KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
03-16-2011, 05:24 PM | #1 |
Rep 54
W220 need help with tire sizes please within 24 HRS!
Hey would appreciate it if ppl can help me pick out a tire size with the 220 M3 stock rims. What im looking for is a agressive but practical look that CLEARS. I'm not a tire wheel guy that would know what sizes and measurements I should use so can anyone please give me a list of tires that would be good for my stock 220 WHEELS
please people post with ur current setup WITH the stock 220 wheels and if it CLEARS 100% thanks! 265 30 19? 295 30 19? let me know please because i need to order tires in 1-2 days! Last edited by Silent9o8; 03-16-2011 at 05:34 PM.. |
03-16-2011, 05:28 PM | #2 |
BimmerPost Supporting Vendor
1007
Rep 4,619
OEM sizes 19x8.5 and 19x9.5 and tires are 245/35/19 and 265/35/19 respectively,
I would stay with the same size in the front and change the rear to a 275/35/19 or a 275/30/19. Both fit well. The reason for the upgrade is that the 265/35/19 size is a very odd size and it seems like not many other cars run it other than E9X M3's, thus making the price a lot higher than the more standard 275/35 and 275/30. Good luck. |
03-16-2011, 06:27 PM | #4 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
I would up-size both the front and rear tires equally (10mm). 255/35/19 in the front and 275/35/19 in the rear. Numerous people have run these sizes on the stock wheels without problems. This is approximately the 10th thread asking this same question....
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
03-16-2011, 07:10 PM | #5 |
151
Rep 1,599
Some Factors to Consider
You want to look at the minimum rim width that the tires you are interested in are designed to accommodate and the revs/mile of the rear tire (primarily for speedo accuracy). This information is all on the Tire Rack site for tires that they sell and should also be available on the specific tire manufacturer's sites.
For example, with PS2's on your 220's, the widest tire you can put on the front is a 255 and the widest tire you can put on the rear is a 285. Assuming your speedo reads fast (like mine), a 275/35 is a much better choice than a 275/30 as it will slow your speedo down by about 1% vs speeding it up by another 3% with the 30 series tire (based on published tire revolutions per mile data).
03-16-2011, 08:47 PM | #6 |
258
Rep 5,012
Your only 2 realistic choices are between 245/275 or 255/275, all 35%s, like stock. I wanted stock sizes, but since I want an ultra-high-performance all-season, nobody makes them in 265, so have no choice but to get 275s. What I'm not sure is if 245 or 255 in the front. With 245s, drag will be less and fuel mileage won't decrease even more, but car would be raised a bit from the rear only, looking even more of a 4x4. And it could also possibly cause issues with the DSC, no? With 255s, the stock stagger and stock stance would be stock, albeit the car would be evenly raised a little. I don't track the car, so don't particularly care about the improved understeer the 255s would provide. Good luck.
03-16-2011, 09:42 PM | #7 | |
876
Rep 3,450
285/30 is a bit too short, so 275/30 would be way too short (someone suggested that above). |
03-17-2011, 12:48 AM | #8 |
258
Rep 5,012
Thanks man. And since Michelins run a bit wider than usual, it's possible the difference might be smaller than the math suggests. The only problem now is the DWSs are backordered until the end of days, so back to square one. Will try to google another tire dealer, but unless miraculously in stock, it's going to be the same story. Take care.
03-17-2011, 04:57 AM | #9 |
Rep 54
NICE THANKS this will be a good post for future searches 255/35 275 35 IT IS!
2 VREDESTEIN 255/35/19 FRONT ULTRA SESSANTA 2 VREDESTEIN 275/35/19 REAR ULTRAC SESSANTA 915.00 good good? Last edited by Silent9o8; 03-17-2011 at 05:06 AM.. |
03-17-2011, 12:40 PM | #10 |
151
Rep 1,599
Sounds good to me. It's the sizes you want. The cost is a bit more than I paid last spring, but I've heard the cost is up as the tires have gotten more popular. It takes a while for the tires to scrub in (up to 800 miles); so, don't be disappointed if they are a little skittish initially.
