      06-23-2011, 10:08 PM   #1
Itsquick
Itsquick's Avatar
Drives: 2011 135i SGM / Black
2011 135i  [6.00]
1971 280SL  [0.00]
2008 M5  [0.00]
2011 N55 OCC installed
Completed the install of 42nd Draft Design OCC.
All parts came from 42nd Draft Designs except the PCV tubes, they are BMW
original parts.
I have only 518 miles on the car, so I hope this helps keep the intake track and valves some what clean!
Some more info is in my album.
      06-24-2011, 01:41 AM   #2
KcN55
KcN55's Avatar
30
Drives: Black 135
ohhh sweeettt they have occ for n55?
[Work Meister s1][KW V2][Icarbon rear diffuser][1M style] [BMW perf spoiler][eye lids] [Lux angel eyes][Rpi red scoops][MHD Stage 2][CPE dp][CPE CP][VSRF 7''][Injen intake][matte grills][Alpine speakers][P3 Vent Gauge][Custom Alcatraz steering wheel][ARK Cat-back exhaust]]
      06-24-2011, 07:53 AM   #3
bogart
bogart's Avatar
117
Drives: E82 N55 DCT
2011 BMW 135i  [7.06]
Awesome man!!! I've been looking for one of these.
Did you buy everything online??? If so can you post links to all the parts?
      06-24-2011, 08:20 AM   #4
Focusedintntions
105
Drives: 2011 135i M-Sport :D
+1 for links to the parts
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
      06-24-2011, 08:50 AM   #5
Itsquick
Itsquick's Avatar
2011 135i  [6.00]
1971 280SL  [0.00]
2008 M5  [0.00]
Everything except the mounting bracket you can purchase.
I will get the list of parts and vendors along with the template
I made for the bracket, posted later today.
It is about a two hour job, maybe less if it wasn't 101 degrees in my garage!
      06-24-2011, 06:41 PM   #6
markt_sa
Drives: 2011 135 m pack dct
Strange question
What is OCC??
      06-24-2011, 07:01 PM   #7
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Originally Posted by markt_sa View Post
Strange question
What is OCC??
OCC = Oil Catch Can
      06-24-2011, 09:26 PM   #8
Itsquick
Itsquick's Avatar
2011 135i  [6.00]
1971 280SL  [0.00]
2008 M5  [0.00]
Parts list for OCC mod.
Vendor: 42draftdesigns.com
3/4" PCV Tubing (sold by ft.) 3 ft
1ea 42-CCA-101 3/4" SS 90 degree fitting
4ea 42-CCA-100 3/4" Plastic 90 degree fittings. Only need 2 for mod.
10ea 42-CCA-U02 3/4" hose clamps
1ea 42-CCU-022 Stealth Oil Catch Can. Black or silver?
1ea 42-CCA-120 Quick Drain Fitting
BMW Dealer items.
2ea 11-12-7-584-128 Vent Hose
Real OEM reference: Item #23
http://realoem.com/bmw/showparts.do?...53&hg=11&fg=15
Mounting bracket can be what ever works best for you.
I used the two open holes in the front fender trim out as seen in the
pictures. Bracket made fro .050 aluminum (2024 T3)
As far as the OCC there are many to choose from. The hose routing can work for most applications, so that opens the choice for the OCC.
The last thing I did was to trim the Ignition Coil Cover to clear the hoses. Really trimmed to much, so I have a new cover coming.
Gotta keep it looking good!
      06-24-2011, 10:18 PM   #9
RealityDesign
realitydesign.com
14
Drives: 2008 Silver 135i
How is the flow on this OCC? I've yet to find a OCC that flows well enough to warrant installing. I had a BSH catch can for a thousand miles or so, but now I'm back to using the FMIC as my catch can... lol.
2008 135i MT - JB4 15ohm, Map 3
CM VC2 2.7gal Meth Kit | CP-e Downpipes | BMW Performance Exhaust | BMS DCI | Stett CP & Forge DV's | ETS FMIC | 3.46 Quaife LSD | KW V2 Coilovers | Breyton GTS-R's | Dunlop Z1 Starspecs | Complete BMW Performance Exterior & Interior
      06-24-2011, 10:21 PM   #10
bogart
bogart's Avatar
117
Drives: E82 N55 DCT
BMW Dealer items.
Thanks for the parts list and info!!! This is awesome. I feel like it should be in the DIY section.
      06-30-2011, 11:42 AM   #11
JB135MDCT
I'm just a cook
JB135MDCT's Avatar
24
Drives: 2011 135i DCT
How do you clean out the reservoir?
      06-30-2011, 02:34 PM   #12
Itsquick
Itsquick's Avatar
2011 135i  [6.00]
1971 280SL  [0.00]
2008 M5  [0.00]
The can has a drain port on the lower end. 42 sells a nice brass drain valve.
      09-26-2011, 01:13 PM   #13
madmanhiker
madmanhiker's Avatar
82
Drives: '11 E92 335i
@itsquick - have you had a chance to see how much it collects?... please let us know. thanks!
-madmanhiker jax,fl
      10-05-2022, 08:37 AM   #14
icoutino
icoutino's Avatar
Mexico
80
Drives: bmw 335i e92
I usé a universal OCC, and just use what was already on the car, turns out that there's o sensor there, the cable it's just conectes to nothing, so I cut where the cable sits and turn backwards so the hose can run free.
1addicts
