      05-08-2011, 07:46 AM   #1
burger16b
burger16b's Avatar
13
Drives: 135i
why marks on tires?
ok so it may be a dumb question but why do people put what looks to be paint or chalk marks on there tires while racing? iv'e seen it on drag cars and auto-x but don't know why its done
      05-08-2011, 08:13 AM   #2
1fastbmw
1fastbmw's Avatar
23
Drives: 2009 135i
2009 135i  [10.00]
I believe the reason is so you can see wheel spin, usaully at the drag strip someone is watching to see if the tires break loose on launch, I can only guess auto-x is simular.
JB4 l Berk AB l AP Mids l PLM DP's l RSD CP l Injen CAI l BSH OCC l ETS FMIC l Koni FSD's l BMW Performance Springs l Complete M3 Frt & Rear l Dinan Shock Mnts & Camber Plates l Quaife LSD l Morel Speakers l Zapco Amps l BMW SS Pedals l Pearlescent Brake Handle l 30% Tint l ICarbon Dry Diffuser l Matte / Gloss Grills l Black 135i emblem l P3 V2 Gauge l SF-71's l Conti DW's 235/265-19's l LCI Tails l Lux H8
      05-08-2011, 08:46 AM   #3
aisthetes
aisthetes's Avatar
13
Drives: 2013 M3 Competition
In autocross you mark edge of the tire tread to check how much tire rollover you're getting around turns. If the chalk wears off, you need more air pressure to maximize your tire contact patch.
      05-08-2011, 12:18 PM   #4
ucbsupafly
Drives: 2008 BMW 135i
What he said. White shoe polish usually gets the job done.
      05-11-2011, 07:46 PM   #5
burger16b
burger16b's Avatar
13
Drives: 135i
thanks always was curious
      05-12-2011, 09:00 AM   #6
MrBlonde
MrBlonde's Avatar
Australia
122
Drives: Audi TTRS, M Coupe, 1299
The chalk mark on drag racing slicks is to see how much the slick is rotating inside the bead locks (ie slick moving inside the rim).
.-=[ Kenny ]=-. 1999 BMW M Coupe 10.775 @ 134.35 mph w/1.600 60' (Best 136.07 mph) 25th August 2004. +2010 X5 35D+
Check out the 1Addicts Drag Racing Standings and Drag Racing 101.
      05-12-2011, 12:08 PM   #7
and 1
winter mode
and 1's Avatar
Italy
62
Drives: 08 135i, 88 M3
1988 BMW M3  [0.00]
2008 135i  [7.50]
the title of this thread made me wonder why star specs have those red and yellow dots (1 of each) on the sidewall
88 M3: BMWCCA J Sport
08 135: because streetcar
      05-12-2011, 02:14 PM   #8
Clap135
Clap135's Avatar
102
Drives: 2009 N54
Originally Posted by TrackRat View Post
The tires should not be slipping on the wheel. They beadlock replaces the screws they use to use to prevent the tire from slipping or dismounting in the case of a loss of air.
I guess you havnt seen a honda idiot at 7psi spinning the wheel inside the tire have you? usually people mark this to make sure the mark still lines up at the end of the run.
      05-20-2011, 04:54 PM   #9
chili555
13
Drives: M3 DCT coupe
If you are a bit scientific, in road racing, you'd like to see how many heat cycles it takes for a DOT race tire to go from very grippy to kinda grippy to slick as a brick. Budget allowing, you'd like to look at the tires with five or so hash marks on them and march over to the tire vendor's trailer for replacements.
What, you didn't mark your tires after every session? Well, I guess for Sunday afternoon's 45 minute race that decides the regional championship, you'll be racing on...God knows what. Myself, I have a set safely tucked away at the back of my trailer with but one mark on them; known in the larger world as scuffs.
See you on the grid!
      05-20-2011, 06:33 PM   #10
Eddy@ApexWheels
Eddy@ApexWheels's Avatar
445
Drives: E30 M3, F10 M5
That is there to aid in proper balancing of the wheel/tire during install. One of the dots is lined up with the valve stem to help compensate for the high/low spots of the tire as they are not perfectly molded.
      05-21-2011, 09:05 AM   #11
bradford
28
Drives: 2008 SGM 135i
Skip the shoe polish and use the triangles molded into the tire as the manufacturer intended.
      05-23-2011, 11:08 AM   #12
and 1
winter mode
and 1's Avatar
Italy
62
1988 BMW M3  [0.00]
2008 135i  [7.50]
only tough part with that is gauging intermittent wear. you can see how far you've worn down in general, but tough to tell in between runs as you adjust pressures
either of the dots?
      05-24-2011, 07:20 AM   #13
MrBlonde
MrBlonde's Avatar
Australia
122
Exactly, that's why they use the marks, to ensure the aired down slicks are NOT rotating inside the rim.
      05-24-2011, 07:47 AM   #14
JimD
JimD's Avatar
368
Drives: 128i convertible
I do not know about drag racing but there is an interesting piece in the Roundel several months back for determining tire pressure for track days (including autocross). I used the white stuff they sell at autoparts stores for marking windshields when you are selling a car. It's cheap. You mark the sidewall where the little triangles are moulded into the sidewall to mark the edge of the tread. You want the tread on the pavement, not the sidewall. I determined I need to be about 40 psi front and back for autocross. Less pressure and the white was removed from the sidewall.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
1addicts
