02-28-2011, 09:33 PM | #1 |
///Mmmm
78
Rep 796
Drives: '09 BMW 135i
Wheel Spacer Install & Pics (56k Death)
Here is my install of the BMS Wheel Spacers. I bought 10mm for the Rear, and 12mm for the Front. Due to front passenger side wheel lug bolts being overtightened (not by me), and un-removable at this time I could only install the rears. It was hard to get exact before and after pictures, enough to tell a difference. While driving so far, the rear end does feel slightly less wobbly.
When I had my tires put on at a local Firestone, I'm thinking they overtightened the lug bolts. I went back today to have them loosened by impact air tools, but the employee claims they always tighten to spec. Even with the air tools, the front passenger bolts wont budge. Following pictures are of just the Rear Passenger side. As usual with me, More pix the better. Nikon D90, Nikkor 18-200 3.5-5.6 VR Fat man trying to losen my lug bolts BMS 10mm/12mm Wheel Spacers, New Torque Wrench, & Anti-Seize Loosening the Lug Bolts High Performance Formula1 Chocks Wheel was very snug, had to kick it off the hub Wheel off Dirty!!! After some brake cleaner and a good scrub, it looks... well the same. All by myself... All set to go Pre-Lube with Anti-Seize. Do Not Use Grease, Anti-Seize has High temp resistance. Brakes get hot! Spacers need a little assistance over the rusty crust 10mm Power Tighten to 88 lbs A few Finished Shots. The difference is subtle, but it was a fun install. Hopefully soon I'll have my 12mm up front. GOT THE FRONTS ON NOW. 10mm Rear, 12mm Front Plans for the future are Koni FSD & Eibach Springs... Thanks for viewing.
Current: E90 LCI 335i JetBlack - BMS OCC, JB4 w/ E85, ETS Charge Pipe, Vishnu Catted DP
Retired:///E82 135i LeMans - 12.710 @ 108 MPH Riss Racing OCC, Shadowline Grills, Magnaflow Axle-Back, JB4, ETS FMIC, BMS DCI, BMW Perf Sideskirts, BMS 12/10 Spacers, E93 Front Sway PDC Flickr YouTube Last edited by Hind; 03-23-2011 at 04:00 PM.. |
02-28-2011, 10:04 PM | #2 |
15
Rep 174
Very nice can't wait to see it when the car is lowered.... A bit overkill on the anti seize?? Haha
BMS JB4 PnP / RPI scoops / BSH OCC / BMS DCI / H&R Super Sport Springs / Nitto INVO 225f 255r / CP-e axle back / BMWPerf. CF rear spoiler, iCarbon CF sideview mirror covers / CF grills / BMWPerf. Front rotors / EBC slotted rear rotors / SS Braided lines / StopTech performace pads / E93 M3 Front Sway / BERK resonated mids / BMS 12mm spacers
02-28-2011, 10:05 PM | #3 |
415
Rep 2,475
Gotta love that improved stance. Can't wait till it's lowered. Great work bro!
How do you like your Conti tires? I was think of getting those as well.
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i |
02-28-2011, 10:14 PM | #4 |
///Mmmm
78
Rep 796
I cant wait either, I'm in the middle of buying a house so mods gotta wait a bit. Conti DW tires made the car a BMW. Grip, handling, ride, comfort, & noise have all brilliantly improved. Cant recommend removing ur runcraps enough. 100% better.
Retired:///E82 135i LeMans - 12.710 @ 108 MPH Riss Racing OCC, Shadowline Grills, Magnaflow Axle-Back, JB4, ETS FMIC, BMS DCI, BMW Perf Sideskirts, BMS 12/10 Spacers, E93 Front Sway PDC Flickr YouTube |
03-02-2011, 06:54 AM | #5 |
323
Rep 1,804
Looks good man. When I was putting my spacers on (pre-Breytons) I used some WD-40 and sandpaper to get the rust off the hubs. It made it a lot easier to get the spacers on. I used the same anti-seeze too - works pretty well. You coming out Saturday?
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
03-02-2011, 09:10 AM | #7 |
I bleed Scarlet and Gray!!
23
Rep 552
I just did the BMS spacers too. 10mm up front and 15mm in the rear. I am on JIC CROSS coilovers. Had to cut a small piece of the plastic fenderliners on the rear wheelwells. But with the aggressive camber and a bit of toe out on the front, they fit really well and it looks awesome.
03-02-2011, 11:30 AM | #10 |
23
Rep 552
03-02-2011, 11:36 AM | #11 |
European Editor
10607
Rep 22,992
Nice DIY photos.
One tip, I would hammer the spacers onto the hub. I would have used a wire brush or scotch-brite pad to remove the rust from the hub lip area. Q). Did you also use longer wheel bolts? Do they come with the BMS kit? How much if you don't mind me asking? Also - maybe you could post some outdoor photos of your car w/the spacers mounted. Dackel |
03-02-2011, 11:46 AM | #12 | |
23
Rep 552
03-04-2011, 06:22 PM | #13 | |
323
Rep 1,804
Now that I think of it. It was a scotch pad, not sandpaper!
-Nick
03-04-2011, 06:33 PM | #14 |
102
Rep 1,552
Drives: '19 M2C | '20 100AE ND2
Because spacers are cheap and new wheels and tires are expensive.
2019 M2C - Alpine White - 6MT
2023 Supra 6MT - Deposit and Wait |
03-04-2011, 09:23 PM | #16 | |||
///Mmmm
78
Rep 796
Thanks for the comments!
I did hammer the spacer onto the hub. I tried a bunch of remedies, I guess I'm either weak or didnt try hard enough. Either way they are gonna be a pain getting off if I ever need to get them off. I paid BMS retail price which is $99 pair, and they come with new lug bolts. Quote:
Like mentioned above, spacers are cheaper, and I like my wheels. I plan on installing the suspension myself with a mechanic friend I have. Only had firestone switch my tires out a few months ago, cuz I cant do that. Come'on, can you switch tires urself with the average man's tools? Um.. no Firestone also damaged my wheels + BMW Wheel warranty = wheels look new again for free.
07-16-2011, 02:26 PM | #17 |
Work hard, play harder
14
Rep 261
Sorry to bump an old thread, but Hind, do you think you could have fit a 12mm spacer on the back? It looks like you're on stock suspension with 261m wheels.
I'm having a hard time coming up with a definitive answer to spacers for a stock set-up. I've seen vendors suggesting everything from 18mm front / 10mm rear to 10mm front / 15mm rear. I couldn't be more confused!?!?!?!? Thanks, Bryan Last edited by BBursey; 07-17-2011 at 10:22 AM.. Reason: Grammar |
07-16-2011, 02:57 PM | #18 | |
///Mmmm
78
Rep 796
07-16-2011, 04:23 PM | #19 |
705
Rep 3,268
Drives: 2010 128i
If you're not stock, 12 mm may be too much. I rubbed with 12's in back, but I'm lowered on Bilstein PSS9's and running Star Spec 255's in back (which I'm told run wide). Just FYI.
____________________________ |
07-16-2011, 05:50 PM | #20 |
269
Rep 4,470
Yes so why should anyone be impressed with a cheap fix on their 1?
135i, SGM, Coral, Sport Package, Auto, Premium Hifi, USB/ipod, Apex EC-7s, PPK Stage II
07-16-2011, 09:38 PM | #21 | |
///Mmmm
78
Rep 796
Additionally, considering the price difference between wheels vs spacers, yes its "cheaper", but the quality of the spacers are top notch. I wouldnt say anything about this mod is "cheap"...
