02-18-2011, 12:08 PM | #1 |
70
Rep 1,339
Blackstone Oil Reports from Aftermarket Air Filters
Has anyone done an oil report on an engine with and aftermarket air filter running? Are the signs of increased wear/contamination compared to stock?
I am thinking about a high flow air filter, and I am looking for evidence of the impact on the engine. I have read the anecdotes and reviews of filters from searching, but could not find any mechanical data. Thanks in advance |
02-18-2011, 12:30 PM | #2 |
258
Rep 5,012
Just blow dirt thru both filters with a ShopVac with a damp white shop towel behind and you'd NEVER consider buying one again . Can't understand why people put racing filters on their street cars for a HP or two at redline (if at all), especially in dusty places, but to each his own. Good luck.
02-18-2011, 01:36 PM | #3 | |
70
Rep 1,339
The question was aimed at seeing if there is objective evidence that there is increased engine wear from the filter change, rather than assumption? The extra dust could get trapped in the oil filter? I don't know, that's why I am asking. |
02-18-2011, 02:01 PM | #4 |
56
Rep 783
Good question.
Subscribed, hopefully someone will answer this soon.
2021 M3 6MT Brooklyn Grey/Silverstone
Previous: 2009 335i ZMP 2013 M3 6MT ZCP Space Grey/Fox Red |
02-18-2011, 02:05 PM | #5 |
168
Rep 1,792
I was running a GruppeM intake (w/ K&N cone filter) when I had my Z4M, did two blackstone oil reports..and both times no extra silica was found in the oil samples, wear was right along the line with other S65 engines.
I was also running a RPi scoop at the time, and the scoop was directing the oncoming air RIGH AT the cone filter like a ram air system. Still, the K&N filtered really well. |
02-18-2011, 03:59 PM | #6 | |
258
Rep 5,012
And the dirty air goes straight to the pistons thru the combustion chamber. It gets to the oil filter after that. Using a 'wet' filter is not going to grenade your engine, but you need to understand the obvious: bigger holes mean more air, but also more dirt; no free lunch here. The issue is if your engine needs the extra air, and the answer is no at lower rpm, where you have to drive most of the time. So the debate becomes IF you get a few more ponies at redline, is it worth it having at the expense of ingesting more dirt? Only you can answer that question. Do your research to decide what you want. But if anybody tells you a wet filter filters the same as a paper one, do the simple test I told you and you'll know for sure. Or just read the myriad independent tests done on the subject. Just like changing oil at 15K miles rather than 7.5K (or whatever) is not going to have an immediate impact on your engine, same thing with air filters. You'll never going to have a consensus on boards like these, so just use them as opinions, including mine. Do YOUR research and come to your own conclusions. Signing off. Good luck. |
02-18-2011, 04:16 PM | #7 | |
70
Rep 1,339
02-19-2011, 03:48 AM | #8 |
220
Rep 2,339
Did one report prior to installing a filter and I think I'm on my 4th one after the filter. None of the after reports have shown anything different from the 1st. The trends continue to be the same after each report.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
02-19-2011, 03:54 AM | #9 |
808E90
233
Rep 4,047
Good thread ... I wonder how the impact would be on my ESS SC system considering the filter is at the bottom front of the car.
LTMW FTL . Karbonwerks LCI Trunk . Vorsteiner Poly Front Lip . NA Motorsports LUX H8 . RECARO Pole Position Seats . BMW Performance Pedals . BMW Performance Performance Grills . BMW Painted Fender Grills . BBS 19x9.5 19x11 LMs . Michelin PS2 265/295 . H&R Sport Springs . Wheel Mate 45/55MM Stud Kit . BBS Red Lug Nuts . ESS VT1 Supercharger . Akrapovic GT4 Exhaust
02-20-2011, 03:03 AM | #10 |
168
Rep 1,792
02-21-2011, 08:57 PM | #12 |
28
Rep 843
Here is what I feel to be a thorough test of oem (paper) versus aftermarket filters.
Cliff Notes: There's no going around the common logic that higher flow means less filtration and vice versa. However, less filtration doesn't necessarily mean catastrophic. It's your car, your money, and you decide if the extra 1-5 hp is worth the tradeoff. |
02-21-2011, 09:30 PM | #13 | |
220
Rep 2,339
02-22-2011, 11:12 AM | #14 |
frequent tire investor
Rep 54
02-22-2011, 11:17 AM | #15 |
93
Rep 2,528
Where I live, its pretty safe to assume that most dust particles that would get past my filter are organic and would burn up in combustion before they blow-by the rings and get trapped in the oil filter.
"But resist we much; we must; and we will much; about that be committed." ~Rev. Al Sharpton 2010 E92 M3|Silverstone II|M-DCT|NCSW|2MT|ZCW|ZPP|ZTP|302|507|Gas Guzzler Tax |
02-22-2011, 11:35 AM | #16 | |
93
Rep 2,528
