05-09-2011, 06:43 PM | #1 |
25
Rep 171
Oil temps... is 245-250F "normal"?
Does anyone else regularly see anything close to 250F oil temps? I have an N54, but would like to hear from N55 owners too.
Just snapped a blurry-cam pic after my daily commute. Kinda worried about the high oil temp, epsecially now that it has gone up about 5 degrees since changing from BMW Castrol Class III (hydrocracked) to German Castrol (Class IV/PAO). The at-temp oil weight (in this case, SAE30) is based on a 200F oil temperature... does anyone know if oil will continue to thicken as the temperature goes past 200F? If so, I would consider changing to a lower viscosity oil. Yes I have some performance mods (Dinan Stage 2 ECU, Berk exhaust) but the oil temp hasn't been affected by any mods.
05-09-2011, 07:14 PM | #4 |
1023
Rep 1,968
I have a N54 with PPK, but I generally see 241 to 243 when moving at normal highway speeds (70 to 80mph).
I have seen a max of 255 (so far) on a warm day when stuck in stop and go traffic (rush hour). This is as reported by the steering wheel, but visually confirmed with dash gauge. I have yet to drive the car in hot weather or on the track, so I can't comment on that. IIRC, the original owner mentioned that oil temps were the same pre-PPK (~241). |
05-09-2011, 07:16 PM | #5 |
124
Rep 1,362
I've seen my temps that high after a 30 min drive, but not at 57F ambient. Also you have viscosity backwards, you want higher viscosity on warmer temps and lower viscosity on winter days. I myself have been using the dealership castrol oil and have had no problems and I've seen temps as low as -5f in the winter to 95f in the summer with lots of humidity.
Oh and mods are Procede, DCI, Mids back exhaust, and FMIC. |
05-09-2011, 07:16 PM | #6 |
57
Rep 2,251
yup is normal
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB |
05-09-2011, 07:25 PM | #8 |
European Editor
10589
Rep 22,992
Yes, normal oil temps OP. Nothing to worry about.
When I first got my car I was using Mobil-1's 0w40 euro blend LL1 oil. The oil temp would be right at 250 'F. When I would really push the car on the autobahn.. temps would go two needle widths over 250. I would say 260-ish. Then I switched to German spec Castrol RS Edge 0w40 LL4 oil. The temps went down to 242-ish. (I would say my normal oil temp is two needle widths lover than in your pic) Now I rarely get close to 250 'F now. AND... the engine is much quieter on cold starts and overall. Dackel |
05-09-2011, 07:59 PM | #9 |
Rep 242
N54 here: Generally always just below 250 after a decent amount of normal driving (15m+, 1500-3000rpm, <50%thr), generally just above 250 after spiritied driving (3000-5500, <80%thr) and generally around 265-270 after a good amount of hard driving (30m+, 7100rpm, 100%thr).
Moral of the story: You're doing just fine |
05-09-2011, 10:20 PM | #10 | |
25
Rep 171
My question is, does the curve continue as the temperature rises above 210F, or is any temperature >210F always the SAE viscosity? If the curve continues, our cars, which run much hotter than 210F, may benefit from a lower viscosity oil that thickens to a higher-than-advertised viscosity at 250F. As for everyone else's replies... thank you for allowing me to be normal. I really thought I was running on the hot side, especially since the oil from the factory, which I used until 1700 miles, ran much cooler, around 230-235F. Maybe that was just a fluke. Last edited by Revelate; 05-09-2011 at 10:31 PM.. Reason: Grammar |
05-10-2011, 12:30 AM | #12 |
1518
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
i drove 400 miles today in my 08 - oil temp steadily hung in the same range as your photo.
05-10-2011, 01:19 AM | #13 |
187
Rep 645
Ive noticed that the normal temp. fluctuates alot. I rarely drive over 3k rpms on a day to day basis, due to traffic and it still fluctuates. I've noticed that the temp has been going up on a couple degrees since delivery and I'm going to raise that concern to my rep next time. I'm thinking maybe he coolant should be flushed out?
Myles |
05-10-2011, 06:14 AM | #15 | |
124
Rep 1,362
05-10-2011, 06:39 AM | #16 |
124
Rep 1,362
"Obviously a 10W-10 motor oil won't have the film strength to prevent engine wear at full operating temperature like a 5W-20, 10W-30 or 5W-30 motor oil for example."
http://www.upmpg.com/tech_articles/motoroil_viscosity/ |
05-10-2011, 03:17 PM | #17 |
41
Rep 1,177
This is normal..
Alpine White, Coral RED , Glacier Silver Aluminum trim, M sport, 6MT, NAV, HiFi, USB-iPod, Bluetooth
Performance: JB4|BMW PE|DP Cosmetics: BMW Sport Pedals|Black Kidney Grill |
05-10-2011, 03:33 PM | #19 |
European Editor
10589
Rep 22,992
This is where my oil temp stays most of the time. This is with using German Castrol RS Edge 0w40 LL-4 engine oil. When I used Mobil-1's 0w40 LL1 eurpean blend oil.. my oil temos were two to three needle widths higher.
05-10-2011, 04:31 PM | #21 |
117
Rep 1,664
Drives: E82 N55 DCT
definitely normal. mine typically sits right around 250.
05-10-2011, 04:41 PM | #22 |
3441
Rep 79,211
Normal. As long as your not exceeding 250 its normal operating temp for these cars.
Thermostat opens gradually in the ~230 range and opens full around ~245F. |
