03-15-2011, 11:49 PM | #1 |
Rep 56
Creaking Noises and funny window alignment
I get a lot of creaking noises from behind my left ear. It appears to come from the rear window, but I can seem to get a finger on it to localise it. I also get some creeking coming from what seems to be the cabling near my right ear where the roof joinery is. This is constant when on slightly uneven ground...
My second problem is the drivers window. From time to time, the window seems to malalign. It then wont go up, and insists on going down everytime it is moved to the top. If I try to get out of the car when the window is fullyup, it doesn't go down that inch like normal. It stays up, and then the car door doesn't shut properly because the window is malaligned. It doesn't happen often. Perhaps once every 2 weeks. I'm not sure how it all happens. To fix it, I have to wind the window all the way down and all the way back up, along with the tiny rear side windows... Any ideas?
www.AustralianSharesForum.com - Get a free BRW subscription.
03-16-2011, 01:02 AM | #2 |
Criminally Insane
53
Rep 1,464
Drives: Like a Demon!
There is a replacement seal kit that is supposed to fix the window closing and some of the creaking issues.
There are multiple adjustments they can make to fix the creaks and squeaks. But if mine is an indication they may come back. Never mind. I'll just ask them to keep fixing them.
Dr Stig 2010 Z4 35is 2011 X3 30d M Sport Australia |
03-16-2011, 04:45 AM | #3 | |
Rep 82
03-21-2011, 09:27 PM | #5 |
62
Rep 2,087
That's because they typically have hard polyurethane bushings verses the standard OEM style synthetic rubber bushings, but did he say he changed the suspension or is that in the other thread?
"Political correctness is a doctrine fostered by a delusional liberal minority and rabidly promoted by an unscrupulous mainstream media which holds forth the proposition that it is entirely possible to pick up a turd by the clean end".-- Unknown
03-22-2011, 01:42 AM | #6 |
Rep 56
Nope, I didn't change anything. My car is totally stock from factory.
03-22-2011, 05:42 PM | #7 |
Criminally Insane
53
Rep 1,464
If you have seen the movie "UP" the you would be familiar with the reference to "SQUIRREL!"
03-23-2011, 12:11 AM | #8 | |
62
Rep 2,087
Yes, I recall the use very vividly!
03-24-2011, 03:59 PM | #9 |
Criminally Insane
53
Rep 1,464
Whereas in my family we scream out SQUIRREL often whenever someone changes the topic.
And we don't even have the rodents here in Oz
03-25-2011, 11:25 PM | #10 |
62
Rep 2,087
Clearly that fits - I read the OPs post 3 times just in case I missed something
Just goes to show that Squirrel behavior is a universal symbol, even if the animal is not indigenous to Land of Oz
03-26-2011, 07:41 AM | #11 | |
Happy Camper
613
Rep 7,869
Drives: C63 AMG & 280 SL on Weekends :
Garage List 1969 Restored Merce ... [7.50]
2011 M3 Coupe TRADED [7.34] 1987 BMW 535is [1.00] Cars from the Past [6.50] The ///M3 Engine S65 [9.59] |
No worries, most of the noises will disappear once it gets warmer Cheers, Rolf-Dieter
Cheers, Rolf-Dieter
Life will take us to some interesting places, fortunately The ///M3 will too with a many of us know this very well, now my C6.3 AMG with 487 HP does it too ---> Click here for some good stuff I found |
03-29-2011, 04:33 AM | #12 |
Rep 5
Dr Stig 2, you say there is a replacement seal kit for the window rattle in the Z4. Do you have any more info about it? I have the same rattle. They mechanic has tried four times to fix it but it keeps coming back in about a day or two. It seems Mt Nebo is enough to test out any rattle repair.
Cheers |
03-29-2011, 12:43 PM | #13 |
1911
Rep 5,106
Can't speak to the window alignment, since this wasn't an issue in my case. However, the fix for the creaking roof is slightly more complex than some have noted above (not simply a "lube & tighten" job).
I had this addressed last fall before storing my car and it fixed the problem. Also, it doesn't "go away in warmer weather" - happens all the time. Hope this helps Dave From the repair invoice: C/S: Creak in roof behind driver side, over bumps. Most likely driver's side B Shell Latch incorrectly positioned. Road tested vehicle & found rattle / creak noise from roof. Removed headliner on A & B roof shells. Road tested vehicle once again. Found noise from driver's side latch area. Lubricated latch and road tested again. Noise still present. Performed adjustment at position rod to latch, adjustment at rod. Noise gone. Reinstalled headliner trims & road tested again. No noise after repair. Work time used for adjusting rod 2 times.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
03-29-2011, 08:55 PM | #14 | |
Criminally Insane
53
Rep 1,464
Are you in Brisbane? Which side of town? I'm out west on the very edge of town.
03-30-2011, 02:36 AM | #15 | |
Rep 5
Southside Holland Park. I am keen to see how you go. The guys at Motorline have been really good, but this is one last creak that is puzzling. They eliminated 4 or 5 other ones in the roof. For this window issue, they dropped the window down a millimeter or so and temporarily it worked but it is back again. |
04-03-2011, 06:14 PM | #17 |
Criminally Insane
53
Rep 1,464
DrDr
I'll hAve the part number tomorrow night. They fitted it to a 335 conv on Friday and it fixed the problems. I want to see if it fixes mine before I endorse it. It costs $900 plus labour, so I see why BMW is not rolling them out to everyone. Mind you, the steering rack replacement won't leave much change from $5k so they do spend when they have to.
04-04-2011, 09:12 AM | #18 | |
Rep 5
What's wrong with your steering rack? More to look forward too? Cheers |
04-04-2011, 10:17 AM | #19 |
63
Rep 432
Drives: Z4 E89
My rattle noises came from the speaker grills on rear (both sides) waiting for 3 months now for replacement
04-05-2011, 05:05 AM | #20 |
Criminally Insane
53
Rep 1,464
DrDr
I have had the window seal kit fitted. It doesn't stop any rattles. It is mire about the open - close- open again problem that the windows do when you open and close the roof. Ie I still have rattles from the roof mechanisms when the roof is up. Do you still want the part number?
04-05-2011, 07:00 AM | #21 | |
4440
Rep 5,733
Drives: '24 iX50; '23 i4 M50
I had this same problem this morning, but with driver's side. In the past, I would get the annoying "pinch protector" effect from my driver's side window after using the automatic roll up function (i.e., pull up window toggle once and the the window would roll all the way back down as it met the roof). However this morning, I had the roof down and put it back up, and although my driver's window rolled up all the way, when I went to exit the car, the window would not lower the normal 2in. As I went to shut the door, it did not shut properly. I thought it might have the roof misaligned, but I was unable to lower the roof, b/c the driver's side window would not go down during the sequence. Keep in mind this was all happening right before some severe downpours. Eventually, I turned on/off the car, and luckily the window resumed its normal function. I think I have my eye on a 1M....
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
04-05-2011, 07:13 PM | #22 | |
Rep 5
Pity about the rattles. I am getting the opening and closing problem now too, so it wouldn't hurt getting the part number. Let me know if you cannot post on the site and I will give you an email address. For the rattles, I have had some success. Maybe we should meet and exchange notes. Let me know. There is a good cafe on Mt Glorious. Cheers |
