02-17-2011, 01:04 PM | #1 |
32
Rep 378
Drives: AW 2011 135i 6MT
3rd Gear to 4th
Just like the title says...has anyone else noticed when you shift out of 3rd and are about to shift into 4th the shifter pulls to the left and tries to go into 2nd? I usually shift around 2.5k rpm, it doesn't happen every time but it is quite annoying having to fight the shifter...
Order Placed: October 25 | Production Complete: November 4 |En Route: November 16 | At Prep Center: December 2 | At Dealer: December 6
02-17-2011, 01:26 PM | #2 | |
20
Rep 219
CP-E Catless DP's // CP-E Midpipes & Rear Exhaust // BMS DCI // Stett Charge Pipe // TIAL 50mm BOV // Helix FMIC // Stock Tune Soon to Come: Cobb Accessport Stage 2+ |
02-17-2011, 01:36 PM | #3 |
57
Rep 2,251
I haven't had that issue. I take it you are still using stock shifter?
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB |
02-17-2011, 01:49 PM | #4 |
40
Rep 1,058
BMW Short shift kit and no issue like that here, sounds like there's a problem with your linkage.
The faster you go, the better it feels
02-17-2011, 02:50 PM | #5 |
105
Rep 2,696
I've never had anything like that with my 2011...could be driver habit learned from a previous car?
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
02-17-2011, 03:47 PM | #6 |
European Editor
10589
Rep 22,992
OP - that is not normal. Either your shifter needs to be adjusted or maybe one of your motor mounts or trans mounts is bad/broken and the engine is leaning slightly to one side cauing the linkage pull. I would go have it checked out at a BMW dealer.
Dackel |
02-17-2011, 04:03 PM | #7 | |
32
Rep 378
The shifter basically pulls to the left it is like I am arming wrestling it...3 to 4th is almost a straight line down so when it pulls left it is very easy to notice... Everything is stock except for the exhaust, I thought it was strange I guess I will have to have BMW check it
02-18-2011, 09:48 AM | #8 |
Lord Captain Commander
110
Rep 3,093
Got the BMW SSK and I didn't notice this at all before or after the install. 3rd to 4th goes very smoothly, I can literally just tap it with the tips of my fingers and it'll go by itself.
Have it checked out
E82 135i M-sport: SGM/6MT/Black |
02-19-2011, 08:12 AM | #9 |
Rep 242
Are you sure you're not doing it?
Try this: Get into the car while its off, put the shifter into third and then clutch in and just use one finger to pull the shifter out of third. Does it move to the side? If it does you have a problem. If it doesnt, the next step is to try it with the drivetrain under load. Disclaimer: This is a potentially dangerous thing to do if you are not paying attention. If you are not totally comfortable doing it, dont. If something happens I take zero responsiblity. Pick somewhere nice and open (and empty, try this on a saturday morning or very late at night) like a large parking lot, get the car up to fourth at like 30 make sure you have nothing in front of you for a while. Now floor the accelerator for just a second to load the drivetrain, look down at the shifter, clutch in and just pull the shifter out of gear with one finger, as you did last time. If the shifter didnt move last time but did this time than you have a loose motor or tranny mount which is causing things to move around under load. Unless Im racing, I always use two or three fingers to go from third to fourth: so the normal case is that the shifter should go directly down into fourth with no lateral play at all. If you do the loaded test and see no play in the shifter then it's most likely just you're technique. Sometimes you can think you're going in a straight line, but that straight line isn't pointing down, its actually pointed at you meaning that it's diagonal to the line that you want to be straight. Human perception is a funny thing, especially when you're making a mental spacial analysis without the use of your eyes, just relying on feedback from your muscles. I had to get used to changing my grip going from 3rd to 4th while racing, because I always tended to pull the shifter towards me, towards second. I would run into the bridge of the H and miss third gear. And then the STi or the rustang would win and I would be sad =*( Now when I shift heavy from 3-4 I actually grab the left side of the shifter to apply a little counterforce to my natural tendency to pull towards me. |
02-19-2011, 09:51 AM | #11 |
Rep 189
Drives: '13 Z4 sDrive35i DCT
no shifter problem here
02-19-2011, 02:17 PM | #12 |
69
Rep 847
How are you holding the shifter?
never wrap your hand around it like you're about to jerk off. For 2-3 just push forward with an open hand, for 3-4 just pull pack with your fingers, maybe wrap your fingers around the shifter from the left so you aren't pulling it left? |
02-19-2011, 06:58 PM | #14 |
378
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
nope
02-19-2011, 08:50 PM | #15 |
184
Rep 3,939
Nope never...2011 6mt and shifts FLAWLESSLY...in fact, the engagement of the gears is so positive that in 7 months of ownership I have yet to miss/scratch a gear!
02-20-2011, 01:09 AM | #16 |
69
Rep 847
02-20-2011, 08:02 AM | #17 | |
69
Rep 658
People say it looks like I'm slapping my shifter when I shift. I guess most people grip it to shift. |
02-20-2011, 12:25 PM | #18 |
Rep 31
Have to agree with the stud. After 5 months I have never missed a gear. Just a positive touch and the shifter smoothly goes where it needs to be.
02-20-2011, 01:24 PM | #19 | |
32
Rep 378
I tried this and the shifter seems to move up, down with no movement to the side. I swear it was pulling to the left but I guess I could have been me causing it. I will keep you guys updated if I end up taking in to the shop. Thanks for all the feedback!
02-22-2011, 01:49 PM | #21 |
11
Rep 185
try shifting with your thumb pointing down when going from 3-4. It will make it harder to pull the stick towards you.
Got the idea from this video... works really well
135i Coupe sport with: JB4, BMW Performance Exhaust, Cross Drill/Perforated front rotors, Black Kidney Grills, Carbon Mirrors, Carbon Tail, Carbon Diffuser. |
02-23-2011, 01:12 AM | #22 |
196
Rep 2,486
sounds like your pistol gripping and its not the car just your hand motion. Pistol gripping can cause a money shift esp if your in the high rpm range in 3rd gear.
