      06-14-2011, 10:29 AM   #1
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
Question on my BMS Install
Hey all,
Just installed my BMS DCI and my installation seems to be a tight fit in comparisson to the pictures on the installation instruction.
Ive posted a picture from the installation instruction (the last picture with the yellow circle).
If you look at my pictures my air hose is not behind the three cables like the one shown at the pictures above. But I cant find a way that is possible to make the air hose go behind the three cables as the air hose is clipped to that straight horizontal bar that the three cables go into.
I guess I was wondering if I installed it correctly as it seems like there isnt much space and my intake is actually touching the cables.
      06-14-2011, 10:33 AM   #2
cmdboy
Drives: One fast car
Thats how my is sitting. Has no problem for two years.
      06-14-2011, 11:21 PM   #3
thez99
thez99's Avatar
153
Drives: 2017 Audi A4
2013 BMW 135i  [0.00]
In the last pic, they are missing the front cable from the cowl..the one that sits closest to the top of the filter, that may be adding to why it looks a little off. Although I would say perhaps your rear filter could be a little farther OUT. Did you make sure to clamp the pipe inside the filter JUST inside, and not push it too far in, this would cause it to be too far in the back of the engine like that.
      06-15-2011, 12:42 AM   #4
Jeef Beef
Lord Captain Commander
Jeef Beef's Avatar
Australia
110
Drives: a sleeper
Looks fine there mate. It is a bit tight for space on our 1ers, the cables also touch my filter.
E82 135i M-sport: SGM/6MT/Black
      06-15-2011, 01:29 AM   #5
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
ok just needed to make sure
also I have been driving it around today and I can't seem to hear this "whoosh" noise that people keep raving about! granted i havent floored the car yet as there is a massive thunderstorm for the next 5 days over in Perth .
Is the sound very noticeable or only noticeable when you go WOT?
      06-15-2011, 01:36 AM   #6
thez99
thez99's Avatar
153
I would say the main reason you arent noticing it near as much is because you still run the stock chargepipe/diverter valve setup. There are noise baffles on the stock pipes that quiet the intake/engine sound, also, those pipes connecting from ur intake tubing to ur diverter valves actually take away from some intake performance as well as sound. Get yourself an ER chargepipe with a BOV, removes the hoses from the intake piping, caps those holes, you hear the engine, turbos, etc. much better, not to mention throttle and WOT performance is increased a bit.
      06-15-2011, 01:59 AM   #7
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
I'm pretty sure I have seen videos of cars with just tune and DCI and you can hear the whoosh sound quite clearly.
I don't have more money on more mods... haha....
      06-15-2011, 02:15 AM   #8
Jeef Beef
Jeef Beef's Avatar
Australia
110
Drives: a sleeper
The whoosh sound is very noticeable. Took my car a few days before it reached max volume. Should be able to hear it even with windows up, but it's the best when you've got them open. If it's raining, it's gonna be pretty hard to hear.
It's most noticeable in the higher gears on low revs and you are a bit more heavy with your right foot. 3rd gear I believe is the best, when you lift off you get the "tschhhh" sound to boot!
      06-15-2011, 02:28 AM   #9
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
will give that go when the weather clear up a bit.
I was getting paranoid that i didnt install it correctly haha..
ps. I suppose it doesn't make a different if you have AT? would it produce more sound if you have a manual 135?
      06-15-2011, 12:48 PM   #10
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
136
Drives: 328
The whoosh sound is there, the more PSI you are pushing the louder it will be...so that explains why you have not heard it if you have not floored it yet. (i.e. you have not built up any boost!!)
      06-15-2011, 01:21 PM   #11
Mr. Nice
Mr. Nice's Avatar
141
Drives: G80 Comp XDrive
As long as its on there tight enough you're good.
Originally Posted by djkrajzi View Post
Mr nice doesn't play nice. But I guess he has a very fast car
1addicts
