03-12-2011, 04:08 PM | #1 |
47
Rep 431
Trying the 1/4 mile for the first time tomorrow at PBIR, any launch tips for DCT?
I have lot's of road racing experience and I've done a few Florida Mile runs but, never had to be concerned about getting a good launch. Any tips for 1/4 mile launch with DCT. I tried the stock launch control setting at the runway and it spun the tires thru 2nd gear. Will being in the "groove" on a dragstrip help with the slippage problems or should I drop the rpm's with the cruise control lever? Love to hear any of your experiences, Thanks in invance, Cheers!
03-12-2011, 06:14 PM | #2 |
44
Rep 436
This car's a bitch to launch at the strip. I know I know it's not a drag car, but still it's fun to try it once. I ended up putting it in D5 with traction control disabled. And I still ended up spinning badly on the 1 -2 transition shift. My 60ft was just terrible in the 2.3 range. Don't go WOT straight from the get-go, you'll load up the DCT transmission and the car will basically do a poor mans launch control (you know what I mean if you've tried this before). Unless your track is sticky as gum I'd avoid the launch control for fear of spinning. My track was really busy so I only got one run. Hopefully you'll be able to try out a few different methods. Do a search on here, there's a little bit more information. Good luck.
03-13-2011, 12:04 AM | #4 |
611
Rep 10,407
LC works great but....
Only if 1. There is not a long line of folks queueing up at the strip. If so your tranny will cool down and you will not be able to us LC - it will be disabled based on the temperature being too low. 2. You have great traction - not a problem at most strips. What worked out best for me on street tires was to use the "pseudo LC mode" by simply mashing the gas way early in the lighting sequence so the revs have time to build and the car launches just at green. My other settings were Drivelogic in D5 and using DSC = MDM, EDC = comfort (to try to allow maximum weight transfer). Since using only street tires I found it best to do one quick burnout with DSC off then just stage up. The burnouts can give some terrible axle hop and I hate that feeling of beating on the car a bit when that happens. Using this technique I was able to get a sub 2 second 60' time, which on street tires I was quite happy with.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
03-13-2011, 01:38 AM | #6 |
M-Flight Member
38
Rep 1,085
at the fırst sıgn of axle hop get off the gas...not cheap to fıx a broken half shaft. I use my Mustang for the 1\4 mıle track...the M ıs for fun cruısıng...and a track wıth turns.
2011 Le Mans Blue M3// Black extended Novillo w/ Blue Grey Aluminum trim/DCT/ZTP/ZCW/ZPP/ZCP Premium Sound ///Akrapovic Evolution Exhaust
2015 Audi S4 Prestige, Brilliant Black S-tronic 2012 Le Mans Blue 135i M Pkg DCT |
03-13-2011, 06:20 PM | #9 | |
611
Rep 10,407
LC lite is the DCTs ability to free rev and pause ever so slightly so that the clutch can be dumped even when not in LC mode formally. It only does this upon very heavy and very large throttle application from a dead stop. I found this along with D5 for perfect redline shifts the best for the drag strip.
03-13-2011, 06:58 PM | #10 |
67
Rep 2,536
03-14-2011, 10:18 AM | #11 |
Moderator
7515
Rep 19,368
03-14-2011, 03:28 PM | #12 | |
611
Rep 10,407
Push the pedal far and fast that's all you have to do. Many do not like it due to the natural delay. The car does simply sit at zero speed and build revs for a brief moment before dumping the clutch. There doesn't appear to be any other possible solution if you want to have it dump the clutch. The consequence in a street race is that the guy with either a normal MT or AT or the fellow using any sort of LC will most likely get a significant jump on you (i.e. in essence you'll have a poor RT). I think it is quite clever - 3 modes - normal take off (the clutch begins moving as soon as the throttle moves), "LC lite" providing that feel of the dumped clutch and then full/formal LC!
03-14-2011, 05:03 PM | #13 | |
47
Rep 431
NSCRA at PBIR on 3/13/11
BEST ET vs ISF Best RT VS ISF Versus the GTR with a mid pipe, look at his RT! Last edited by mike33176; 03-14-2011 at 05:39 PM.. |
03-14-2011, 05:06 PM | #14 |
Track Duty
266
Rep 2,467
03-14-2011, 05:11 PM | #15 |
Moderator
7515
Rep 19,368
Yeah, I've done that on a few occasions on the street. It's nice but, I guess I kind of avoided it at the track due to the delay. I got my best time with LC, but it was nothing to write home about either way since the track was an ice rink.
Great job! Do you have exhaust or other engine mods? Or are you stock. Either way, it's a great effort, and with more practice you could probably be in the low 12s. |
03-14-2011, 08:36 PM | #19 | |
611
Rep 10,407
Great times, I'm assuming you just have AA software and no other performance mods? If so the 12.4X is downright amazing. The best time posted in this giant "database' of ours is 12.5! Nice work on putting the IS-F down as well! My first time at the strip with this car was vs. my buddy in his Challenger SRT8 who was really egging me on. Needless to say even totally botching the RT I still reeled him in...
03-14-2011, 08:41 PM | #20 |
47
Rep 431
No, along with the tune, I have an AA Cat-back and an HFC- Xpipe. I need to address my launch/ RT issues and I will get into the Very low 12's and I think , very high 11's.
03-15-2011, 08:06 PM | #21 |
611
Rep 10,407
^What do you estimate as your crank hp with those mods?
03-15-2011, 09:31 PM | #22 |
Scared money don't make money.
67
Rep 1,448
Drives: 2009 E92 M3 DCT
Nice times brah . It looks like your AA tune is extremely consistent. I saw the same consistency on the dyno when I was running their tune.
2009 E92 M3/DCT/Alpine White/Fox Red/Carbon Leather OE Tuned 402 whp & 303 wtq/Gintani X-pipe/MXP Axle Back/Rogue Pulley/AFE Stage 2/Cosmetics By IND & EAS HUGE THANKS: Gintani, OE Tuning, and EAS |
