      05-29-2011, 12:18 PM   #1
burger16b
burger16b's Avatar
13
Drives: 135i
car feels slower help me!!!
ok so I've had my car for a couple of months and only drive it when its nice out because I have a civic for dd. when I first got the car and would take traction control off I could send the ass end squirrely in first. now with traction control off it barley spins the tires. am I losing hp? I checked the dv vales and charge pip connections an all looks good. nothing is coming off. its definitely not me getting use to the car. when shifting through the gears everything feels fine and turbos are defiantly spooling cuz you can feel them kick in, even in third you can hear the tires starting to spin. also as a side not I have a riss racing exhaust and cfe intake. and stock run craps that are new from the dealer. out side temp around here has been around 70º when I got the car it was around 55º to 60º any sugetions on what it could be?
      05-29-2011, 12:53 PM   #2
eleven11
eleven11's Avatar
372
Drives: -F85 X5M-
Probably needs to have the adaptive settings reset (quick search will tell you how). And, its angry that your Civic is your DD.
Edit:
http://www.bimmerfest.com/forums/sho...d.php?t=411543
Here you go.
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      05-29-2011, 12:57 PM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I bet your rear tires have worn down pretty good and are giving you less thread squirm now & more traction. How are your rear tires? Most ppl only get between 8K to 18K miles out of them.
      05-29-2011, 06:31 PM   #4
burger16b
burger16b's Avatar
13
Drives: 135i
Edit:
Here you go.
its a manual tranny. the civic is the dd because work is 32 miles away and better on gas.
      05-29-2011, 06:36 PM   #5
burger16b
burger16b's Avatar
13
Drives: 135i
tires have less then 2k on them . also is the sound baffle suppose to connect to something?(where its pointing to in the picture) because like in the picture its just floating in the engine bay.
      05-29-2011, 09:54 PM   #6
Lefthandblack
Drives: BMW 135i
It's the temp outside. When it is 55 degrees here, I can't get traction in 1st, 2nd and parts of 3rd. When it is 70 and above, only first gives me issues. Definitely the temp. Those runflats get squirrely when the pavement is cold.
      05-30-2011, 12:26 AM   #7
eleven11
eleven11's Avatar
372
Drives: -F85 X5M-
Oh, manual... no dice, then. I'm not sure on your floating piece.
2017 X5M - Current
      05-30-2011, 01:08 AM   #8
moveswiftly
moveswiftly's Avatar
381
Drives: Cayman GT4, 135i
2012 335iS  [0.00]
+1
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi
      05-30-2011, 10:29 AM   #9
burger16b
burger16b's Avatar
13
Drives: 135i
ok thanks i thought so. never had run flats before. cant wait to burn through these and get some real tires
      05-30-2011, 01:27 PM   #10
Hind
///Mmmm
78
Drives: '09 BMW 135i
Current: E90 LCI 335i JetBlack - BMS OCC, JB4 w/ E85, ETS Charge Pipe, Vishnu Catted DP
Retired:///E82 135i LeMans - 12.710 @ 108 MPH
Riss Racing OCC, Shadowline Grills, Magnaflow Axle-Back, JB4, ETS FMIC, BMS DCI, BMW Perf Sideskirts, BMS 12/10 Spacers, E93 Front Sway
PDC Flickr YouTube
      05-30-2011, 01:47 PM   #11
Vectors2final
Vectors2final's Avatar
1357
Drives: 2018 F80 YMB/SS ZCP
Also, FI cars tend to run a lot better in cooler weather. They tend to have a little more pep in the step. I call that weather, "Turbo Weather"...
2019 Ruby GT350 - Gen 5 Whipple on corn making 855RWHP.
Sold: 2018 F80 Part Deux /DCT /YMB /Full SS /CF Trim /ZCP /ZEC w/Black 666M
Sold: 2015 F80 /DCT /YMB /Full SS /CF Trim /ZEC /ZLP /HK /S&TVC- 18''///M
      05-31-2011, 09:19 AM   #12
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
136
Drives: 328
sorry to kind of derail, but can't we just remove that whole section with the sound baffle?
      05-31-2011, 08:21 PM   #13
burger16b
burger16b's Avatar
13
Drives: 135i
yeah can we with out doing damage to the engine?
      05-31-2011, 08:53 PM   #14
thez99
thez99's Avatar
153
Drives: 2017 Audi A4
2013 BMW 135i  [0.00]
Um..im pretty sure if you mess with the stock charge pipe you either need to get aftermarket on that connects securely on both sides, or dont do shit to the stock one..
The baffle is in between the stock pipe where the two dv hoses intersect, if you remove that the pipe will be too short, period. Just get an ER chargepipe with their replacement DV's or a BOV setup (better). Less restrictive incoming throttle and drag.
Also, not sure if thats a pic of the N55 CP or the n54, but im pretty sure my n54 CP the whole thing was one piece..
      05-31-2011, 09:42 PM   #15
burger16b
burger16b's Avatar
13
Drives: 135i
its the n54 and yes it does connect between the diverter valves, but it has no effect on the length. As you can see in the picture it attaches to the flange between the diverter valves so that is why I'm questioning if I can remove it. I'm getting the er charge pipe and fmic kit in the near future but want to know about the sound baffle for now.
      05-31-2011, 09:47 PM   #16
thez99
thez99's Avatar
153
Where im not even sure where the hell the other end of the sound baffle connected tbh..I just had my shop swap the stock one out for the ER one, no problems. Still have my stock pipe n hoses.
      06-01-2011, 07:48 AM   #17
MilehighM3
MilehighM3's Avatar
915
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
It's not supposed to connect to anything, it's an engine sound system similar to the last Z4. Gives an air intake sound when you get on it. Without it the car us much quieter. You can also replace it with a stock 3 series charge pipe if you dent want aftermarket. The 1 is the only car to use the sound baffle... It has no effect on performance with or without it
1addicts
