06-10-2011, 12:56 PM | #1 |
16
Rep 238
COBB AP= WTF just happened???
So installed the stg 1 93 octane map (yes there is 93 in the tank) and pushed it hard last night. Seconds later as I dropped back down to about 70 mph, the car starts for lack of a better word "sputtering". I gave just enough gas to maintain that mph and it was fine but if I went anything past 25% throttle it would sputter harder. The service engine light came on while this was happening for about 4 miles. Then the service engine light turned off and the car was perfect again. I did not push my luck from there as I wanted to make it home. Any ideas anyone???
06-10-2011, 12:59 PM | #2 |
AKA HISSMAN
34
Rep 888
Did you check the code?
(FBO) Cobb Stage 2+, AR Downpipes, Injen DCI, AA (Sport) FMIC, ER Chargepipe/Synapse BOV, Carbon fiber bits and Breyton GTS-R Wheels.
06-10-2011, 01:19 PM | #4 |
2452
Rep 7,341
Sounds like HPFP but the codes will tell the real story.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold |
06-10-2011, 01:28 PM | #6 |
AKA HISSMAN
34
Rep 888
Yes.
06-10-2011, 02:02 PM | #7 |
Rep 82
I agree, really sounds like your HPFP... Uninstall COBB and take it to the dealer. I really hope BMW finds a real fix to the fuel pump problem before my warranty runs out. Constant replacement sucks.
06-10-2011, 02:10 PM | #8 |
154
Rep 4,528
Drives: M2 CS
06-10-2011, 04:40 PM | #10 |
16
Rep 238
I checked the codes and got (P2FA3 mis coding) and (P29D2 misfire in cylinder 6). Anyone know why this would happen? I'm not blaming it on the AP, however it only happened the day after I installed it. Admittedly, this was the first time i "really" pushed it in the car. Guess the N54 didn't like 130 mph+.
06-10-2011, 04:45 PM | #11 |
aka 1013MM
1253
Rep 9,545
just go take the car back to the dealer and get the hpfp fixed. end of story. live on. stop thinking. just do it. NIKE.
06-10-2011, 05:42 PM | #13 |
15
Rep 146
11k miles on my 135 no trouble. Two weeks after my Cobb install, my HPFP went out. I dont think its due to the specific cobb tune, but I do feel it wouldn't have happened had I not run a tune at all.
Then again, others with no tunes have replaced their HPFP's.
2008 135i 6mt
Cobb Access Port Stage 1 |
06-10-2011, 06:43 PM | #14 |
BMW Client Advisor
1000
Rep 3,526
lemon the damn thing. you will get a lot of your money back
06-11-2011, 04:20 PM | #16 |
111
Rep 537
this happened to me exactly with procede when i started pushing 14+ PSI. I changed spark plugs and now it runs beautifully. Change those first because easiest cheapest, then move on to coils, injectors and hpfp.
2018 X3 M40i - JB4 / BMS Billet Intake
2015 M4 6MT - JB4 / Gintani DPs 2005 M3 6MT - VF Engineering S/C / KW / StopTech / Dinan / HPF Stage III (removed)- Track Toy |
06-11-2011, 05:53 PM | #17 |
675
Rep 4,080
I've had this sort of thing happen after changing out parts like FMIC, intake, etc. and not letting the engine adapt before pushing it.
Those don't look like HPFP codes. |
06-11-2011, 10:42 PM | #18 | |
67
Rep 920
And to the op as all have said its hpfp #2 for you
16 m4 vert, 18 X6M, 22 Tesla MYP, 21 Plaid, 17 Ram
06-12-2011, 07:38 PM | #19 |
Rep 49
Misfire only in cyl 6 ? sounds like an injector. Have you had all your recall(s) performed ? I'd return the car to stock, bring it to the dealer, address your driveability issue, and continue enjoying your car. Don't blame the tune ! Don't lemon the car !
06-13-2011, 09:58 AM | #20 |
Got Boost?
Rep 234
wow...people are very quick to blame HPFP. That code doesn't suggest HPFP at all. How many miles on your spark plugs?
Could be plugs, coils, injector...way more likely than a HPFP. It only happened on one cylinder. Then again it could have just needed to adapt...or been some bad fuel. Hold off on dealer...car isn't going to let itself blow up or anything. Clear the codes. If it happens again either go back to stock and dealer it, or swap plug, coil, injector to a different cylinder and see if the misfire moves there...swap those separately to isolate the problem.
- - My Car Domain - -
2010 BMW 135i AT, AW, ///M Sport JB4|BMS DCI|MS 3" cattless DPs|Golf Tee|33% Tint|///M Pedals |
06-13-2011, 12:03 PM | #21 |
[Versatile]
378
Rep 1,683
I love you , no homo.
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD '13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD '20 AW F87 X3MC - Sold Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build. |
06-13-2011, 02:17 PM | #22 |
16
Rep 238
Removed the tune and took the car to the dealer. Figure what could it hurt. I'll let you guys know what was found. I know it ain't saying much but the current fuel pump is only about 2 months old, and I don't think that's the problem. I'm gonna guess coil pack or injector.
