KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
03-04-2011, 07:58 AM | #1 |
15
Rep 274
Ideal Tire pressure
Gents new owner of a '11 e93 OEM 19's, on the contisport contact3's. Came out of a 2008 997S so am used to performance sports cars, and know how sensitive they are to subtle changes in tire pressure. On that car, after talking to various people, came to realize an "ideal" tire pressure for spirited driving around town was not at all what was indicated in the book (those pressures tend to be the "middle of the road" to balance tire life,comfort, etc. I simply want the best handling....tires are simply the cost of owning a sports car.
Was curious from those of you that have had your cars for a bit, with the stock 19's, what tire pressures you are running? I am not DE'ing the car at all, but do enjoy "driving" my car around town, so am looking for what people have found to be the ideal pressure. Thanks much |
03-04-2011, 08:37 AM | #2 |
15
Rep 751
I think you will find something around 38, at operating temperature, should be about right all around. I have found those tires operate fine on track, in the general 37-39 range. So, if on track or driving hard, you will need to bleed off some air as the temp rises.
03-04-2011, 08:45 AM | #3 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
With 18s I've found 38 to be good.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
03-04-2011, 11:52 AM | #4 |
15
Rep 274
got it...so you guys are not "staggering" the pressures front and rear as the book suggests? (I think my book said 36F/38R) you're shooting for a 38psi in all four at operating temperature, which may mean cold is like 34 or 35.....I'll try that and see if I like it better let me know if I am understanding you guys, and thanks
03-04-2011, 01:29 PM | #5 | |
15
Rep 751
03-04-2011, 01:34 PM | #6 |
15
Rep 274
OK..thanks man Also, I assume this would not change your answer, but I should have told you I have the Dinan Stage 2 suspension on there I called them earlier, and they indicated proposed 'cold' pressure of 35F/35R...sounds spot on with what you are saying (depending on how much my driving style heats them up). They also indicated I could try 35f/33R...so, once again, kudos to you I'll try both this weekend, with a goal of either 38 all around hot, or perhaps 40 F 38 R hot
03-04-2011, 02:06 PM | #7 | |
Veni Vidi Vici
89
Rep 2,750
+1 I'm currently 38 all around, but usually run one to two pounds less in the rear with my summer set-up. I'm also on a Dinan suspension. Rears are 275/40-18s on 18x10 and fronts are 255/40-18 on 18x9 (summer).
03-04-2011, 04:06 PM | #8 |
97
Rep 3,246
Running dinan as well and sounds about right to run things at 35 cold and have adjusted front to differ from back at the track to dial in or out over and understeer as appropriate, might just take some trial and error to find Your ideal pressure
mods: track ready stuff
03-08-2011, 12:37 PM | #9 |
15
Rep 274
Thanks for advice gents...just as with the Porsche, a pound or two one way or the other in these cars makes a noticable difference in the handling characteristics (that, and I am one anal retentive mo fo). With the Dinan set-up, with yoru advice, found that 35F/36R "cold" results in the best handling. EDC in normal mode ("sport" was just too damn tight, and did not allow the car to effectively absorb the steering input). Much appreciated
03-08-2011, 07:03 PM | #10 |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
how can you drive on 38?
i tired that once the car felt like it was on 1st gen runflats damn hard i stick to stock pressure |
03-08-2011, 07:16 PM | #11 |
1904
Rep 5,678
I ran my tires at 37 F, 38 R last summer and found the tires wore down in the centre faster on the rears. This summer I will take them down a couple of pounds per corner to try to even out the tire wear across the whole tire.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
03-09-2011, 03:01 PM | #12 |
24
Rep 398
If I'm not mistaken it depends on average speed. So if you drive mostly on freeways at high speeds (80mph) you need higher Psi? Correct me if I'm wrong!
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan.
03-09-2011, 03:38 PM | #14 |
76
Rep 1,147
Drives: 02 E46M3 15 F80 M3 16 X5 35d
I have mine at 36F?34R with pretty even wear on the street. JMO
03-10-2011, 03:37 PM | #15 |
Rep 69
