KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
03-11-2011, 08:55 AM | #1 |
43
Rep 216
Tire Size Recommendations
Need to replace my rears. I ran 245/35/19 fronts and 285/30/19 rears last year (Advan Sports) and liked the look. Was reading this is too much of a delta for understeer. Should I go down to a 275/30 to match up with the fronts better? 9.5 front wheel and 10 rear with Eibach drop. Thanks!
03-11-2011, 10:01 AM | #2 |
876
Rep 3,450
you would want to do 275/35, not 275/30 (which is too short). that would be my recommendation, and you could switch the fronts to 255/35 when the 245's wear out. this would get you to the OEM stagger - 20mm wider tires in the rear (as opposed to the 40mm wider rears that you have now).
03-11-2011, 10:07 AM | #3 |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
i have 255/35 19" and 275/35 19" PS2s
great handling and slightly higher sidewall so more comfortable than stock |
03-11-2011, 04:30 PM | #5 |
Rep 34
I have a related question. I'll be replacing all four this spring and I'm thinking I'll try out the new SuperSports. I have stock 19s with stock suspension and 15mm front/12mm rear spacers. Looks like 275/35 is the way to go for the rears. Will I have issues if I go to the 255/35 fronts to keep the 20mm stagger or should I keep it with the stock 245/35 size?
Thanks. |
03-12-2011, 06:29 AM | #6 | |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
03-12-2011, 02:10 PM | #8 |
151
Rep 1,599
Yes, your are fine. The increased understeer is likely something you would only notice on a track. Even if you get in a situation where the car understeers a bit, it's not a big deal.
