06-14-2011, 01:12 PM | #1 |
Bimmer Newbie
22
Rep 312
Drives: CSM N54 Prem/Comf/Sound
Anyone ever see or can validate this?
From a youtube video comment to get your 'GPS' digital speed to show up on your instrument cluster:
"What you do is this, get in the car, close your door, and turn on the ignition(press the start/stop button, but not the brake). Wait 10 sec or more, and then press the resetter on the speedometer and hold it until a triangle appears, then the oil, then after those you'll have something called 01.00 and something else under it. When that appears you stop pushing the button and wait like 1-2 sec for a number to appear What you do next is that you add the last 5 numbers 1 + 2 + 3 + 4 +5, after that you press the button again for 2 sec and it will display 01.__ then just press the button until you reach 19.__ And it will say lock:ON and then you just press up to the number that you got from adding the 5 numbers together. Then it's unlocked, then go to 08.__ which is the speedindicator. 08.00 is realtime gps speed, 08.01 is digital speed ridden from the needles " Anyone see/do this already? |
06-14-2011, 01:27 PM | #2 |
I break for no one
15
Rep 379
Umm, if BMW put a GPS tracking link in my car and didn't tell me I will be supremely pissed off. Since I don't have nav, I need no tracking link. If there is one, it's being ripped out.
06-14-2011, 02:20 PM | #4 |
European Editor
10589
Rep 22,992
^^That does NOT get you a GPS signal!! ...that gets you into the Instrument Pannel secret menu/cookies! It will display the actual road speed. But you have to enter that 'add up" VIN every time you want to get into the instrument pannel. It is a PIA.
here is how... http://e90.wetpaint.com/page/BC+hidden+menus?t=anon Btw... the actual speed via the car's wheel sesnor is very accurate. You will have the same speed shown as your GPS navi will display - as long as you have OE sized tires. When I switched to 225/255's my M3 digital speedo reads lower by 1kph less than true GPS speed. Still better than the +3% of what the speedo shows/reports. BTW-II... you can always have your instrument pannel (Kombi in German) coded to have the M3's digital speedo displayed. "V = kph (or mph)" depending on what your menu settings are set too. |
06-14-2011, 03:19 PM | #5 | |
Bimmer Newbie
22
Rep 312
Better start ripping stuff out...lol |
06-14-2011, 03:29 PM | #6 | |
117
Rep 1,998
actually they only "look" for you when the airbags are deployed and or you press the button... But I guess someone has access to your ESN at BMW...
X1, R58 JCW, M2 in my future if planets align
06-14-2011, 03:36 PM | #7 |
2452
Rep 7,341
I got mine coded by a local guy in NYC. My car now reads the "V=[speed]" and I dig it. It's still not accurate according to my GPS speedo on the iphone.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold |
06-14-2011, 04:33 PM | #8 | |
European Editor
10589
Rep 22,992
That is because either "that guy" coded the M3 digital speedo to read the SAME as the speedo signal. ie: "buffered value". Or... you have non OE sized tires (larger or small overall diameter.). When I had Thorsten from www.car-coding.de do mine... he asked me which I prefered. I wanted "true" vehicle speed. And ohh... even when you have the V-max removed and you do a top speed run... the digital speedo will ax out at 155mph/250kph! |
06-14-2011, 06:56 PM | #9 |
44
Rep 1,265
I had someone that does code on our cars put that feature on my car. It's stupid if you ask me. I have a digital and sweep speedo on my CTSV also. I always turn off the digi one
06-15-2011, 08:36 PM | #10 | |
47
Rep 940
I got my car coded by the same guy with actual road speed, and it is spot on. I'm betting it's your iPhone that is wrong.
E82 Gone. 2013 JKUR on order Last edited by tcd223; 06-16-2011 at 01:53 PM.. |
