05-08-2011, 08:18 AM | #1 |
Rep 218
After a real hot day or spirited driving does anyone
lift their 135's engine hood to alleviate heat? I've noticed that my 1'er gets hot as hell after driving stop and go, or spirited...just wondering if doing the hood pop in the garage would help preserve engine parts over time.
My 04 S4 4.2L V8 gets hotter than any vehicle I've owned..enough that my feet get hot. Anyway, alot of S4 owners would lift the hood after a drive to help cool down. Am I just being neurotic??
08 135i |Alpine White w/ Terra Boston Leather|Sport Pkg| Premium Pkg| Shadowline| Gloss Black Trim| Nav| Comfort Access| Active Steering| Steptronic| Htd Seats| Prem. Sound/Sirius| Park Distance| PPK 1|BMS 4LED|M3 Sway Bar
05-08-2011, 10:16 AM | #3 |
217
Rep 1,489
BINGO!!! You and I must be the only ones. I too a former A4 1.8tmq owner, i did this for the last 11 years.
In the summer months when i pull the 1er in the garage, pop the hood every time. On a really hot days/spirited driving, open hood/and place a floor fan in front of the car for better cooling. Heat cycles is what "KILLS" every thing under the hood. From vacuum lines to rubber hoses, to all the different plastics, down to the engine block...... This sounds very OCD, but i works, My A4 looked like a brand new car under the hood...... So...........yeah, you are not the only one
-Diplomacy is saying, "nice doggie while trying to find a rock"-
07-Z4 coupe-Black/Black/6MT/sport/premium/X 04-M3 vert-Black/Imolla/6MT/Cold/Xenon/HK/ 06-M3 Coupe-Mystic/Black/6MT/ZCP/Xenon/HK/ 09-135i- AW/Bk-Lette/6MT/M-pac/Nav/Hi-Fi/Usb-Ipod/SOLD |
05-08-2011, 10:58 AM | #4 |
184
Rep 3,939
It's a turbocharged engine...all components were designed to withstand high temperatures as this is common in force-inducted setups. I see the effort in what you do, but frankly, I don't believe it will make any difference over time in terms of engine durability. Just look at how quickly your engine's rpm's fall on a cold startup, indicative of little time it takes for the engine to come up to operating temperatures.
05-08-2011, 10:58 AM | #5 |
Rep 35
05-08-2011, 11:00 AM | #6 |
184
Rep 3,939
05-09-2011, 03:54 PM | #7 | |
15
Rep 290
-my opinion
________________
BMS DCI | AR Catless DP's | ETS FMIC | E38 Map Cobb Protuned by Jake@PTF 2012 BMW 335is: 11.926 @ 117.710 MPH (stock runflats) |
05-09-2011, 04:04 PM | #8 | |
184
Rep 3,939
Also, the act of leaving the car running before shut off is referred to as "turbo-timing", which allows for oil/coolant (depending on the type of turbo) to continue circulating through the ducts inside the turbocharger to help it achieve a safer cool down - this helps preserve the shaft seals/bearings. |
05-09-2011, 04:05 PM | #9 |
2452
Rep 7,341
You're probably doing more harm than anything by doing this. Leave the hood down and let the temp slowly decrease.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold |
05-09-2011, 04:07 PM | #10 | |
15
Rep 290
________________
05-09-2011, 04:33 PM | #11 |
15
Rep 220
I come from electrical engineering, not mechanical or automotive but at least with electronics fast changes in temperature are a problem. It comes from parts that are bonded together (bolted, soldered, whatever) that have different rates and direction of size change with temperature.
I have no idea whether opening the hood helps or not but it might keep the paint from getting too hot and discoloring.
2012 Alpine White 135i | DCT | Dinan Stage 3 | ER Charge Pipe | P3 Cars Boost Gauge | Performance Suspension | Terracotta Leather | M Sport Pkg | Premium Pkg | Heated Seats | Comfort Access |
05-09-2011, 04:37 PM | #12 |
2452
Rep 7,341
That's the only possible benefit I can see.
05-11-2011, 12:07 PM | #14 |
Rep 12
I would think of it like Heat-Treating metals - if you heat it up and rapidly cool a material, such as a quenching bath, you cause embrittlement of the chemical structure.
I agree that you should let the car cool on it's own just to make the change that extra bit more gradual. Of course opening the hood isn't like throwing ice water on the engine, but given the experiments I've run and things I've seen I'd like it to be as slow and gradual as possible. |
05-11-2011, 12:45 PM | #15 |
Opus Angelus
426
Rep 1,267
While there may be some benefit, I doubt it's enough to be significant. Heat is just one of the variables in the enviroment that determines how fast a car wears.
I drive around in 100+ temps 5 months of the year, probably means my car will wear faster than somebody in Canada, but I doubt not by enough for them to really care about it. |
05-11-2011, 10:25 PM | #16 |
Former Opel GT Pilot
327
Rep 771
05-12-2011, 06:15 AM | #17 |
184
Rep 3,939
lol not at all. I hate to put it in these terms, but without offending anyone, this thread is as irrelevant as it gets. Winter, summer, whatever, no matter how much longer or shorter it takes to cool down, it is not an abrupt change for the engine.
05-12-2011, 09:38 AM | #18 |
105
Rep 2,696
I do it only at track days in between sessions only.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
