06-10-2011, 10:43 AM | #1 |
276
Rep 3,465
Drives: 997.2 GT3, '17 G30
BMW SSK 2 years later not so short!
I first installed my BMW Performance SSK almost 3 years ago maybe 6 months after I picked up my car. After initial install, the shifter was very tight and had a snickety feel to it going in and out of gear. Fast forward to today, I also now have a 2010 Mini with an aftermarket short shifter, just recently sold my e36 with a UUC short shifter and my e30 I sold 2 years ago had the z3 1.9 shifter arm and bushings in it and those all proved to be more precise and shorter than my BMW performance SSK. Now also, it seems that the BMW Perf SSK bushings are more worn in now with 6k miles of use and 1 track day + numerous spirited drives in Upstate NY.
The throws feel long and vague and makes me think that its as if someone went in under my car w/o me knowing and replaced my stock shifter back into the car. Does anyone else feel the same way after putting some good use on their Performance SSK?
ig: 0verrev
06-10-2011, 10:49 AM | #2 |
Indian Stig
29
Rep 1,002
Drives: '03 540i M, '11 Ducati M796
Maybe you've just gotten used to it? Especially since you've been driving other cars with shorter and more precise throws, it probably just doesn't seem like it used to. One sure-fire way to find out is swap back to the stock shifter.
2008 E82 N54 || Stage 2 -------- Gone to a good home. |
06-10-2011, 10:57 AM | #3 | |
Lord Captain Commander
110
Rep 3,093
E82 135i M-sport: SGM/6MT/Black |
06-10-2011, 11:28 AM | #4 |
276
Rep 3,465
I'm not sure if you can say I am "used to it" as I drive the car roughly once a week or once every 2 weeks. True I am getting used to the shorter SSKs in my other cars but I distinctly remember a very snickety feel.
If only UUC would finally fix their issues, that would be my next step.
ig: 0verrev
06-10-2011, 11:40 AM | #5 |
Indian Stig
29
Rep 1,002
B&M also make a short shifter for the 1ers... I haven't heard of anyone running one though. I know they're a popular option in the Audi world.
http://www.bmracing.com/PRODUCTS/BMW...MW-1-SERIES-04
06-10-2011, 11:48 AM | #6 |
47
Rep 940
At the next meet, you can take a spin in my car. That way you won't have to put your stock shifter back in.
E82 Gone. 2013 JKUR on order |
06-11-2011, 09:08 PM | #8 |
110
Rep 3,093
Well I just had a friend drive my car that hasn't since I put my SSK in. I forgot to mention to him that I put in the SSK too.
His first reaction was "WOW this feels so much better than last time, what did you do to it?" So I guess it's partly us
06-12-2011, 01:33 AM | #9 |
European Editor
10589
Rep 22,992
Measure the shifter throws. The BMW Performance SSK has 55mm throws from 1st to 2nd gears.
There are some plastic bushing in the system.,. they do wear and cause some sloppyness. The bushings can become oval instead of circular... and this can cause a loose feel. Also the plastic "cup" that the shfter stick sits in can wear as well. The only real way to check these parts is to take it apart for a look-see. |
06-12-2011, 02:11 PM | #10 |
European Editor
10589
Rep 22,992
The UUC webiste might help you understand where the OE shifter can wear at all the plastic parts. Just don't buy one of these UUC shifters because I hear they don't fit/work on our 135i's!! lol I would think BMW would cover you IF you had it installed at a BMW dealer and IF you had your reciepts.
http://www.uucmotorwerks.com/shifter...stic/index.htm This is also a good post - that shows you all the things in the shift linkage that can wear and make the shiftlinkage "wiggle". http://forums.bimmerforums.com/forum...php?p=22046392 Dackel |
06-12-2011, 08:55 PM | #11 | |
68
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
Dackelone, I'll measure my UUC did you measure from the trim? UUC SSK isnt bad, DSSR doesn't fit with the 135i.
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
06-13-2011, 02:28 AM | #12 | |
European Editor
10589
Rep 22,992
I measured using the chrome trim ring as a guide. Here is how I measured it... http://www.1addicts.com/forums/showt...shifter+throws Dackel |
