      02-23-2011, 03:33 PM   #1
AntonV
AntonV's Avatar
39
Drives: Sedona/Savanna 135i
tpms frequencies. what years did they change?
I have a 2009.....may build. looking to buy 1 used tpms from an 08. think itll work?
2009 135i Coupe - Sedona Red Metallic - Savanna Beige - 6MT- ///M Sports Package - Boston Leather - Power/Heated Seats
2005 BMW F650 GS - Mandarin Yellow - Farkled
      02-23-2011, 03:40 PM   #2
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
The change was late in 2010 models. I think Sept(?) builds. Pre 2010 models had the same 433Mhz TPMS.
The 2008 sensors should work from what I have read posted here.
Dackel
      02-23-2011, 04:16 PM   #3
Gary@TireRack
Moderator
Gary@TireRack's Avatar
369
Drives: Formerly 1995 M3
The date for the sensor change in the 1series was 9-1-10. Models built after that used a different sensor.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      02-24-2011, 04:58 AM   #4
IDBMW
IDBMW's Avatar
41
Drives: 2019 X3 M40i
I have a March 08 build date and have bought two sets of wheels and tires from Tire Rack with sensors in both. One set was purchased March 2009 and the other set November 2010. I put the wheels on the car and drive off without resetting the TPMS and no dash lights.
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
      02-24-2011, 05:03 AM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Keep in mind that ANY TIME you change tires or add air into the tires... you SHOULD reset the TPMS. This will tell the system what the traget pressure is. So it can warn you of a deflation/flat.
      02-24-2011, 10:49 AM   #6
Tom K.
Tom K.'s Avatar
124
Drives: '07 328iT, '13 Boxster
Simply adding air doesn't require a reset unless you wish to change the reference pressures.
Changing a tire without a reset will trigger the warning.
Tom
      03-05-2011, 08:27 AM   #7
DrPig57
DrPig57's Avatar
16
Drives: Crimson/Coral 135i M// package
That makes sense. I have a 2011 135i (July build)and I'm using sensors from an 2008 135i. No issues.
I was told pre September 2010 there were four sensors (one in each wheel well) after September 2010, there is only one sensor. They still operate off 433 Mhz
      03-11-2011, 11:41 PM   #8
psalm40
Jet Black 135cic
psalm40's Avatar
Drives: 2011 135i convertible
Just looking for a little clarification....
Will these TMPS's work?
I have a 2011 135cic (May '10 build).
I am looking at buying wheels that are currently on a 2008 135i coupe with, what I assume are, 2008 TPM sensors from TireRack.
Thanks!
EDIT:
I just re-read the earlier posts. I think that I am OK. There seemed to be some confussion in the earlier posts between 2010 model years and build dates.
2011 Jet Black 135i Vert
2011 Diamond White GL450
      03-12-2011, 05:48 AM   #9
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Thanks!
EDIT:
You should be Ok.
Build dates before Sept/2010 use the old TPMS sensor. Build dates before Sept/2010 use the 433K Hz sensors. After Sept BMW changed the whole system design & freq.
Dackel
1addicts
