02-19-2011, 06:57 PM | #1 |
123
Rep 891
iPhone works in a 2008 but not in a 2011.5???
I finally picked up an iPhone 4 the other day and the audio has been cutting off and throwing the radio back to FM AM. My car is a 2011.5 bare bones other than the iPod connection in the center console.
So I drive to the dealer and ask someone if they've heard of anything like this before. One of the salesmen walks out, tries out another Y connector which fails to correct the problem. He proceeds to tell me to buy a 3.5mm audio jack and connect both the audio jack and iPhone connector to the phone if I want it to work. Not happening. So I decided to try the BMW supplied Y cable on my friends 08 M3 which is fully optioned and it worked flawlessly. Doesn't cut out at all and charges the p hone as well. At this point I know it isn't my phone or the supplied Y cable. Does anyone have any suggestions on what to do next? Thanks in advance. |
02-19-2011, 07:00 PM | #2 | |
Rocket Scientist
33
Rep 948
2015 BMW M5 Sedan Returned to BMW at end of lease.
02-19-2011, 08:25 PM | #4 |
98
Rep 525
Drives: '21 F95 X5 M C, '11.5 E92 M3 C
+1. 2011.5 uses the white USB cable that came with your iPhone. No audio or charging issues with mine using the Apple USB cable.
Drives: '11.5 Interlagos Blue E92 M3 Comp, '21 F95 X5 M Comp DIYs: Enable Rear Fog | Easy Side Gill Replacement | Front Grill Replacement |
02-19-2011, 09:06 PM | #5 |
123
Rep 891
02-19-2011, 09:11 PM | #7 |
98
Rep 525
Was yours build on or after Sept 2010? If not then you need the Y cable. 2011.5 refers to cars with the COMBOX iDrive and built on or after Sept 2010.
02-19-2011, 09:24 PM | #9 |
98
Rep 525
Ah. Sorry thought you did. I'm not sure for non-iDrive cars.
02-19-2011, 09:27 PM | #10 |
98
Rep 525
Maybe you can get your dealer to order same cable as your friends Y cable.
02-19-2011, 09:54 PM | #11 |
123
Rep 891
My friends 2008 Y cable and my 2011.5 Y cable have the same part number. The only thing I can think of is the cars software hasn't been updated. I doubt that because I just had my 1200 service done and I HOPE they checked it lol.
02-19-2011, 10:01 PM | #12 | |
341
Rep 655
02-19-2011, 10:04 PM | #13 |
123
Rep 891
I've 4 cables here and I'm going to step outside and all four. One of them is the cable that came with the phone and I have no clue where the other cables are from.....BRB
02-19-2011, 10:32 PM | #14 |
123
Rep 891
Ok......car was built 12/10
I tried every USB to iPhone cable I had in the house including the one that came with the phone and they all did the same thing. Pandora would play for a few seconds then pause itself and the radio would go back to FM radio. Eventually the radio wouldn't even recognize the iPhone at all regardless of how many times I swapped the cables. So as of now I'm convinced I don't need the OEM Y cable but there is something wrong with the vehicles iPod/Phone interface. P.S. I also tried an iPod touch I have and it did the same thing. Play for a few seconds then cut off and revert back to FM. |
02-19-2011, 10:47 PM | #15 | |
341
Rep 655
02-19-2011, 10:58 PM | #17 | |
123
Rep 891
So when that feature finally does become available will I be able to just update the software at the dealer or will I need a hardware change as well? Thanks a bunch gents. Last edited by Bx Tpr; 02-19-2011 at 11:32 PM.. |
02-20-2011, 12:17 AM | #18 |
123
Rep 891
02-20-2011, 10:55 AM | #19 |
341
Rep 655
As 2011.5 M3 is the my first BMW, I don't know for sure, but I would guess it due to the Y connector the fact that it gets audio from the AUX cable and uses the USB for charging and phone functions?
You can achieve the same thing by using a separate AUX cable, you just can't have the Y connector. |
02-20-2011, 11:31 AM | #20 |
2297
Rep 13,005
