05-26-2011, 10:25 PM | #1 |
23
Rep 274
Dinan Stage 2 boost
Does anyone know what boost is with this flash I have looked on dinan web site can not find.
05-26-2011, 11:13 PM | #3 |
12
Rep 99
14.8 PSI is what I've been told. Easy to check, just put in a "T" and add a gauge.
DJ
2009, tuned 135i, gone, but not forgotten.
Fear of dying exceeded thrill of speed. (and coordination.) |
05-26-2011, 11:50 PM | #4 |
23
Rep 274
Well I have just installed a p3 vent boost gage and i have dinan stage 2 installed and all i can get for boost is 10.5. Is this low?
05-27-2011, 12:03 AM | #5 | |
12
Rep 99
If you are not pulling in third gear, you may not have time to get to the full boost (IIRC). Does it seem to flatten out at 10.5 or just get there? DJ
05-27-2011, 12:25 AM | #6 |
23
Rep 274
Thats floored it just gets there and no more than that. The reason im thinking there is somthing up is because of the recall. I told the dealer that i have dinan installed and do not want it erased. The car doesnt feel the same or i could be just getting use to it. I wish had the gage installed before they touched it. I was reading on n54 web site and someone saying 13.5 boost for stage 2. If 8.3 is stock and im only getting 10.5 thats alot of dough for 2.2 gain
05-27-2011, 06:15 AM | #7 |
I like beer
32
Rep 1,286
That seems low. I usually hit about 13.8 psi, and I also have Dinan Stage 2 and P3 gauge. Not to sound insulting or anything, but did you calibrate the gauge after install?
05-27-2011, 06:51 AM | #8 |
Bimmer Newbie
22
Rep 312
Drives: CSM N54 Prem/Comf/Sound
also be warned.
Dealers remove the Dinan when changing parts as the install new BMW software. They did it to me and then their 'dinan laptop' was out for repair. I had to come in again to have Dinan back on. |
05-27-2011, 08:51 AM | #9 |
23
Rep 274
Not insulting at all thats what this forum is for feed back. 13.8 sounds like it i would be happy with that. I did calibrate also. I am hearing funny noise when car shut off it sounds like a belt slipping then stops or a bad bearing. We will see i am going to take it in for its service and get dealer to check it out.
06-02-2011, 11:30 AM | #11 | |
Rep 446
06-03-2011, 07:08 PM | #12 |
68
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
I'm going to my dealer to have my Dinan S2 re-installed. Seems every time BMW has a recall (did the HPFP & Injectors) and install a new BMW SW you have to re-install the Dinan SW. Funny thing was I had to talk to the Service manager before I could make an headway, seems a lot of service technicians aren't very knowledgeable even if they are a authorized Dinan service centre.
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
06-07-2011, 08:52 PM | #14 |
40
Rep 400
i hit around 14.5 consistently
Black Sapphire Metallic 135i/Coral Leather Interior/ Gloss Black Grills/20% tint/M door sills/Black 135i badge, smoked LED side marker, Dinan stage II , DINAN Exhaust, performance side skirts, performance shift boot/e-brake, pedals, carbon fiber wrapped interior
06-10-2011, 01:35 AM | #15 |
68
Rep 627
Wow just had my Dinan S2 SW re-installed, HUGE difference, my 135 pulls like crazy! =)
06-10-2011, 01:58 AM | #16 | |
Rep 32
Litebulb did you take it to BJ's? |
06-10-2011, 09:05 AM | #17 | |
Rep 446
06-10-2011, 12:25 PM | #18 | |
68
Rep 627
Brought it back to Autowest, but Brian Jessel is a Dinan dealer as well.
Mike I was in the same situation, after my HPFP & injectors my car felt slow. I double checked and they did install a new BMW SW. So I called Dinan and they confirmed that with every recall, Dinan issues a new SW. I would make an appointment with your dealer, mine took a few hours and was under warranty. Quote:
