02-25-2011, 12:27 PM | #1 |
Feeling Blue.
117
Rep 801
Drives: I12 i8,f10 M5,e89 IS,F1 6S35i
megan racing exhaust on e93 installation issue
so ive been searching high and low for an answer to my question. What support bar is it that needs to be "fabricated" on a e93 when installing a megan racing axel back exhaust? Or is it just something i need to unbolt? please let me know because i want to order the exhaust as soon as possible.
02-25-2011, 12:32 PM | #2 |
514
Rep 1,437
Never heard of this. Maybe you should consider another exhaust???
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
02-25-2011, 12:35 PM | #3 |
Feeling Blue.
117
Rep 801
well i always thought that virtually the e92 and e93 share the same exhaust setup and that only the e90 setup is a little different. so i did some searching on the forums just to make sure and apparently something needs to fabricated, i just want to know what lol..
02-25-2011, 12:37 PM | #4 | |
BimmerPost Supporting Vendor
8208
Rep 18,823
Drives: BMW
These images will show an Akrapovic Slip-On system properly installed, properly clearing the support brace: I would highly recommend against modifying any pre-existing structural support systems to install aftermarket parts.
02-25-2011, 12:41 PM | #5 |
Feeling Blue.
117
Rep 801
i really apreciate that tom, THANKS!
02-25-2011, 12:42 PM | #6 |
514
Rep 1,437
I have an RPI and it fit through the E93 support structure with no issues. Id be very weary of installing an exhaust that doesnt.
02-25-2011, 12:48 PM | #7 | |
Feeling Blue.
117
Rep 801
well according to the company this exhaust is made for the e92. I tried calling the company however they said that there is no real demand for e93 m3 exhausts ... and they did not want to disclose what was needed to be fabricated if i indeed wanted to install it on my car...go figure |
02-25-2011, 12:49 PM | #8 |
514
Rep 1,437
That being said, time to search for a different exhaust.
02-25-2011, 12:50 PM | #9 |
Feeling Blue.
117
Rep 801
03-03-2011, 03:10 PM | #10 |
56
Rep 504
it will not fit at all. I found this out after spending 3hrs taking the oem exhaust, a couple of trips to the hardware store to get some missing stuff, and another 2ish hrs of fitting the megan to finally get to the canister that would not clear the bar.
The issue is that the megan exhaust is ONE whole unit that has been designed without this bar in mind; the stock exhaust has a notch in the middle which is why the e92 and e93 have the same part. The only way to fit this exhaust is to either modify the muffler or the bar which is a big no no (provides support to the rear) So I ended up selling my megan and bought another one. Hope that helps btw. I saw your pics of the lip you are selling, what is the suspension/spacer mods on your car? Stance looks perfect. Thanks |
Tags |
e93, exhaust, issue, megan racing |
