04-25-2011, 11:26 PM | #1 |
20
Rep 231
FS: E85 Z4 Coilover Kit [SOLD]
[SOLD] This is a coilover kit based on Koni shocks and the Ground Control Coilover Conversion. The following is included: One set of two brand new Koni externally adjustable rear shocks from TCKline. ($400) Two used Koni front externally adjustable shocks. ($100) Four springs: 440# (2) 2.5" x 6" and 550# (2) 2.5" beehive 6.5" ($200) Two used Ground Control rear height adjusters and centering cones ($50) Two used Ground Control front coilover perch sleeves and height adjusters ($50) Two TCKline rear shock mounts in excellent condition ($50) The total cost for these items is $850. I am willing to install at no cost for anyone living in the Northern VA area. The only additional parts that are suggested are camber plates (although not necessary), and a set of bump stops for the front shocks (I cannot find them. They are under $20.) These are for an E85 Z4 and came off of a 2004 3.0i which now has AST4100 shocks. I also have a wide range of other springs available.
FS: Leather Recaro Pole Position Seats & Hardware Last edited by nlink720; 04-30-2011 at 08:09 PM.. Reason: SOLD |
04-27-2011, 02:10 PM | #3 |
479
Rep 2,782
Drives: ESS/G-Power Z4M, VF Z4, 996tt
How many miles/track events are on the front shocks? I'm trying to figure out how much life is left in them. Thanks!
04-27-2011, 02:19 PM | #4 |
442
Rep 2,747
Great price, good luck with your sale
LINK TO 07 IR PHOTO JOURNAL:http://www.zpost.com/forums/showthread.php?t=1303735
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 |
04-27-2011, 02:46 PM | #5 |
20
Rep 231
The fronts have about 20,000 miles on them. I will be honest in that they are in very good operating condition, but do not look so super from an aesthetic perspective. I am basically giving the fronts away. I think I factored in about $50 each on them. The fronts are relatively cheap anyway. The rear externally adjustable shocks are the specialty item, and are much more expensive. They are also brand new.
##POST UPDATE## The following items have sold: 440# springs 550# springs Rear height adjusters and associated accessories. The coilover system still exists, but the purchaser would have to buy the rear height adjustment accessories, and choose a different spring stiffness. I have springs in: 550/650/700/800 remaining. The rear externally adjustable shocks will be listed on other forums shortly as well. They are compatible with the E36/E46/E85/E86. See Here:http://www.tcklineracing.com/webdocs.../Details30.cfm
FS: Leather Recaro Pole Position Seats & Hardware |
04-27-2011, 02:58 PM | #6 | |
CarbonFiber Engineer @ ZeroMassMotorsports
40
Rep 1,481
I'm curious as to whether the S.I. mount points will collectively fit these 04' mfr. date components ??
04-27-2011, 03:02 PM | #7 |
479
Rep 2,782
I'll take all 4 shocks, assuming they will work on an unmodified 2003 3.0i sport. PM sent!
04-27-2011, 03:34 PM | #9 |
20
Rep 231
Correct. 6" x 2.5" x 550. Eibach Race. Pic if you need. Springs not part of the conversion kit will be at 60% of new. I sold the conversion kit springs ( 440/550 ) at less because they were barrel springs, which I did not want/use, and which that buyer actually did want/ will use on his E46.
