06-21-2011, 04:41 AM | #1 |
24
Rep 131
Octane boosters N55/N54
Hi, I would like to find out what your take on octane boosters are. I have heard of reports where OB damages plugs in your car. Is this true? Any experiences with them? Power increases?
06-21-2011, 07:56 AM | #3 |
Indian Stig
29
Rep 1,002
Drives: '03 540i M, '11 Ducati M796
There's really no need for them and running too much octane booster will foul your plugs. Fill up with the highest octane top-tier gas in your area and you'll be good to go... If you track the car, get some high octane at the track.
2008 E82 N54 || Stage 2 -------- Gone to a good home. |
06-21-2011, 08:48 AM | #4 |
123
Rep 1,925
Drives: 2010 135i,1989 PRO3,2001 530i
octane booster = epic fail
135i coupe 6MT TiAg ///M sport http://www.rhominnovations.com www.musicarNW.com www.unitedBMWonline.com |
06-21-2011, 08:57 AM | #5 |
Professional Rookie
34
Rep 533
Drives: 2016 M4
A buddy of mine is running it here and there on his N54 without problems. Usually for track runs when he can't get race fuel.
Terry at BMS uses it to suplement crappy western gas, but I think if you can get good quality 93 octane it should be fine. mineo77: care to elaborate?
2016 MGM/Sakhir M4 DCT | M-Adaptive | Not Stock for Long |
06-21-2011, 02:31 PM | #7 |
178
Rep 1,516
I can vouch for the success of octane boosters. I have 91 gas where I live, so we need it to make some 93 power. My car was hitting in the 295whp consistently. We added octane booster and I hit 322whp and 326whp. I'd give it a shot.
06-22-2011, 10:21 AM | #8 |
123
Rep 1,925
from my research and working with HPF there has been no shown benefit. however, cant argue with folks gaining nearly 30HP from a few more octane (which doesnt make too much sense either, thats a lot of power gain for a few octane but if you are running a higher map then it adds up)
06-22-2011, 04:35 PM | #9 |
70
Rep 2,197
If you're looking for some increased octane levels, try looking into mixing your own fuel. Toluene used to be a very popular component in homebrew racegas. It raises octane and increases the BTU, if I remember correct(Not 100% on the last part.) I think its outlawed by some racing organzations though, and it causes cancer. I have no idea how it interacts with cats or fuel injectors, but it might be worth researching. Its a lot more work than octane booster, but its cheaper in the long run if it will work
06-22-2011, 05:11 PM | #10 |
28
Rep 1,938
depends on the octane requirements of the engine. Assuming you want your car to run max timing advance (best power), the octane requirements may be higher than what you get from the pump. Some places like CA only get 91 octane, whereas you can get 93 or 94 in some other places. In OR, 92 is the best we can get and sometimes it doesn't keep the engine as happy as it could be on a hot summer day in traffic.
06-23-2011, 12:45 AM | #11 |
24
Rep 131
Problem is where I live we get 91 octane ( might be lower than that) I have the option of using NF or Torco as these are the 2 that are available. Torco is 2 times the price of NF and do not know if its worth while.
Sunoco 109 is also an option but will it work on the 135 with no issues or should I look at the Sunoco 104? |
06-23-2011, 05:25 AM | #12 |
70
Rep 2,197
Aren't 109 and 104 both leaded? If so that's definately not an option. What mods do you have? By the sound of things, if you really need the increased octane your best option is meth.
06-23-2011, 11:05 AM | #14 |
70
Rep 2,197
That's why I was saying leaded fuel isn't a(good) option. But I guess if you have removed all the cats, and have luck with the O2 sensors, then you could try it. I've read a few boardmembers claiming that leaded fuel fouled their injectors, but idk if that was the real cause or not. Btw, lead is actually a lubricant and actually good for most metals...
06-23-2011, 11:19 AM | #15 |
24
Rep 131
Both 104 and 109 are unleaded. Google sunoco fuels. Pretty good reviews from some people I know. I tried the 104 in my k04 gti and gains were good.
06-23-2011, 11:25 AM | #16 |
70
Rep 2,197
Really? That's awesome. Id like to try and find some local to me, but the only thing sunoco sells around here is 110 cam2
06-23-2011, 12:33 PM | #17 |
Rep 9
octane boosters are good if you fill up with bad gas and need a boost. i filled up with 90 the other day because i was almost out of gas and the gas station i was at only offered 90 (ethanol free 90). car ran real sluggish until i put in the booster and it adjusted over time back to normal.
06-23-2011, 05:03 PM | #18 | |
28
Rep 1,938
06-26-2011, 05:43 AM | #21 |
53
Rep 941
ive never seen 76 sell that in so cal where im from..
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ berk resonated mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BMS OCC, ER+tial charge pipe. AR DP's, Helix IC,meth, drilled slotted rotors
06-26-2011, 02:18 PM | #22 | |
realitydesign.com
14
Rep 205
First, you'd need to spend about $25 on 100 octane gas to mix your tank to 93-94 octane you get from the octane booster, compared to $15 for the booster. Second, you need to drive (in most cases far) to a gas station that sells 100 octane, rather than just grabbing a bottle from the garage. I have several 5 gallon jugs of 100 octane in my garage, but even then, it's more of a pain in the ass (and more expensive) to fill a few gallons of 100 from the jug than to dump a little can of octane booster in. Thus far, I haven't used the NOS race octane booster. But Terry at BMS seems to use it every tank of gas and has had no issues. It's looking mighty tempting. Although really, with meth, I wonder how much difference it really makes. 91+meth vs 93+meth shouldn't be THAT different. No matter what you start at, as soon as that meth is spraying you're well over 100 octane anyway.
2008 135i MT - JB4 15ohm, Map 3
CM VC2 2.7gal Meth Kit | CP-e Downpipes | BMW Performance Exhaust | BMS DCI | Stett CP & Forge DV's | ETS FMIC | 3.46 Quaife LSD | KW V2 Coilovers | Breyton GTS-R's | Dunlop Z1 Starspecs | Complete BMW Performance Exterior & Interior |
