03-15-2011, 04:16 AM | #1 |
Statistical Consultancy (Medical / Pharma)
Rep 150
Breyton GTS-R - playing it safe with a little risk...
So, after months of offset calculations and running through possible tire choices, I finally ordered my new summer wheels / suspension combo. I'm gonna go with:
-Eibach pro kit springs -Breyton GTS-R in plain Hyper Silver, in the following sizes: Front: 7,5x18 ET35 Rear : 8,5x18 ET38 A well known combo, not taking any chances on colors neither. Why breytons? 1-I want to keep on using the RFT in OEM sizes. I know some will call me crazy but I have to drive around to clients all the time and the RFT technology assures me I will always get there without delays. 2-They're light - don't need to elaborate why that's a good thing 3-CSL style might be overdone, but I think the style suits our 1 perfectly... However, I decided to use the new offsets, which are front and rear 10mm wider than the regular "1-offsets". I did this because it seems like the standard GTS-R are still a bit too "tucked in", looking at several members' pictures. In the front, this shouldn't be a prob. I see many members using 15mm spacers up front on the OEM wheels: Breyton 7,5x18 ET35 would be similar to running a 14mm spacer on the OEM wheels. At the rear, I might have minor issues, because an ET38 is again similar to running a 14mm spacer on the OEM. I saw 1 member using a 12mm without issues, but as all experienced members know, every mm counts . So, I expect to have minor rub in the rear, which I want to remove by adding 1degree of camber extra. This should add sufficient clearance, I think... (if not, I'll have to roll the arches a bit). Expected delivery is 2 weeks... I'll keep you all updated! Cheers, Erik |
03-15-2011, 06:51 AM | #3 |
Rep 150
Ordering from my local tire supplier (Vulco belgium).
Apparently, the concavity should be similar to the ET45/48 versions... We'll see soon... |
03-15-2011, 07:21 AM | #5 |
Rep 150
Well, Vulco does not sell online.
You can check out www.felgenoutlet.de . A german site, and there they list all the possible offsets... price is similar to what I will pay... Good luck! E |
03-15-2011, 07:31 AM | #6 |
154
Rep 4,528
Drives: M2 CS
keep us posted, be sure to post pics when you get them
03-15-2011, 08:07 AM | #7 |
Rep 150
03-15-2011, 11:05 AM | #10 |
211
Rep 2,233
Here's a pic of my car with a standard offset GTS-R on the front (Tire Rack does not list the offset) and OEM tire. Suspension is Eibach/Koni FSD. Not sure I would have gone with lower offset wheels but I will be curious to see your pics.
03-16-2011, 03:28 AM | #11 | |
Rep 150
Might be the angle of the picture, it's a bit strange to look at it that way. Do you have other pics? Or do you still have this wheel, so you can look at the ET stamp...? |
03-16-2011, 06:49 AM | #12 |
Rep 150
BAD NEWS !!!
The guys at Breyton confirmed GTS-R only exist in ET45/48... The ET35/38 is a "mistake" from the German website I found them on. In fact, there are referring to using 10mm breyton spacers... Don't know what I'll do now: use the 10mm (or 5mm rear) spacers from breyton to get these offsets or just look to a whole new set of wheels... (btw, spacers are illegal in Belgium so I'm basically screwed...) |
03-16-2011, 09:50 AM | #14 | |
211
Rep 2,233
http://alufelgenco.com/gb/bmw_e82.php |
03-16-2011, 09:53 AM | #15 |
Rep 150
03-16-2011, 09:54 AM | #16 | |
Rep 150
03-16-2011, 11:03 AM | #17 |
211
Rep 2,233
05-28-2011, 10:12 AM | #18 |
Rep 150
Wheels FINALLY delivered...grrrr more than 2months wait... Gonna make an appointment for next week. Decided to go with 5mm spacers all around, pics will follow :-]
