KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
02-21-2011, 12:14 PM | #1 |
923
Rep 15,818
Same profile in the rear?
I have always thought that you need to have a larger profile in the front
But after some research, I have found that, depending on the size of the tire, you can have the rear be the same profile I'm looking at these specs: 20x8.5 et 32 20x10 et 25 With these tires: 255/30/20 Nitto 285/30/20 Nitto Now, I know that if the rear was 275/30/20 it would be fine... but what about the 285/30/20? Is that an ideal size? Thank you
02-21-2011, 03:34 PM | #2 | |
Putcha ang ganda...
281
Rep 5,441
i know some people here using 285 rear dont have any problem depending on tires but remember make sure your drop cause running 20' wheels look like a 4x4 on a stock height m3 but you should be ok to run 255/30 and 285/30 although it looks like that you might need spacers on the front to have it flushed rears are ok with the 285 but front definately need a spacers..
02-21-2011, 03:37 PM | #3 |
923
Rep 15,818
How come it would need spacers?
Stocks are et 29 with 8.5 rim right?
02-21-2011, 04:02 PM | #4 | |
Putcha ang ganda...
281
Rep 5,441
Not that u dont need it its just running 20 is a bit tricky to pull it off on an M3 meaning u must be aggressive and drop... Sorry its harder to type it than showing u in person U can still pull 10mm and use 255 but u might rub on full lock turn... With or without spacers...
02-21-2011, 04:06 PM | #5 | |
923
Rep 15,818
I hate rubbing
02-21-2011, 04:28 PM | #6 |
923
Rep 15,818
found out front is 8.5 vs 9
so a spacer will be needed to be flush, but not required a drop.. well a drop is 'always' a must on the forum right? stock wheels or aftermarket lol
02-21-2011, 04:51 PM | #7 | |
Putcha ang ganda...
281
Rep 5,441
20 on our car withiut a drop looks so damn wierd like a 4x4
02-21-2011, 04:59 PM | #8 |
Wheel Whore
29
Rep 76
I'm on RD sport springs with:
20x8.5 et10 20x10.5 et15 245/30-20 285/30-20 I had the fenders slightly rolled and it doesn't rub at all.... IF you wanted to match my offsets, then you need: 20x8.5 et 32 (22mm spacers) 20x10 et 25 (16mm spacers) if you want something more conservative, 20x8.5 et 32 (10-15mm spacers) 20x10 et 25 (5-10mm spacers) Keep in mind I'm running 10.5 and you have 10.0. The 285 rear tire stretched more on my wheel creating more fender clearance... ALWAYS!
|Arkym CF F&R-Hood-Bootlid | RD Sport Springs | 20" Venaci Spirit w/ Michelin PS2 | Alpine 3kK HID Halo | Light HL&TL overlay| |TecnoCraft Kevlar Envy | Gintani Tune-HFC-Xpipe-Muffler | AC Schnitzer Roof Spoiler | Huper Optik 40% | BRM21 LED| |
02-21-2011, 05:09 PM | #9 | |
923
Rep 15,818
I can appreciate an aggressive set up, but it's just not for me. The rear is perfect for me. the front I may add a spacer. I would rather not roll my fenders. I rather it not poke out too much lol a drop is a different matter. I wouldn't mind if you wanted to post some pictures :P
02-21-2011, 05:59 PM | #10 |
Wheel Whore
29
Rep 76
Here's some shots so you can see the fitment in reference to the fender... You can see what I mean by the stretch of the tire in the last picture.
02-21-2011, 06:02 PM | #11 |
923
Rep 15,818
damn that's really aggressive
def sexy. but too much for me lol
02-22-2011, 03:53 PM | #12 |
923
Rep 15,818
ok so basically to make it flush, I'll need to add a 10mm spacer to the front to make it 20x8.5 et 22
What spacer would you guys recommend? I'm thinking maybe MS?
02-22-2011, 05:33 PM | #13 | |
Wheel Whore
29
Rep 76
LINK I've never used the MS, but haven't heard anything bad about them. EAS has the 10mm in stock. LINK Hope this helps!
02-23-2011, 01:13 PM | #14 |
923
Rep 15,818
thanks :P
03-03-2011, 07:22 AM | #15 |
Rep 18
hello
i whant to put wheels on my bmw m3 e92 from 2008 in 8.5 x 20 and 10 x 20 whit offset 15 front and rear.whil it work or not?.what tires most i put in front and rear so i whil have no rubbing in my front and rear fenders;i don't want to rolle my fenders.i'm thinking on 245 30 20 front and 275 30 20 rear.whil it work???or what must i do. |
03-03-2011, 05:30 PM | #17 | |
Rep 35
03-06-2011, 01:13 PM | #18 |
Rep 82
with the offsets you're quoting sound similar to the bbs offsets on mine - the original profile on my rear's which are the same size and offset, recommended tyres were 285 25 20...however, the ride was pretty firm and i managed to crack the rears in some bad potholes...
So I'm changing the rears to 285 30 20 and having spoken to both tyre fitters and Donbona's who also has this profile tyre, I'm told it's an improvement. As for lowering - the pics show that the rear is not too bad with standard height (these are the 25 profile tyres) but the front looks like it could do with shorter springs and spacers...BUT and a big but my daily driving here in the UK involves speed humps which are all over the place and as I use myine for daily use I wouldn't lower it any more than stock unless I had adjustable coilovers like kw variant 3...
M3 Convertible 2008, Jerez Black with individual orange peel effect (factory standard), Fox Red, DCT, EDC, High gloss, carbon leather, comfort access, Logic 7, adaptive headlights, Tubi Rumore, 20" BBS CX-R, 19" OEM and 18" OEM with Winter Tyres....investments in BP/Shell
08-09-2011, 01:41 PM | #19 |
81
Rep 639
bump
'11.5 SG E93/6MT/ALL BOXES CHECKED BLACK GRILL/BLACK SIDE GILLS/15% TINT/PAINTED REFLECTORS/SPACERS/ANGEL iBRIGHTS/20'' VOSSEN CV3/VINYL WRAPPED SHADOW LINE TRIM/ETS-POWER TUNE/ ///M-FLIGHT MEMBER |
