03-05-2011, 09:37 PM | #1 |
108
Rep 697
Warranty brake replacement
What are people's experiences with BMW replacing brakes that are obviously used on the track?
I have a friend who is at 25k miles and two different dealerships would not replace the (oringinal) rotors because they were obviously tracked. I'm not expecting a dealership to replace cracked rotors every few months, but after almost 2 years of use on the original brakes I didn't think they would push back. I'm acutally quite suprised how hard it is to wear out a set of rotors. My friend is quite a talented and experienced driver and it took him over a year to wear the rotors down to min thickness even with track pads. So is anyone out there getting brakes replaced under warranty or does tracking the car really void such things? Last edited by RickyBobby; 03-06-2011 at 02:20 AM.. |
03-06-2011, 09:45 AM | #2 |
433
Rep 1,286
Boy, I think this is real dealer dependent. The shortest interval I've heard personally is a bit over 3,000 miles which is pretty ridiculous (VIR two events, really late braking from big speeds) but they replaced them. Another guy I tracked with had his replaced at 10,000 miles and the third guy I know just got his complete front and back brakes and rotors replaced at 21,000 miles. I guess the message is "your mileage and dealer willingness may vary."
You know the other thing that might make a difference? In each case the pads were gone. I wonder if you still have pad life left, but the rotors are shot that they might not want to do it. Last edited by VictorH; 03-06-2011 at 09:47 AM.. Reason: more info |
03-06-2011, 09:45 AM | #3 |
374
Rep 8,033
My experience has been that if the rotors do not show significant wear such as cracking (due to thermal stress) or scoring, and if you have never had your rotors replaced under the maintenance program, they will replace them at least once. The second time around can be problematic if it is too soon. I doubt that they would do a third set within 4 years.
This is somewhat explained in the program description in the warranty manual. It states that they can refuse to replace parts that have been worn out prematurely (I can't remember the exact language). Having said that, if your rotors do not show signs of cracking or scoring, and if this is your first replacement, and if they refuse to replace them, I would refer to the warranty manual and ask them to explain on what basis they are refusing service. (They should have approached the minimum thickness number though). The answer cannot merely be, "your car has been tracked." As long as the wear falls under some kind of norm (expected duration) for rotor wear, they wouldn't have a position IMO. I would force them to disclose what that norm is exactly if they refuse service, and how the wear on your rotors differ from it. This also all depends on how cooperative the service manager is. I've had good luck and dealt with a reasonable service manager. He did refuse me service once on the rotors, but I don't blame him since the rotors were severely scored and kind of toast with spydering, etc. with not too many miles on them.
03-06-2011, 04:05 PM | #4 |
108
Rep 697
Well the rotors are definitely spider cracked and unsafe for track driving. I'm not arguing the fact they they have been heated up quite a bit. My argument is that 25k and 1.5 years seems to me like a reasonable replacement interval.
I'm actually quite happy with the performance of the stock brakes with track pads and am ok replacing rotors once a year. I just figured the 1st set would be on BMW. PFC direct drive rotors are on their way.. |
03-06-2011, 06:56 PM | #5 |
892
Rep 9,032
Don't know why the dealer would give you trouble. That's a reasonable amount of time and mileage (though on the early side), and they get paid to do it.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
03-06-2011, 06:58 PM | #6 |
374
Rep 8,033
I think the issue is they need to send the rotors back to BMW NA for inspection. Not sure if that applies to all rotors or if just to a random sample. If BMW NA doesn't like what they see, they can refuse payment to the dealer is what I've been told.
03-06-2011, 08:22 PM | #7 |
15
Rep 751
It should not be a problem, but, as others have said, it really all depends on your dealer. If in doubt, I would not volunteer any information about track use, and I would be sure to have the OE pads installed when taking it to the dealer. And to answer your question, yes, track use and/or aftermarket parts can void warranty claims if the dealer chooses to take that position.
03-06-2011, 09:11 PM | #8 | |
108
Rep 697
As far as denying track use, I took the honesty route since it's pretty obvious that I am enjoying the car |
03-07-2011, 06:39 AM | #9 |
374
Rep 8,033
I've been very up front about what I do with the car with the service manager. No issues as long as you don't compete with it and mod it like crazy, which is what the manual states. I also kept the car fairly stock. My engine had problems and they told me they wouldn't have been able to do anything about it if I had messed with the ECU, etc. These are expensive cars leading to expensive repairs when issues come up, and I don't see the point of throwing the warranty out the door for another 20-30hp. Anyway, I don't think putting on a set of track pads and enjoying it on the track voids the warranty (the manual recommends the use of high temperature pads on the track!) as long as the wear is reasonable. If one does 20 track days a year on it, sure one will go through brakes every year and they won't cover it--not that they should. I think everyone is entitled to at least one brake job over the 4 years though if rotor thicknesses are down to the allowable spec.
03-07-2011, 07:56 AM | #10 |
70
Rep 1,339
I had my brakes swapped at 19K with no problems. They know I tracked the car (I got caught with rubber marble marks on the running boards! Doh!). They kind of like that I am not one of the prissy posers and drive the car. They did warn me that they will not cover items that suggest "abuse".
25K refusal is a bit tight in terms of refusal. It might be a dealer that doesn't see that many M cars, so is not used to the car's needs and project from regular 3's. I went to a dealer who over-filled my oil because it didn't know about the double sump drain. They also did not have the correct alignment specs for an M3 in their software. Remember, these are franchises. I would go to another dealer with used M cars on their lot (a suggestion). I suspect they will leap at the opportunity to steal a customer - especially an M3 owner. |
03-08-2011, 01:25 PM | #11 |
99
Rep 700
It is amazing what a 6-pack of beer for the tech or a bottle of champagne for the SA for his weeding will do for you. AMAZING. Best money I ever spent!!!
I apologize for spelling mistakes up front, they are a result of multitasking.
03-09-2011, 09:23 PM | #12 | |
108
Rep 697
I digress.. I'll post a review of the PFC rotors after I put them through their paces. |
03-16-2011, 01:11 AM | #13 |
108
Rep 697
Can't wait to install these bad boys! I forgot how huge our stock rotors really are. The PFC rotors look like they are straight from a big brake kit. I'm hoping they provide better cooling and crack less than the OEM rotors. Fingers crossed.
03-16-2011, 08:27 PM | #14 | |
Captain Obvious
90
Rep 977
Edit: Found the answer in another thread: 28.4mm.
Just a girl and her 863 ponies...
2013 Santorini M3, 2016 328i Alpine White Wagon (Lab hauler), 199x wrapped E36 M3 (because racecar) ///M-Flight Last edited by dnvrdrvr; 03-17-2011 at 09:54 AM.. Reason: Found my answer |
03-16-2011, 08:49 PM | #15 |
R A W L S
17
Rep 164
So I'm doing a DE event this weekend. My brake monitor system says I've got 6000 miles left before needing new front pads. I bet I finish them off in the first 30 minutes of driving. My car has 7800 miles on it. Do you think my dealer will provide a warranty break job for me when I take the car in next week, assuming there are no signs of tracking, other than fast pad wear?
03-16-2011, 11:39 PM | #17 |
108
Rep 697
03-18-2011, 02:20 PM | #18 | |
60
Rep 1,036
Dealer replaced my front pads at 1,400 miles. Took them 2 days to convince BMW to pay for them as good will. Now I'm running Brembo's. Think they will cover pads for me now
03-18-2011, 05:50 PM | #19 |
72
Rep 1,803
Where did you get the PFC rotors?
[SIGPIC][/SIGPIC]
2007 GT3 Clubsport w/CGT buckets in Scotland 2003 CSL, SG, Alcon BBK SOLD 2002 M5, SSII/Blk and bone stock. In storage back home in TX 2008 M3, AW/Blk 6MT, lots of track stuff SOLD |
03-18-2011, 06:11 PM | #20 |
326
Rep 3,882
03-18-2011, 06:19 PM | #21 | |
70
Rep 1,339
03-18-2011, 06:45 PM | #22 | |
374
Rep 8,033
