06-20-2011, 09:20 AM | #1 |
141
Rep 571
Oily/greasy residue on charge pipe and air box, what is that???
Car: 2011 135i with M-Sport Pkg and DCT at ~6,700 miles.
Modifications: V5 Procede with updated Fuel Harness and Golf Tee Mod Just popped the hood open last night and noticed an oily/greasy residue all over the top and sides of the charge pipe and the underside of the air box. Based on the location of the residue, it seems like something between the charge pipe and air box is emitting/spraying it out. What could it be? The locations immediately outside of the affected area seem to be spotless so it appears to be very isolated. The car is only about half a year old and with low mileage, the rest of the engine bay is fairly clean with just some leaves scattered about. Sorry, I am at work at the moment so I can't post a picture yet. I will try to post a picture by the end of the night. Anyway, the car drives fine with no noticeable symptoms. Am I just being paranoid? Thanks in advance. |
06-20-2011, 09:30 AM | #2 |
141
Rep 571
Okay, so I know this isn't an exact representation of my engine but the angle of the picture best illustrates the affected areas in yellow.
Any ideas what could be causing this? What is that residue and where is it coming from? I will post a picture of the actual problem later tonight. Thanks again. |
06-20-2011, 10:49 AM | #3 |
159
Rep 5,689
Blow by, I get it all over my engine bay with a bov.
Not near as bad now that I have an occ but still there.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
06-20-2011, 11:55 AM | #4 |
141
Rep 571
06-20-2011, 12:01 PM | #5 |
Indian Stig
29
Rep 1,002
Drives: '03 540i M, '11 Ducati M796
Unfortunately, it seems to be quite normal. I've got the same oily residue coating my intake piping.
2008 E82 N54 || Stage 2 -------- Gone to a good home. |
06-20-2011, 02:03 PM | #6 |
53
Rep 941
normal to get it.. the n55 should be better compared to n54 however, since it has updated engineering on the PCV's.
I just got a BOV and BSH OCC so i hope i dont get oil all over my engine bay now. lol..
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ berk resonated mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BMS OCC, ER+tial charge pipe. AR DP's, Helix IC,meth, drilled slotted rotors
06-20-2011, 06:33 PM | #8 |
323
Rep 1,804
The oil/greasy residue is, well, oil. Normal though.
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
06-21-2011, 01:38 AM | #9 |
137
Rep 1,450
if it is quite a bit of oil and wet then you may have a leak. Check all your clamps are tight and no leaking is evident where they join the charge pipe or where the charge pipe fits onto the throttle body. It is also worth looking at the DDV's to see if anything is leaking from there. If all those are ok, then I guess it's as the others have said above
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
06-21-2011, 03:59 AM | #10 |
153
Rep 2,757
Drives: 2017 Audi A4
Just curious for those with the bsh catch cans, how easy is it to empty the can?
06-21-2011, 06:18 AM | #11 | |
141
Rep 571
06-22-2011, 01:54 AM | #12 |
137
Rep 1,450
A boost leak wouldn't drip...it is under pressure so it would "spray" anyway, from what you describe, it sounds like an insignificant amount and no need to worry unless it gets worse
06-22-2011, 01:56 AM | #13 |
137
Rep 1,450
I use a plastic pipe to "suck" it out so I don't let it fill up much. Otherwise you have to remove it to get to the drain plug
04-11-2018, 03:14 PM | #14 |
161
Rep 763
Sorry to bring a thread back but I’m having similar oil residue but a bit more toward the front of the engine, and my alternator is getting some oil on it as well which can’t be good.
The origin of the oil seems to be from under the pipe coming out of the air box similar to what the OP described The car drives the same still but with summer coming up I just want to be sure this isn’t going to break something ... pretty sure an alternator shouldn’t get oil on it so might be SOL |
04-12-2018, 07:36 PM | #16 |
480
Rep 1,600
Chargepipe is heavily greased at the throttle body end. The oil base in the grease seems to wick a bit.
Sliiiiiiick, i think you meant the OFHG gaskets? Fusionchicken, check your oil filter housing gaskets. A leak there will dribble onto the belt, slinging it onto the alternator and soiling the top radiator hose also |
04-12-2018, 08:12 PM | #17 | |
161
Rep 763
06-02-2018, 05:26 PM | #18 |
161
Rep 763
So I replaced my OFHG and the two high pressure hoses connecting the oil cooler to the radiator.
For good measure I also replaced the stock drive belt and the pulleys Now it’s pretty clear that my chargepipe / diverter valve is/are spraying oil. What’s bloody annoying is that oil is getting on my new drive belt This explains my very occasional 30FF low boost code too hopefully replacing the chargepipe and DV is the end of this oil leak on drive belt saga |
06-02-2018, 08:17 PM | #19 | |
22
Rep 58
