:46 PM | #13 | |
18
Rep 462
Its also not just about loosing 5-10hp coming out of a stop, but more about edging yourself closer to heatsoak of your FMIC toward the end of a pull. Cooler start means prolonging hitting the point of timing being pulled. If your someone who likes what you get out of the DCI, go for it and enjoy. There is no hate for you from me. Just remember that the open debates on these forums to bring independent test results about products is a gift that you can choose to use or not. I have a set of DCIs I just bought with intensions of using them for my Mr. 5 intake, but decided to go with a bigger single cone instead so maybe I'll run some comparision tests (via logs) in a few weeks to add to the independent data collection on this subject... |
06-28-2011, 05:22 PM | #14 |
41
Rep 468
Here is a little testing I did with DCIs vs. a stock air box. Hood closed with 136k CFM fan blowing on the car with fresh air being pulled from outside the building. Ambient temps where in the high 90s iirc. Keep in mind we don't sell DCIs nor do we plan to, this was simply a test based on customer request.
http://blogs.cobbtuning.com/2011/06/...ir-box-vs-dci/ There might be a limitation when the hood is closed. Unfortunately I didn't test the DCIs with the hood open. IIRC the Evo IX has a similar issue where cone based intake does not make more power given the issue has to do with getting fresh air to the intake itself. They found modifying the stock air box to pull air from the fender made the most gains and with fresh ambient air. Cheers, Rob |
06-28-2011, 05:27 PM | #15 | |
41
Rep 468
Cheers, Rob |
