06-05-2011, 07:24 AM | #1 |
16
Rep 127
SCCA AutoX school - San Diego
Did my first ever SCCA event, an autocross school yesterday. Day was full of driving and chatting with fast people, I definitely learned a lot. It was my second time out with the 135i so I'm still learning how to drive it. Car is all stock with 17x8.5 Kosei's wrapped in 235/40/17 Dunlop Direzza SS.
Broke the timing beam going sideways and ended up sliding for a considerable distance. I tried steering with the slide, but it was really dirty once I got off line and I'm just glad the car stopped before hitting those big pillars. I think I just got right in between the two pillars and stopping a few meters short of the curb. Since they weren't strict with cones and times, I really didn't DNF Ended up being .5 seconds off of my instructor, who also drives a 135i. Given he only did 2 tries, and I did my fastest time during my third run, I'm still pretty happy with my times. Last edited by Oofie; 06-05-2011 at 07:33 AM.. |
06-05-2011, 10:55 PM | #2 |
13
Rep 340
Nice, looks like you're getting comfortable with the new ride. Now that you've gotten your first spin out of the way, there's nothing holding you back.
Exhaust sounds like you guys couldn't wait to modify for more power. That's stock? |
06-06-2011, 07:12 AM | #3 | |
16
Rep 127
By the way, that's still all stock. I modified my Gopro camera to accept an external mic which I then placed on the rear bumper just above the exhaust tips. You going to be here for the 26th autocross? |
06-06-2011, 07:37 AM | #4 |
140
Rep 2,234
I am interested to hear how you modified your gopro for an external mic. Gopro mic really sucks
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
06-06-2011, 08:05 AM | #5 |
49
Rep 654
From the looks of the video and the sound you were fully on the gas coming out of that last corner and you needed to straighten out for the stop box. The weight of the car swung around on you as you tried to straighten out for the finish and as you said there was likely some dirt on the pavement adding to the mayhem. You might've been able to save that with a super fast steering correction in the opposite direction, but all is well and that looked awesome! Haha
06-06-2011, 08:52 AM | #6 | ||
13
Rep 340
06-06-2011, 08:56 AM | #7 |
16
Rep 127
06-06-2011, 12:54 PM | #8 |
140
Rep 2,234
don't forget to let us know how you modified your gopro. I was thinking about buying an external digital audio recorder and then sync the audio to the video. is this what you did?
06-06-2011, 01:07 PM | #9 |
16
Rep 127
yup, ill try taking pictures of what I did. Having an external recorder is a good idea also, but entails more steps to edit sync points, etc.
06-06-2011, 01:54 PM | #10 |
140
Rep 2,234
great thanks man!
06-06-2011, 04:04 PM | #11 |
16
Rep 127
***The mod most likely will void your warranty, and do this at your own risk. I am not responsible for any damage that might happen or if your GoPro won't function properly.***
I bought these: -3.5mm male to female stereo cable like this. -external microphone like this. -Basically, you have to open up your gopro camera by taking out the batteries and taking out the four small screws behind it. Be careful opening it as there is a ribbon cable connecting the front half to the other half. Once opened, look for this piece, the stock mic. I used a soldering iron to take it out. From here, cut your 3.5mm cable and keep the 'female' part. I just cut off the 'male' part so that I have a long cable sticking out of my gopro. Strip the 3.5mm cable. I basically joined the red and white (L/R) and soldered them onto the (+) of the board, where the original mic was attached. Then just solder the (-) of the cable to the (-) of the board. Reassemble the camera and test it with the external mic. I also covered my external mic with a piece of cloth/foam to reduce wind noise. Of course, you can skip the 3.5mm cable and just cut the external mic's end and attach it to your gopro, but I chose the 3.5mm interconnect so I can be more flexible. This way, I just have to buy another 3.5mm interconnect so if I wanted to, I can place the camera in the front bumper while the mic is near the exhaust. By the way, the external mic will probably greatly reduce the battery life of the camera. It's still worth it though compared to capturing wind noise. Last edited by Oofie; 06-07-2011 at 06:18 AM.. |
06-06-2011, 08:36 PM | #12 |
AutoXer
34
Rep 683
I can tell you he got very used to the 135i by the end of the day! Big improvements. Let's just wait to see how long they keep it stock.
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
06-06-2011, 09:07 PM | #13 |
140
Rep 2,234
damn you weren't kiddin' when you said you had mod your gopro! thats amazing what you did. not sure if I have the know how to pull that off. couple of questions, how do you route the wire from the sealed enclosure and where do you route the wire to the back of the car? in all honesty I would probably buy the external digital audio and just sync the audio and video but thanks for the info
06-06-2011, 09:13 PM | #14 |
105
Rep 2,696
It's a pretty sweet mod, but alas cannot be done for mine as I'll be using it for diving
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
06-07-2011, 08:12 AM | #15 | ||
16
Rep 127
