KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
02-17-2011, 01:55 PM | #1 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Tire Pressure Monitor Life-span Question
I have a set of TPMS off of a set of wheels that have been sitting in my garage for two years (only used on the car for 750 miles). I was thinking of pulling them off and using them on a new wheel set I'm putting together. Does anyone know how long TPMS are supposed to last? Is there a battery inside of them that should be replaced? Since they have been idle for so long will they have plenty of juice? I would hate to install them and have to deal with the hassle of them failing....
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
02-17-2011, 02:14 PM | #2 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
For what it's worth, Wikipedia says 7 to 10 years is typical.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
02-17-2011, 02:24 PM | #3 |
2739
Rep 6,734
Thank you. I just did a search and that is consistent with what I found out. Tire Rack says 5 years.
'23 X7
02-18-2011, 01:57 PM | #4 |
M3Post Supporting Vendor
87
Rep 964
5 is low end of what's possible, 10 is at the high end. It will vary, because most of them go into a power saving mode when they are not moving. OEM sensors are not designed with battery access, so if they die you have to get new ones.
If they've been sitting they should be fine. Put them on, follow the owner's manual instructions for resetting the TPMS, and drive for 20 mins or so. They should sync up and work normally.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
