BMW E60 5-Series Forum | 5Post.com
Go Back   BMW E60 5-Series Forum | 5Post.com > BMW 5-Series (E60) Forums (2004 - 2009) > General 5-series and M5 (E60) Forum
Closed Thread
      05-05-2011, 11:04 PM   #1
Sean@PYSpeed.com
Sean@PYSpeed.com's Avatar
306
Drives: 2009 AW E92 M3
PYSpeed.com | COBB AccessPORT - 2008-2010 BMW E60 E61 535i/xi/xDrive
PRODUCT DESCRIPTION
COBB Tuning is no stranger to engine tuning over the years, with their success in the Subaru Impreza WRX/STi, and Nissan Skyline GTR. They have nailed their software and installation procedures down to the bare simplicity, reliability and more support you can ever imagine.
Introducing the COBB Tuning AccessPORT for the 2008-2010 BMW 135i, 335i and 535i vehicles equipped with the N54 twin turbo engine. The AccessPORT brings hand-held ECU flashing, managing and monitoring convenience to BMW, unleashing untapped power hidden in the ECU with just the push of a button. The AccessPORT lets you quickly reprogram your car’s ECU with performance-tuned calibrations for instant power gains without any tools, wiring, soldering or downtime. Simply plug the AccessPORT into your car, upload the desired maps, and unleashethe new power band and torque curves out of your factory to highly modified N54 twin turbo powered BMW.
The AccessPORT puts you in control. Installing the AccessPORT is a breeze. Typical installation takes less than 20 minutes from the comfort of your driver seat and is able to store multiple calibrations, making map switching easy with just the touch of a button. Choose from many pre-tuned maps for different levels of modifications and types of fuels and be ready for any situation. For extreme modifications or maximum power output, the COBB Pro network can custom tune your setup on a dyno using their soon to be released AccessTUNER Pro tuning software.
Flashing the ECU for increased performance is just the start of what the AccessPORT is capable of. It can capture 0-60MPH times, ¼ Mile times and Trap Speeds. Switch over to Live Data and choose a gauge to monitor, such as; oil temperature, intake air temperature, throttle position, ignition timing, boost, MAF voltage, air/fuel ratio and many more. Select the integrated Data Logging function to record multiple channels of data for up to 10 hours for in-depth performance analysis. Go to Troubleshooting mode to diagnose issues by reading trouble codes and resetting the system once the issues have been resolved. Users can even configure the AccessPORT as a shift light that flashes the screen at whatever RPM you choose. In times where you are not driving the vehicle. You can protect your investment. You can quickly load the Valet map to limit engine revs and boost and when it’s necessary to remove the AccessPORT, the uninstall process is simple, taking under 10 minutes and restoring the ECU to its original condition. The AccessPORT can be installed and uninstalled as many times as needed without fuss or hassle.
The AccessPORT from COBB Tuning is the most comprehensive hand-held ECU flashing, managing and monitoring device available for 2008-2010 BMW 135i, 335i and 535i vehicles. Satisfy your hunger for more power and control. Access the potential of your BMW today!
FEATURES
* Incredible power gains are just a few clicks and a flash away.
* Sophisticated logic of the OEM ECU remains intact, providing refined response, excellent driveability and precise control.
* Hand-held flashing lets you control what is stored on the ECU, when-ever and where-ever you want.
* Installs in just minutes through the OBD-II connector. No tools or other actions are necessary. Simply flash and drive.
* Grows with your modifications by changing maps that match your mods.
* Select from Off-The-Shelf maps to match your modifications or take your BMW to a Pro Tuner for professional dyno calibration.
* Uninstalls just as easily and returns ECU to stock configuration.
* Conveniently data log sensor values for up to 10 hours to perform.
* Vibrant-color, user-configurable auxillary gauge. Live Data lets you view real-time data from any of the data channels that can be data logged.
* Performane tools record 0-60mph times and 1/4 mile ET and Trap Speed. See real world impact of modifications and tuning changes.
* Intuitive DTC code reading provides the trouble code and a brief description to help diagnose issues easily. Reset the ECU to clear codes at your convenience.
* 30 Day Satisfaction Guarantee.
TYPICAL PERFORMANCE GAINS
Stage 1 Map (See Modification Requirements HERE )
* BMW 135i - +28.3% (+78) Peak HP & +31.8% (+91) Peak TQ with 93 Octane
* BMW 335i - +30% (+73) Peak HP & +38% (+105) Peak TQ with 93 Octane
* BMW 535i - +19.2% (+44) Peak HP & +30.5% (+80) Peak TQ with 93 Octane
Stage 2 Map - In Development
INSTALLATION & TUTORIALS
      05-06-2011, 12:04 PM   #2
Glowin
Glowin's Avatar
73
Drives: X3 35 & 335i now - M2/M4 next?
Hi there, I had asked Cobb about 3 months ago why their 535 map only produced a bump of 19% in HP, whereas the 335 map for the same engine produced 30%, which is a huge difference. The difference in torque is somewhat big too.
I was told by Rob it wasn't the difference b/w the cars' parts (like exhaust) and this was the reason:
Originally Posted by Rob@Cobb View Post
The tunes are the same between the 135/335/535 given the similarity of parts. The 535i that we had access to simply made less power. We now know it needs to have it's WGs tightened or replaced. We simply released conservative dyno maps for the 535i given we didn't want to give the typical power range.
We will be re-dynoing the 535i once it's mechanically sound and/or looking for another 535i to re-create our dyno graph off of.
Cheers,
Rob
I haven't yet seen an update from them on their dyno, and see that the official numbers are still the lower ones.
Any chance you can speak with them and give us an update? Hopefully we can get similar numbers posted soon, as it seems odd there'd be such a big difference on the same engine with different cars.
      05-20-2011, 02:59 PM   #3
Glowin
Glowin's Avatar
73
Bump for reply to my post above?
      05-23-2011, 03:14 PM   #4
Sean@PYSpeed.com
306
I have put your inquiry out already. We are waiting for info from cobb! Thanks
      05-23-2011, 05:05 PM   #5
Glowin
Glowin's Avatar
73
Great to hear, thanks!
It would be awesome to get this sorted out, since as you've probably heard, Evolve just came out with their handheld flasher, and they're saying that their tune produces the same power on the 535 as on the 335 (though a dyno hasn't been done on a 535).
      05-25-2011, 04:15 PM   #6
Sean@PYSpeed.com
306
We will definitely let the crowd know about your inquiry when we get it. Thanks
      05-26-2011, 03:34 PM   #7
Sean@PYSpeed.com
306
Thanks for all your support!
      05-27-2011, 12:51 PM   #8
Sean@PYSpeed.com
306
All PMs responded... Thanks
      05-28-2011, 06:39 PM   #9
Sean@PYSpeed.com
306
We have very competitive pricing! PM me for specials!
      05-30-2011, 05:55 PM   #10
Sean@PYSpeed.com
306
PM me for specials!
      06-06-2011, 02:47 PM   #11
Glowin
Glowin's Avatar
73
Hey Sean, check your PM!
      06-10-2011, 05:22 PM   #12
Sean@PYSpeed.com
306
Thanks for the inquiries! Please check out our website or PM us for more products and info!
      06-11-2011, 12:02 PM   #13
Sean@PYSpeed.com
306
Thanks for the inquiries! Please check out our website or PM us for more products and info! =)
      06-14-2011, 03:45 PM   #14
Sean@PYSpeed.com
306
Thanks for the orders!
      06-15-2011, 02:34 PM   #15
Sean@PYSpeed.com
306
We have put in several orders for Cobb AP. Thanks for all your support.
Please PM me for special pricing.
      06-16-2011, 11:47 PM   #16
Sean@PYSpeed.com
306
      06-17-2011, 11:36 PM   #17
Sean@PYSpeed.com
306
      06-19-2011, 10:36 PM   #18
Sean@PYSpeed.com
306
      06-20-2011, 03:49 PM   #19
Sean@PYSpeed.com
306
      06-27-2011, 09:32 PM   #20
Sean@PYSpeed.com
306
      07-03-2011, 10:03 PM   #21
Sean@PYSpeed.com
306
      07-06-2011, 01:57 PM   #22
Sean@PYSpeed.com
306
Closed Thread
5post
