03-08-2011, 04:29 PM | #1 |
30
Rep 317
is it safe to Jump the coupe?
Hi,
I seem to have let my M's battery die over the winter. I remember it was getting weaker in the fall (I did start it every few weeks over the winter). Is it safe to Jump it? Id like to see if she'll hold a charge, but Im not opposed to just buying a replacement battery (she's out of warranty as of about a week before parking her for the winter). Thanks! |
03-08-2011, 04:38 PM | #2 |
25
Rep 615
Yes, but make sure you use the designated posts that are UNDER THE HOOD and not the battery itself. See your owner's manual if you are unsure exactly where the cables should go.
2013 Audi TT RS (Tech Pkg, Sport Exhaust, Heated Seats, Sirius)
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2. |
03-08-2011, 05:08 PM | #3 | |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
03-08-2011, 05:23 PM | #4 |
Dog Listener
703
Rep 7,850
Whew! When I read the title I was thinking of jumping as in "I'm going to paint it like the General Lee and have some fun a la them Duke Boys..."
03-08-2011, 05:32 PM | #5 | |
35
Rep 956
I would definitely just replace it so you don't end up stranded later. Sears has a Diehard International battery that is a direct replacement. I have one in mine. Was priced around $145. |
03-09-2011, 12:55 AM | #6 | |
///M-fanatic
193
Rep 3,885
Those terminals under the hood all link to the battery anyhow. |
03-09-2011, 01:06 AM | #7 |
23
Rep 1,034
What about a battery charger?
Straightaways are for fast cars, Corners are for fast drivers.
03-09-2011, 01:30 AM | #8 |
///M-fanatic
193
Rep 3,885
03-09-2011, 09:10 AM | #10 | |
25
Rep 615
Also, I use a battery charger all the time during the winter when the car isn't driven for several days. The terminals under the hood make hook-ups much easier.
03-09-2011, 09:44 AM | #11 |
2070
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Oh, I just uncover the battery and let my charger rest in the trunk with it closed (cable makes it out alright to the wall).
I didn't even know we had terminals under the hood, haha. Also, why a bad idea to hook the neg terminal up when jumping? Wasn't it designed to be that way?
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
03-09-2011, 09:53 AM | #12 | |
127
Rep 1,772
Drives: 2007 Z4M Coupe
Gruppe M CAI / Euro Headers / Rogue Engineering X-pipe / RE Diablo Exhaust |
03-09-2011, 10:23 AM | #13 |
///M-fanatic
193
Rep 3,885
Yeah, I still don't see how connecting directly to the battery terminals can be bad. It's all the same. The ground post in the engine bay is a common ground with the battery's negative terminal; rendering it the same in the end.
I did half an electrical engineering major, and I'm not seeing a quantifiable reason to not connect directly to the battery... Plus, not all cars have ease of access like BMW's. And therefore, most cars require you to jump the battery terminals directly. Germans just thought outside the box since a while back =P |
03-09-2011, 01:29 PM | #15 |
2070
Rep 4,365
Yeah, battery tender sure is a life saver
03-09-2011, 04:04 PM | #17 |
Accountant, 1st Class
Rep 237
Drives: 2006 Z4 3.0si Roadster, Black
Battery Jump
The main reason to not connect directly to the negative battery post has to do with the spark. It used to be (still is) very dangerous to spark around the hydrogen gases emitted by the battery. Connecting to the engine block or other negative connection would not eliminate the spark but it would be created away from the battery.
All that said, with today's closed /sealed batteries escaping gases are almost non-existent. The alternate negative connecting point never had anything to do with electronic surges or such. |
03-09-2011, 04:40 PM | #18 |
///M-fanatic
193
Rep 3,885
See that's what I thought. There really is no pertinent reason to NOT hook up directly to the battery's terminals for a jump. Spark-related issues were resolves decades ago, probably even before EFI was made available to the mass public =P
03-09-2011, 05:13 PM | #19 |
2070
Rep 4,365
That does make sense out of the whole idea though. Thanks!
03-09-2011, 10:56 PM | #20 |
Car Geek
3626
Rep 3,593
A few examples of exploding batteries due to terminal spark:
http://www.worksafenb.ca/docs/HA-Battery_e.pdf http://www.honestjohn.co.uk/news/leg...ery-explosions http://www.thehulltruth.com/boating-...y-explode.html http://www.bimmerfest.com/forums/showthread.php?t=15924 |
03-10-2011, 09:49 AM | #21 | |
2070
Rep 4,365
2. We have Z4's, which have AGM batteries. Thus, this particular line in this article pertains to us... "There are now available dry AGM batteries used mainly on stop start vehicles, which are a superb starter batteries, don’t explode and last nearly forever." 3. Not even talking about jumping, talking about driving stuff or starting a vehicle and having the battery explode. Kind of a counter point to this argument more than what you were trying to probably portray. 4. Post is nearly 10 years old, and talking about a "Kraft company vehicle" with no other explination. For what anyone knows it could have been a 15 year old car or a car that had been sitting for years. Pretty unreliable IMO. I think this is pretty much a null point on our Zeds, although some would rather be safe than sorry I guess.
03-10-2011, 10:17 AM | #22 | |
21
Rep 494
As for jumping the battery, I'm sure you are safe, but a battery tender would be the least stressful for the car.
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit| |
