06-22-2011, 10:09 AM | #1 |
48
Rep 207
ZCP Spoiler install with 3M Tape Q
For those of you that installed the CF rear spoiler with 3M tape, and dont have any gap issues... What thickness of the tape did you use? And did you go all the way to the edges?
Thanks. |
06-22-2011, 10:20 AM | #2 |
Putcha ang ganda...
281
Rep 5,441
the 3m tape only have one kind. most people use the betalink well actually dealer is required to use betalink but 3m tape should hold it without too much gap...
if your thinking of changing the lip or you think you are going to get bored... use the 3m... betalink is a pain to remove.
06-22-2011, 10:23 AM | #3 |
1251
Rep 6,913
Not exactly true Sean... You can find 3M automotive tape on Amazon in both 1/4 and 1/2 inch varieties. It comes with a red backing.
I used both....the 1/4 inch is better suited for some areas of the lip, and the 1/2 is better in some. If it's applied close to the edges, there should be no gaps!
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
06-22-2011, 10:35 AM | #4 | |
Putcha ang ganda...
281
Rep 5,441
although i just browsed 3M's website i guess they have .25 mill thick.. but the one i see on the website are just semi adhesive. the one that automotive sells are the firm adhesive. EDIT: ill check amazon... i hope this is the firm version... looks like they have several version of 3M tape that have the red backing
06-22-2011, 11:03 AM | #5 |
208
Rep 3,153
I dont know about anybody else but I intended to install my Performance spoiler with 3M tape but once I looked at it, I realized that there was no way that was going to work. The contact area on the spoiler is so small and thin plus the spoiler is so high and creates significant drag/downforce that I dont see how in the world the tape would work. So, I just used the Betalink and I am glad I did! It looks great and is VERY sturdy. Yes it is permanent but IMO it is the only way to go with the performance spoiler.
2011/E92/M3/MR/BB/ZCV/ZP2/EDC/2MT
06-22-2011, 04:37 PM | #6 |
164
Rep 1,506
Drives: '15 FO M4
I installed mine very easily with 3M tape. I used the wider 3M for the middle part and the thinner 3M for the sides. There are absolutely no gaps on mine and it probably took 10 minutes to complete the installation. It has been on for a few months now and is still holding strong. See pics in my garage.
Fire Orange F82 Built by Alekshop | Pure Stage 2 Turbos | Akrapovic Evolution and Downpipes | ESS T-500 Performance ECU Software | Evolution Racewerks Chargepipes | Gruppe M CAI | Awron Gauge w/ Valve Control | KW Clubsport | Brembo GT 380 F&R | 19" BBS FI-R | BMW Performance Seats, Aero, and Steering Wheel | Vorsteiner Diffuser | IND Cosmetics
06-23-2011, 12:58 AM | #8 |
51
Rep 598
I did threads on this....... YES you can use 3M tape. At first I thought the same thing that the contact area was too small but you have to put it all the way up to the edge on the front of the spoiler. The part that contacts the back edge of the trunk you have to attach the tape where it is notched.
3M has no gap. I recommend tape over Beta link anyday, everyday.
Current: 2006 Lotus Elise SC
Previous: 2008 AW E92 M3 6MT - Sold 2004 AP2 S2000 - Sold Last edited by SIIK2NR; 06-23-2011 at 01:13 AM.. |
06-23-2011, 11:40 AM | #9 |
48
Rep 207
Thanks for the drawing, that makes it very clear. (I did search for this before posting, but didn't find something this exactl)
My original question still hasn't been answered however. What thickness (not width) tape did you use? And where did you get it? Thanks |
06-23-2011, 01:28 PM | #10 | |
Putcha ang ganda...
281
Rep 5,441
like mentioned above i browsed 3m website and they only have a semi adhesive tape with red backing on it and you need a firm one which is only available in one kind. maybe you can call 3M to confirm but like i said the regular 3m red backing tape will just do fine. Ill post the picture of what im talking about in about 2 hours.
06-23-2011, 01:31 PM | #11 |
164
Rep 1,506
Drives: '15 FO M4
I went to OSH and bought just standard 3M tape. I used half inch width for the middle and quarter inch for the sides. You can also just cut the 1/2 inch width in half when you do the sides. I'm not sure what thickness it was, but I honestly only saw one thickness when I was there. GL
06-23-2011, 05:25 PM | #12 |
51
Rep 598
One thickness...... 3M ONLY....DO NOT USE SCOTCH Brand!!!
Width can be 1/2 or 1/4 inch For the spoiler, 1/4 is ok. But for the front lip or diffuser, absolutely use 1/2 inch.
Previous: 2008 AW E92 M3 6MT - Sold 2004 AP2 S2000 - Sold |
06-24-2011, 05:34 PM | #13 | |
1251
Rep 6,913
06-24-2011, 11:18 PM | #14 |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
make sure you clean your trunk and spoiler throughly before install, any dirt/grim/grease/etc that is left on there will compromise the tape and lead to early failure.
06-25-2011, 12:33 PM | #15 |
265
Rep 1,696
There is no indication on my 3M tape packaging what the thickness is. But I do have the part numbers of both sizes of tape I used in my DIY that I wrote today:
http://www.m3post.com/forums/showthr...83#post9893383 |
06-26-2011, 01:14 AM | #16 |
21
Rep 340
Everyone posted some good suggestions. I might also add that it helps to make sure you stretch the tape out while you're putting it on so it gets a little thinner and helps minimize the possibility of there being any gaps.
06-26-2011, 11:41 AM | #17 | |
51
Rep 598
I always make sure to NOT stretch the tape and to apply it on "relaxed" as possible.
